LB7 Fuel Pump - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 12-13-2011, 08:59 PM Thread Starter
andrew24dub's Avatar
LB7 Fuel Pump
Hey i have a 2002 gmc duramax and it has a superchips flashpaq tuner, mbrp exhaust, a ppe boost valve, and a profab intake horn, all on a stock trans and turbo and im wondering what would be the benefits to adding a bigger or better fuel pump?
I have no clue about what it will do if anything to help the performance of the truck or fuel mileage so any information will be appriciated
I would like to know what does this help if i were to get a better fuel pump or what mod i could do to make it deliver more fuel?
ive been told with more fuel comes more power, but is this true with just getting a better fuel pump and also does this mean more smoke?
im very confused, please help
2006 GMC Sierra 2500HD 4x4 SLE LBZ
Silver Birch Metallic
Andrew's Youtube Channel
EFI Live by IdahoRob/ TransGo Jr/ Banks Intake/ Airdog 2 4G DF165/ Merchant Automotive Pump Rub Fix/ Suncoast Filter Loc/ Deviant Tie Rod Sleeves/ Rancho RS9000XL/ MBRP S6004P/ CAT Fuel Filter Adapter/ Alligator Transmission Repair Lines/ DHD Brace/ Blocked/ Shimmed
andrew24dub is offline
post #2 of 9 (permalink) Old 12-13-2011, 09:09 PM
I'm That Guy...
TDFDiesel's Avatar
You don't have a fuel pump unless you installed one. Add an AirDog165 lift pump, it will help prolong life of injectors by removing air and additional filtration.
Tony
Old Trucks: 3 - LLY, 1 - LMM
TDFDiesel is offline
post #3 of 9 (permalink) Old 12-14-2011, 11:51 AM Thread Starter
So how can I get more fuel into the engine because I've heard with more fuel comes more power?
post #4 of 9 (permalink) Old 12-14-2011, 11:52 AM Thread Starter
Also I think it makes more smoke too, I'm not completely sure, sorry if these are dumb questions
post #5 of 9 (permalink) Old 12-14-2011, 12:59 PM
BIG PHIL's Avatar
You can buy a Lift Pump and install it on your truck. It will provide fuel to your injection pump to make it last longer and not work as hard. Like TFD said , an Air Dog is a good option because it also provides filtration of your fuel. If you have a tuner a lift pump will help out.
Creepy-Ass Cracker
2003 GMC Sierra CCSB 2500HD 4x4
Duramax
Rancho lift, Kryptonite upper control arms, Rare Parts tie rods, Cognito braces, Isspro boost and digital EGT, S&B intake, UDP Cat adapter, Air Dog II 165, LBZ CP3, 100 gal fuel tank, 305/50r20 Nitto 420s, 20x10 wheels, MBRP 4 inch Cool Duals, Troll Performance Tuning EFI Live tuned by Kory Willis
@BIGPHILF1
BIG PHIL is offline
post #6 of 9 (permalink) Old 12-14-2011, 03:07 PM Thread Starter
So basically what does that mean, will a lift pump inject more fuel or what?
post #7 of 9 (permalink) Old 12-14-2011, 03:29 PM
Bobo
DieselX-Bob's Avatar
A duramax has a high pressure common rail pump called a cp3. It sucks fuel from the tank through your fuel lines. A lift pump mounts close to the tank and sucks fuel from the tank to provide positive pressure up to the CP3 pump through the fuel lines. It increases the responsiveness of the cp3 pump. The cp3 can build pressure in the rail faster if it has an adequate supply of fuel waiting for it at the flood gate so to speak. Without a lift pump, the gate opens and the cp3 has to wait to draw fuel into it.
EFILive tuner
DieselX-Bob is offline
post #8 of 9 (permalink) Old 01-25-2012, 07:21 AM
anybody ever try a holley black pump? and if they did what they do to install it
dennis53 is offline
post #9 of 9 (permalink) Old 01-25-2012, 07:31 AM
Administrator
jc1843's Avatar
Another plus for a lift pump-- you don't have to pump the primer when you change the filter.
jc1843 is online now
