CP3 on my LMM - Chevy and GMC Duramax Diesel Forum
post #1 of 16 (permalink) Old 12-20-2011, 05:45 AM Thread Starter
Jordo's Avatar
CP3 on my LMM
I was told if i want more power in my truck the next thing i need to add is a new CP3. So Im in the market to upgrade to a different CP3. I guess wat do I need to know about it, and wat does it really do?
Now: 08 Chev CCSB Leveled, DPF & EGR Delete, EFI Lve Kory, Banks intake, 3" Downpipe, 4" Exhaust W/Muffler, CTS2
Sold: 2011 LML Denali CCSB, 4" Flo-Pro w/Muffler, EFI Live!
Jordo is online now
post #2 of 16 (permalink) Old 12-20-2011, 05:59 AM
DirtyMaxx03's Avatar
Do you have an after market turbo? Bigger injectors? If not I would look into a turbo before a cp3. After the turbo get some nozzles. The cp3 is a high pressure injection pump it is what supplys the injectors with fuel. People usually don't upgrade the cp3 unless it isn't making pressure due to having larger injectors and running higher pulse width tunes.
Sean
2003 Lb7 2wd
Dropped
Efi Live by Rob Coddens
s472
DirtyMaxx03 is offline
post #3 of 16 (permalink) Old 12-20-2011, 06:01 AM
WishforaDMax's Avatar
someone lied to you
yep unless you are running bigger turbo and injectors then there is no reason to get a second or a upgraded cp3, you can blow the motor well before you do that lol
Names Yezin im 24 and yes i bought my truck myself
2006 CCSB 2500Hd Lt2 LLY DMax, Efi live 150hp Idaho Rob , 5in Straight Pipe 6in Black Tip:rockin, Diamond Eye Dp, Tie rod sleeves, Edge Insight cts, SDP Egr Delete Pipe, Fprv shimmed, Pcv Reroute, All On mod, Blue led's in gauges cluster, Clarion Nx700, 8000k HID's highs/lows/fogs, Rbp Locking Fuel Door, Recons with Led Reverse lights
Name is Sharks06LLY on Duramaxdiesels.com
WishforaDMax is offline
post #4 of 16 (permalink) Old 12-20-2011, 06:03 AM
Banned
You have way more mods to go before you need a modded cp3. A stock cp3 is capable of produceing 650 rwhp with an aftermarket turbo. I would go that route, a stock fuel system can drastically ovefuel a stock turbo anyway so why add even more unuseable fuel. Plus, once you add fuel you had better have 10,000 set aside for an engine build and already have a short block sitting in your garage. Because once you add fuel (pump/injectors) it's a ticking time bomb......................
smokinlmm is offline
post #5 of 16 (permalink) Old 12-20-2011, 06:08 AM
MudDoc's Avatar
this^
2013 Huffy Ultimate Spiderman bicycle
baseball card in back wheel mod
TRAINING WHEELS OFF!!! 09-22-13
Streamer handle mod
Saving for front basket
MudDoc is offline
post #6 of 16 (permalink) Old 12-20-2011, 06:11 AM
rebpdt's Avatar
i wouldnt touch the cp3 - if you want power, make sure you can hold it i.e. get your trans built then you can get a lot more out of your tuning and go from there
CCSB LB7 4x4
rebpdt is offline
post #7 of 16 (permalink) Old 12-20-2011, 06:14 AM
Originally Posted by MudDoc View Post
this<
FIXED IT FOR YA ask raptor jesus he knows all
post #8 of 16 (permalink) Old 12-20-2011, 06:14 AM
Banned
I just noticed he dosen't have a built trans.........................
OP, you don't even know what a big EFI built trans tune can do yet...............
Get your trans built next..................................
post #9 of 16 (permalink) Old 12-20-2011, 06:42 AM
Word Up
cainer70's Avatar
Send a message via MSN to cainer70
Like all the guys have already said..... You have about another 6000 bucks minimum to spend in mods before you need to be thinkin about CP3's and all that good stuff.
LMM Twinz N sum shyt ATP Tuned
02 LB7 to be EFI'd this week.
cainer70 is offline
post #10 of 16 (permalink) Old 12-20-2011, 07:37 AM Thread Starter
Jordo's Avatar
Yeah I'm getting a sun coast GDmax put in this spring then injectors. Well don't want a time bomb that's for sure. So built tranny then just bump my Efi numbers up?
Jordo is online now
