Xx fuel system problems - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 03-17-2012, 04:17 PM Thread Starter
Texas Wallbanger's Avatar
I have the XX FUEL SYSTEM installed on my truck and right after I put it on I started having to prime the system almost every time AFTER I had been pulling hard. This is the only time it does it! Anytime I have more than 20 k behind me it has to be primed. I will pull let the Turbo cool, shut it off, then it will start up and run for about five seconds then shut down? We are at a loss for answers other than the 2 micron filter is just not letting enough fuel pass by or causing some kind pressure build up then sucking back. THIS ONLY HAPPENS UNDER LOAD AND REALLY JUST AFTER 20K . ANY IDEAS?
I posted some pictures of BOTH oil/fuel systems. I'm a bit nuts about this problem so again any ideas are welcome.
J.B.3
2009 3500 LMM DRW LTZ
Downpipe <> "Clean" Exhaust <> AFE Intake Stage 2 <> PPE Deep Tranny Pan <> TransGo Jr. <> PCV Reroute <> Resonator Plug <> <> Amsoil By-Pass <> Synthetic Fluid Everywhere <>. Auxiliary Fuel Filters 2 cat filters 1R-0749 & 175-2949 <> Rear Air Bags <> LED fogs & rear work lights <>6000 lumens Drive lights<> Pillar gauges <> Debadged <> full front bumper replacement <> <> stock Fuel Filter replaced w/ 1r-0750 or 0749 <> EFI LIVE from ATP by Rob <> Michelin Green X<> Kennedy Lift Pump <>Custom Flatbed<>Edge CTS gauges <> Built tranny-alto clutches, heavy duty Precision TC, new tranny lines-solenoid valve body, Mishimoto all hoses and boots, Rancho shocks
Texas Wallbanger is offline
post #2 of 6 (permalink) Old 03-17-2012, 04:28 PM
blaineGMC's Avatar
You likely need a fuel filter head rebuild kit. Does your truck do the same thing when your parked on a hill with the front of the truck towards the top of the hill?
Blaine
04 LLY Suncoast/Precision ML by me. Tuned by Rob.
AFE, MBRP, Mag-Hytec, Merchant Automotive, SSBC, Bilstein
For EFI Live go to:
blaineGMC is offline
post #3 of 6 (permalink) Old 03-17-2012, 10:40 PM Thread Starter
I live in Texas man .....never really had a chance to text that. But i will look for a hill to test this on.
J.B.3
post #4 of 6 (permalink) Old 03-18-2012, 01:19 AM
rittenhouse_21's Avatar
do you have a lift pump? that might cause the issue the cp3 prolly cant keep up with what is being demanded.
01 dmax
rittenhouse_21 is offline
post #5 of 6 (permalink) Old 04-19-2012, 03:55 PM
Texas Wallbanger,
Try calling XX-Fuel Technical support in between 8Am and 5PM Pacific Time so they can help troubleshoot your issue.
Your description sounds a lot like you are sucking into the fuel supply side of the system. Re-check all your XX-Fuel fittings and connections. Check the filters for correct tightness and as "BlaineGMC" suggested, you should also check your OE filter and head assembly. Your needing to prime has nothing to do with the filters (unless loose) and everything to do with finding where the air is being sucked into your system.
ashtiani is offline
post #6 of 6 (permalink) Old 04-20-2012, 10:26 AM
Texas Wallbanger,
Just a follow up to my last post:
Try opening up the compression fittings on the fuel line. In particular, I would like you pinch the ferrule in between your thumb and forefinger and try and wiggle the ferrule. If you get any movement whatsoever, that means the compression fitting was not tightened sufficiently upon installation. Please refer back to our installation instructions and go through them again to insure a trouble free installation.
ashtiani is offline
