cognito alignment specs? - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 24 (permalink) Old 04-14-2012, 05:23 PM Thread Starter
Send a message via MSN to Cschneider_23
Hey guys I got my trucked aligned when i put my upper control arms on. But didnt have the new tires on. The new tires are 285/75 r 16 and I had the stock tires on when i got it aligned and now I'm getting bad tire scrub. I was wondering if anyone could tell me the spec to align it seeing as the place didnt give me the papers back after they did it?
2007.5 GMC Sierra LMM Extended Cab Long Bed White
4"MBRP Front and MID Pipe to 5" CAT back Magnaflow
3" MBRP down pipe
Motor OPS Auto Cal
Cognito leveling kit
285/75r16 Goodyear wrangler duratrac stock PTO reims
8.6' western v-plow, Transgo Jr shift kit, PCV delete,EGR delete
Cschneider_23 is offline
post #2 of 24 (permalink) Old 04-14-2012, 05:44 PM
turbosmoke_90's Avatar
Caster, +4.0 to + 6.0 degrees with .8 degree caster split optimal for average road crown.
Camber, 0.0 to +.2 degrees, with both sides equal.
Toe, 1/16'' to 1/8" toe in, or stock toe setting.
^^straight from the instructions.
Eddie_LLY likes this.
Greg
2008 Chevy 2500 HD ECSB 4x4 LT
MBRP 4in. down pipe back w/5in. tip
Edge Evo Race
PCV Re-route
EGR blocked
Air Lift bags
Cognito UCA's, Kryptonite tie rods, Bilstein
turbosmoke_90 is offline
post #3 of 24 (permalink) Old 04-15-2012, 12:20 PM Thread Starter
Thanks
3" MBRP down pipe
Motor OPS Auto Cal
post #4 of 24 (permalink) Old 04-17-2012, 04:42 AM
The caster split is very important so make sure to get a spec printout of before and after the alignment.
MTL_Dmax is offline
post #5 of 24 (permalink) Old 04-17-2012, 05:28 AM
Varty Yo's Avatar
3 times ive had mine aligned to factory specs and have had no issues. The one time i tried the cognito specs the tech said he couldnt get them to it. Very close but couldnt do it. I just get it done now to factory specs
2006 LBZ
Mike L Stage Awesome!
Airdog2 165, 5" MBRP Turbo back
EFI Live tuned by Idaho Rob, DSP5, ATP
Cognito set at 8" Nor-cal Truck
Fox 2.0 shocks all around, Deaver 6" springs
SS idler support/ Rare parts tie rods
37x13.50x20" toyo MT's/ XD Hoss wheels, Fuel Octanes
HID's All on mod/ AMP reaserch steps
Varty Yo is offline
post #6 of 24 (permalink) Old 04-17-2012, 06:07 AM
Do you have stock control arms or Cognito control arms on your truck?
If you have the Cognito's, is the ball joint mounted above or below the arm?
MTL_Dmax is offline
post #7 of 24 (permalink) Old 04-17-2012, 09:15 PM
Varty Yo's Avatar
cognito with ball joints under
2006 LBZ
Varty Yo is offline
post #8 of 24 (permalink) Old 04-18-2012, 04:31 AM
Not sure what's going on there then because that should work with the Cognito alignment specs.
MTL_Dmax is offline
post #9 of 24 (permalink) Old 04-18-2012, 05:27 AM
Varty Yo's Avatar
yah i know. The tech said he would have to drill out the cams to get it to work. I just get it done to stock specs.
2006 LBZ
Varty Yo is offline
post #10 of 24 (permalink) Old 04-18-2012, 05:53 AM
mxhead6.6's Avatar
how'd you get away with mounting the balljoint on the bottom? mines mounted on the top, and i called cognito and they told me you usually only mount the balljoint on the bottom if your running there 9-11 cognito kit..
2006 silverado 2500hd loaded,blue LED conversion, cobalts, CTS,6'' skyjacker, softride springs
mbrp down pipe, 4'' straight pipe, 7''mbrp stack,
EFI live DSP5
Ignited 8000k low beams, highbeams, fogs.Banks ram air,bushwaker fender flairs,35'' Nitto Mud Grapplers
RBP 18'' 94r's, RBP RX-2 running boards, RBP RX HD Grille,BD turbo gaurd,Airdog2 165,Longhorn Fab Shop trac bars,alpine 7'' double din, 2 Type S's under the rear seat,trainhorn
Tranny and spinny thing to come!
mxhead6.6 is offline
