| Performance Upgrades Discuss what Intakes,Exhaust,Fuel System,Programmers,Tuners,&Trans. are right for you. |
| Banned | Fluidampr Install/Results LMM Wanted to share my results after installing a Fluidampr viscous harmonic damper part # 830111 on my 2008 LMM Duramax. Install is very straight forward and took about 1 and 1/2 hours to complete. Tools needed: Fan clutch removal kit Body clip tool or pick + small flat screwdriver Lisle Duramax flywheel locking tool(comes with damper bolt socket) Large steel 4ft cheater bar! Eat your wheaties and be at least 200lbs or you will have trouble. 3/4 breaker bar (1/2 will snap). 13mm short socket for 3 fan guard bolts Bar stock steel to lock water pump pulley if LMM. Surpentine removal kit or 1/2 breaker bar. **** Make sure you trim the lower fan guard as it will rub on the front of the damper. This needs to be added to the instructions! This essentially goes the same as a water pump Tear down with exception of pump removal (unless you are ultra anal).Install flywheel locking tool. Remove old damper and clean crank snout with Brakleen. You will re use the factory damper bolt. Lightly coat the snout with anti seize. Guide the fluidampr on making sure to align the keyway. Push until the damper seats all the way back on shoulder of crank(you will hear a thud when it is seated. Install bolt and torque to 74 ft lbs. Now mark the bolt so that you know when it has been turned 105 degrees as per Fluidampr's instructions. Now install belt, fan assembly and button up the top shroud. I always disconnect the battery's whenever I do any engine bay work. VERY IMPORTANT!!!!! REMOVE LISLE FLYWHEEL TOOL. If you try to start prior you will cause damage to flywheel and starter. Double check everything and start to check operation. ** please note this is only for reference. Always double check manufacturers written directions and consult a professional if you are not a proficient mechanic. ![]() ![]() ![]() ![]() ![]() ![]() Results: All I can say is WOW! My LMM sounds like a LML. The engine vibrations have been cut in half and power seems up a little(might be psychological). But vibration and sound are dramatic. Even the transmission seems to shift a bit more smoothly. Overall I am very impressed. Keep in mind that my truck is low mile and mostly stock. For power add on's these shine even more. This technology has been used in big rig over the road diesels for years, and I can see why! Any questions please feel free to ask. Last edited by AZFIREGUY79; 01-13-2013 at 09:54 PM. |
| Junior Member Join Date: Oct 2012 Location: Springfield, IL
| Couple questions because I'm curious... What made you do this mod to begin with? And did you reuse the factory crank bolt or install a new one? Thanks for sharing, I thought my LMM was pretty quiet for a diesel already. Good to know it can be improved!
__________________ 2008 Sierra 2500HD | MPI Twins | Banks Intercooler | PPE Manifolds | PPE Uppipes | Magnaflow 4" Exhaust | Tuned by Rob @ ATP | | BigDipper Trans | Suncoast 1056 Converter | MikeL. Tranny Cooler | | AirDog 2 Liftpump | BigDipper 30 over injectors | | DMaxStore Frontend Kit | Wilwood 6 Piston Brakes | Cognito Upper A-Arms | Traction Bars | Mag-Hytec Diff Cover | | HID's | Recon Taillights | Recon Cab Light | | Black Suede headliner | Lockpick Gen 6 | |
| | eBay Motors #3 (permalink) | |
| Banned | Quote:
Regarding the crank/damper bolt, I re used the factory one as per recommended by tech at fluidampr. Really no reason to replace as I'm pretty confident it's not a TTY. Last edited by AZFIREGUY79; 12-11-2012 at 12:25 PM. | |
| Sounds like you did quite a bit of research before your purchase, and you knew exactly what I was wondering about the crank bolt too. The torquing method sure sounded like a tty bolt, and with the stuff I'm familiar with its kind of a not-so-great idea to reuse those. Sounds like that's not the case here. |
| Banned | Quote:
Also, GM/ISUZU's torque spec has been 74 ft lbs plus 90 degrees for quite some time. They released a TSB stating new recommendation is 105 degrees which fluidampr will change in there instructions. If you have installed at 90 degrees that is sufficient and DOES NOT need to be re done. I spoke with fluidampr engineer who backed this up. Last edited by AZFIREGUY79; 12-11-2012 at 12:37 PM. | |
| Banned | Just wanted to report back after some testing. Have had the truck up to about 80 MPH and its very smooth compared to before. My wife asked what I did to the engine after driving it. She didn't think it could get much more quiet, and stated to her it's as quiet as a gas motor in her friends Tahoe lol. I plan on removing my allison in a few weeks to upgrade it for my eventual duramaxtuner SPADE. Not going to roll the dice on a stock converter and C3 clutch issue. I just wanted to thank IVAN over at Fluidampr/Vibratech for making a truly impressive damper. It has exceeded my expectations and will compliment my future HP upgrades nicely! |
| DuramaxForum Veteran Join Date: Jul 2007 Location: ObamaNation-Under the Dictator's rule
| Nice writeup, thanks for sharing. It's amazing how a dampener can alter how a diesel runs....it also does amazing things for the Ford diesels. .
__________________ Ham Radio= Global communications without airtime fees My Antenna-SteppIR Si Vis Pacem, Para bellum !!!! ======================== 07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod) --EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo --SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe --AMSOIL Synthetics and filtration bumper to bumper, including Bypass --DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs --PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes --Danville 3" Y Bridge and big air intake kit / EGR delete |
| Senior Member Join Date: Aug 2011 Location: Jersey
| Nice write up. Thanks
__________________ 2006 Chevy Silverado ..LBZ..mbrp 5" turbo exhaust (no muffler or cats) modified stock air intake, EFI by Kory Willis, Big Dipper stage IV trans, Precision ML, Pump rub fix, Alligator trans lines, Autometer guages, Airdog II-165, Ready Lift leveling kit, 285/75 Nitto Dune Grappler, Bilstein shocks, Cognito idler and pitman arm braces, PPE tie rod sleeves, fingerstick, blocker plate, pvc reroute,air intake regulator blocked, Banks boost tube, All Amsoil fluids |
| Banned | Thanks guys! |
