Throttle body Spacers for 2011 Duramax - Chevy and GMC Duramax Diesel Forum
Old 12-26-2012, 07:17 AM   eBay Motors  #1 (permalink)
I have been trying to see if adding a throttle body spacer will actually add a bit hp and add the 2-4mpg which they say they do, anyone with knowlege know the truth?
I do a ton of driving and would like to gain a few more mpg if possible, but I'd hate to waste my money on something which is a total farse, & since a ton of people on the site are very mechanically inclinded, something which I am not, many of you should know, hopefully anyway.
any and all help in this regard would be a great help, thank you.
PS, I am also kind of interested in the Air Dog system, and if you happen to know about the advantages to this, i'd also appreciate your help in this matter, although I am now going to do some searching in here about this system.
My main question is about the throttle body spacer as I couldn't find anything on here thus far, but I am going to continue looking at both of the above.
Again, thank you
Brand new 2011 Chev Silverado LTZ Duramax 4x4 Z71 C/C...Black...air raid cold air in take, afe exhaust, h&s tuner, by-passed stock exhaust and def fluid...sunroof...nav...& all the other goodies nobody really needs...B&W turnover ball hitch...headache rack...HID headlights & fog lights...6" running boards...snow stage 3 system
08 Chev ex-cab 2500 Duramax 6.6L turbo, B&W turn over ball hitch, head ache rack, side step bars
Air Raid air-intake, Titan Fuel tank, EFI Live w/exhaust brake, Edge Monitor, Bilstine Gas Shocks, Heavy duty brake pads and rotors, Magnaflow DPF Pro Performance Exhaust, XM Satelite Radio, Garmin GPS w/Oiltrax mapping software
Rdubb is offline   Reply With Quote
Old 12-26-2012, 07:24 AM   eBay Motors  #2 (permalink)
Some Newfie with a dmax
Brennan's Avatar
If you could find a throttle body spacer for a duramax, where would you put it?
06 lly,
Black,
Levelled,
Efi by rob,
5"
Etc.
Brennan is offline   Reply With Quote
Old 12-26-2012, 07:28 AM   eBay Motors  #3 (permalink)
Varty Yo's Avatar
You know ou drive a diesel right?
2006 LBZ
Mike L Stage Awesome!
Airdog2 165, 5" MBRP Turbo back
EFI Live tuned by Idaho Rob, DSP5, ATP
Cognito set at 8" Nor-cal Truck
SS idler support/ Rare parts tie rods
37x13.50x20" toyo MT's/ XD Hoss wheels, Fuel Octanes
HID's All on mod/ AMP reaserch steps
Varty Yo is offline   Reply With Quote
Old 12-26-2012, 07:36 AM   eBay Motors  #4 (permalink)
Vrabel's Avatar
You should get every part advertised to save fuel. Before you know it, you'll be taking fuel out of the tank to make room for more saved fuel.
2001 CC/SB 4WD EFI Live DSP 5, LBZ Short Block, Cut LB7 Pistons,keyed crank and cam, balanced,LBZ Intake Runners with RDL Shorty Y-Bridge, EPR Twins, Big Dipper 40% overs, MBRP Cool Duals, LBZ CP3, ADII, BD Manifold, C2 Gauges, H2 Wheels, Cognito Sleeves and Braces, Hids-Hi-Low-Fogs.
Sheet Metal Workers Local #22
If it's not made in America, YOU paid too much!
Creatures of The Night Performance and ProFab Performance
Vrabel is offline   Reply With Quote
Old 12-26-2012, 07:38 AM   eBay Motors  #5 (permalink)
Pat H's Avatar
Don't forget the magnet on the gas doors to suck out the negative electrons in your fuel
2010 Chevy 2500HD CCSB LMM
A few things here and there installed
Originally Posted by danhr View Post
well you have reduced power..... you fix it by adding more power
Pat H is offline   Reply With Quote
Old 12-26-2012, 08:55 AM   eBay Motors  #6 (permalink)
FATBOY666's Avatar
When you do the throttle body spacer do you have to upgrade from a 1/2" kabibble to a 3/4"?
2006 chevy lbz CCSB LT3
4" turbo back mbrp
3" mbrp downpipe
s&b cold air
kennedy diesel egr block
Black american racing atx mojave 16x8 wheels
285 nitto terra grapplers
dsp 5 tunes by idaho rob
autometer c2 egt and boost gauges
flipped trans cooler
More to come...
FATBOY666 is offline   Reply With Quote
Old 12-26-2012, 09:06 AM   eBay Motors  #7 (permalink)
mackyoudip's Avatar
I didn't know dmax's even had throttle bodies..
And they don't do shit to gassers either!
Mack: LMM.
mackyoudip is offline   Reply With Quote
Old 12-26-2012, 09:30 AM   eBay Motors  #8 (permalink)
TakeEm's Avatar
The LMLs have a "throttle body". Pretty sure it is for controlling vacuum in the intake for emissions/EGR.
Caleb 22
2007 LBZ CCSB S475/stock Wehrli Twin Turbo Kit/Suncoast Built by Dmitri Millard
EFI Live DSP5 by Duramaxtuner.com
5" DE, rerouted, debadged, demolded, 18X9 BMF Novakanes Stealth wrapped with 285/65/18 Nitto Trail Grappler MTs, 45 gallon transfer flow replacement tank, Amp power steps, All Season bulletproof trans/power steering line kit, Airdog II 165, Nicktane with Cat filter, Edge Insight CTS with pyro
Big thanks, Duramaxtuner.com & Willie @ Synthetic Motorsports
TakeEm is online now   Reply With Quote
Old 12-26-2012, 10:14 AM   eBay Motors  #9 (permalink)
mike diesel's Avatar
Please post the link to this supposed throttle body spacer for a duramax
05 lly
EFI Live
4094 vvt
Built Trans
BT Lockup Box
Supporting Mods
mike diesel is offline   Reply With Quote
Old 12-26-2012, 10:30 AM   eBay Motors  #10 (permalink)
dirtylb7's Avatar
X2 On what mike said.......
07 ecsb lbz with .................
dirtylb7 is offline   Reply With Quote
