suggestions - Chevy and GMC Duramax Diesel Forum
Old 01-02-2013, 06:34 PM   eBay Motors  #1 (permalink)
suggestions
I am new to the site and i was wonderin what mods i need to do to my truck. Its a 02 chevy 2500hd crew cab and I pull a trailer a lot and what size injectors do i need i was thinkin about 100horse but idk. and what would be the best box or efi would be best. its a bonestock truck now.
jmurley is offline   Reply With Quote
Old 01-02-2013, 06:48 PM   eBay Motors  #2 (permalink)
TakeEm's Avatar
First off, why are you wanting bigger injectors?
Secondly, what are your plans with this truck. If it is strictly for towing you want to keep the power stock, add exhaust and an intake.
Caleb 22
2007 LBZ CCSB S475/stock Wehrli Twin Turbo Kit/Suncoast Built by Dmitri Millard
EFI Live DSP5 by Duramaxtuner.com
5" DE, rerouted, debadged, demolded, 18X9 BMF Novakanes Stealth wrapped with 285/65/18 Nitto Trail Grappler MTs, 45 gallon transfer flow replacement tank, Amp power steps, All Season bulletproof trans/power steering line kit, Airdog II 165, Nicktane with Cat filter, Edge Insight CTS with pyro
Big thanks, Duramaxtuner.com & Willie @ Synthetic Motorsports
TakeEm is offline   Reply With Quote
Old 01-02-2013, 06:52 PM   eBay Motors  #3 (permalink)
Cknight199's Avatar
We classify injectors by % over stock. Hp is for ford and dodge boys
2006 LBZ CCLB DRW
Suncoast Trans w/ 1056
Billet Garrett 4094
BTLockup Box
Built Front End
Some More Stuff
EFI Live by Starlite Diesel
Fastest 1/4 yet: 13.606 (fourth time down the track)
Cknight199 is offline   Reply With Quote
Old 01-02-2013, 06:53 PM   eBay Motors  #4 (permalink)
baconstruction's Avatar
take some time and read through some posts. everyone has their own opinion on what they do or what is best. This is a great site for learning the difference between mods. If you are new to the diesel world do some searches before you make changes. It is easy to put power to the truck but hard to fix when you do it wrong
05 lly cc, afe turbo inlet, blocker plate, efi dsp5 by nick (duramaxtuner.com)
baconstruction is offline   Reply With Quote
Old 01-02-2013, 08:47 PM   eBay Motors  #5 (permalink)
im looking for more power and better fuel milage cause stock just dont cut it.
Old 01-02-2013, 08:51 PM   eBay Motors  #6 (permalink)
I pull a 35 ft trailer with 18 rolls of hay and barely have enough power to pull over hills
Old 01-02-2013, 08:54 PM   eBay Motors  #7 (permalink)
TakeEm's Avatar
Your asking for trouble by adding power while towing that much weight. Your transmission is going to hate you. Your fuel mileage isn't going to be the best towing that much weight.
Do you have another truck that has towed this same trailer with load? How does it compare?
Caleb 22
Old 01-02-2013, 09:14 PM   eBay Motors  #8 (permalink)
yamaha181's Avatar
you dont need to put in bigger injectors. stock injectors can make 500-550hp with good tuning. With the lb7 the injectors have been know to be a very common failure. but you will blow through a tranny towing that much weight with 50-90 horsepower over stock.
07.5 GMC LMM CCSB 6"lift, H&Sblack maxx,dpf delete and straightpiped, pcv reroute, egr blocked, fprv shim kit, bilstein 5100's and rear bags, custom traction bars, 35" nittos, 20x10's.
SOLD-lb7 ECSB lifted w/efi live
yamaha181 is offline   Reply With Quote
Old 01-03-2013, 09:57 AM   eBay Motors  #9 (permalink)
i had a 96 dodge with the pump turned and it done about the same.
