2013 Duramax upgrades - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 11-21-2013, 08:43 AM Thread Starter
What would u guys recommend for upgrades for my 2013 Dmax without taking the emissions off. I was wanting to do something to get better sound and performance. Thx in advance for the help
farmboy222 is offline
post #2 of 7 (permalink) Old 11-21-2013, 08:48 AM
DURAMAXED OUT's Avatar
sound and performance only comes from DPF delete. FASS lift pump is a good start just for added filtration and less water in fuel.
2013 LTZ CCSB Z71 4x4,
PPEI SOTF tunes, AFE true 5 inch
S&B Cold Air Intake
Rancho 4in lift 2.5in rear
Alligator Resonator Delete
FASS 150 Lift Pump,
Isspro EV2 Factory Match Pyro and Boost, Edge CTS
Westin MAX Winch Tray and Bull Bar w/ 30in LED bar
Badlands 12,000 Winch
Skyjacker Custom Dual Steering Stabilizer,
Firestone Ride Rite Airbags/Ride Controller
Hornblasters Conductor Series XL
B&W Turnover Ball Gooseneck and Companion Fifth 2015.5 OEM Full Function Tow Mirrors
Fog Light LED Cube conversion
35x12.5R18 with +18 offset XD riot
My Build Thread: Blue Granite LML Build Thread
Looking for Spare Parts? FS: Lots O parts and Goodies
LED Mirror Light DIY: HOW TO: LED Mirror Lights
Tow Mirror Conversion DIY 2015.5 Tow Mirror Conversion
Legal Headlight Mod DIY: HOW TO: Legal Headlight Mod for NBS Trucks
DURAMAXED OUT is offline
post #3 of 7 (permalink) Old 11-21-2013, 08:53 AM
812-200-2200
Meyerperformance's Avatar
Tuning, exhaust and lift pump like mentioned above. Great setup and will get you the sound and performance you are after.
Meyerperformance is online now
post #4 of 7 (permalink) Old 11-21-2013, 11:41 PM
OregonDuramax's Avatar
Sound-wise you'll get nothing different unless you delete the dpf. A dpf-back exhaust will be the biggest waste of money unless you absolutely hate the trumpet exhaust or plan on getting the rest of the turbo back soon. If I were you I'd do stuff like make sure all my fluids and filters are top notch, maybe stuff like a deep trans pan and/or bigger diff cover. Make your truck bulletproof. Trac bars, tie rod sleeves or new tie rods altogether. T case brace, pitman/idler brace, steering stabilizer, that kinda stuff.
2009 Silverado LMM, CC/SB, LTZ
Exterior: Nitto Trail Grapplers on KMC Misfits, Black Billet Grille, Black Bowtie, Debadged,
15% Tint, All-Lights-On Mod, Leveling Kit
Interior: Edge Insight CTS, Backup Camera, WeatherTech Floormats, 12 gauge, and a Black Lab
Performance: Straight Piped, EFILive by IdahoRob, DSP2, TransGo Jr., FASS Titanium 150, PCV Reroute, Nicktane w/ Donaldson W/S filter, PPE Ported Fuel Fitting and Race Valve, Cognito 60" Trac Bars, Pitman/Idler Braces, Tie Rod Sleeves
OregonDuramax is offline
post #5 of 7 (permalink) Old 11-23-2013, 06:18 PM Thread Starter
keep em coming guys im looking into a lot of these mods
post #6 of 7 (permalink) Old 11-23-2013, 07:30 PM
cleandirtymax's Avatar
Mbrp makes a 3" downpipe that keeps your 9th injector and all that. Ppe makes up pipes and manifolds that keep egr. S&b Intake. You can do pass side ic pipe with air horn that keeps the throttle body deal for egr and intake heater and a driver side ic pipe. All that can be done with no tunning and not completely voiding warrantee
2013 gmc sierra 2500hd
SDP 3" Y bridge, 5" intake. DRP S475/stock charger kit. fleece powerflow750 4"downpipe and charge pipes. drp driver side charge pipe, drp fuel sump
5" mbrp full dp back straight exhaust, mbrp 5-6" tip, fass150 titanium. all egr system removed. pcv re route, ppe manifolds and up pipes, custom tunes by kory, efi live
fuel throttle 20x10 wheels on 35x12.5's. zone shocks, ZONE 5" lift turned down for flat cvs.
cognito PISkit. rough country tie rod sleeves,
bds ladder traction bars, removed side mouldings. home made rbp grill, home made spyder head rack
cleandirtymax is offline
post #7 of 7 (permalink) Old 11-23-2013, 09:40 PM
BoostMe's Avatar
Just got my smog done and they don't do much other than visual of smog equipment as well as any aftermarket additions and looking for any black smoke from tail pipe, yet the tester told me next year the are going to implement a ECU history test where he said if I were to leave everything stock and went to a stock tune I'd have to run that tune for a day or longer to pass provided I don't delete anything, just making it tougher for owners wanting more from their trucks.
My list starts with the Lift Pump, FASS 150, cat filter, deep tranny pan, mag hytek front and rear with fluid changes probably to Amsoil pro lend gear lube additive to both.
2011 Silverado 4x4 2500HD LTZ all stock for now, added a DeeZee Platnium Series tool box, husky mud flaps, wade floor liners, Toyo Open Country RT 33/12.5-20 + Bilstein 4600 shocks.
BoostMe is offline
