Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > After Market Mods. > Performance Upgrades
Old 10-31-2009, 06:48 AM   eBay Motors   #1 (permalink)
Duramaxxed06
Duramaxxed06's Avatar
MBRP DP Install
Ok, so I've heard this install is frustrating... but I was just wondering if there are any special tools, tips or anything like that that I'll need.
Any help is appreciated.
Thanks!
2006 Duramax LBZ SLT Crew Cab 4x4 w/nav
Stealth Gray
Edge Evolution CS
Edge A-Pillar
3" MBRP Downpipe (awaiting install)
s&b CAI Dry
MBRP 4" XP Series, no cat
2" T-Bar crankage
BF All Terrains (285/75/r16)
Fold-a-cover
Peripheral iPod Adaptor
Duramaxxed06 is offline   Reply With Quote
Old 10-31-2009, 07:27 AM   eBay Motors   #2 (permalink)
CHYKYNLIPS
The install is not all that bad but adjusting the pipes can be. Its not exactly cut and dry installation due to that. I have seen the same exhaust on two similar trucks and ones tip is in a good location while the other hangs down real low and looks goofy. I had to modify a few of the brackets to get good clearance and get the tail pipe tucked up to the fender. You just have to hang it but leave the brackets loose enough to still be able to twist each section then start from the front adjusting then keep inspecting till it sits where you like it then tighten them. Just give yourself a good half day if needed and be patient.
07.5 LMM Chevy CCSB Z71
Edge Evo Race, Banks Ram Air,
MBRP 5" Exhaust W/DPF Delete
EGR Blocker Plate, PCV Reroute Mod
6" Fabtech, 18" Chrome Diamo 8 Karat
35"X12.50" Toyo Open Country M/T
Thanks to Tyler at MPF for all performance mods!
CHYKYNLIPS is offline   Reply With Quote
Old 10-31-2009, 07:33 AM   eBay Motors   #3 (permalink)
Duramaxxed06
CHYKYNLIPS,
Thanks for the heads up. I planned on installing my s&b, MBRP exhaust, Downpipe, and EGT probe today.... but the it's raining like heck, and the Georgia v. Florida game is at 3:30.... it may have to wait until tomorrow. Dang Rain!
Stealth Gray
Edge Evolution CS
Edge A-Pillar
s&b CAI Dry
2" T-Bar crankage
Fold-a-cover
Old 10-31-2009, 08:31 AM   eBay Motors   #4 (permalink)
tgreene
tgreene's Avatar
Be ready to loosen all 8 body bolts so you can lift the cab up to get the tranny dipstick tube out so you can get the old DP out....
Trevor
2007 Chevy 2500 HD LBZ,CC,SB
Thanks Jess @ Husker diesel
Installed: S&B CAI, 5" MBRP turbo back (bye kitty kitty), MBRP 3" DP, and Mag-Hytec rear diff cover, Mag-Hytec trans pan, AmsOil everything, Transgo Jr, BD Manifold, gauge's on the A-Pillar, ADII 165, EGR Blocked off, PCV Reroute
Tuned with EFI Live
I think i'm gonna need a bigger boost gauge
tgreene is offline   Reply With Quote
Old 10-31-2009, 12:40 PM   eBay Motors   #5 (permalink)
thepunisher04chev
thepunisher04chev's Avatar
All I had to do was sand the powder coat on the top tube that slides into the turbo. But it was a B***H to figure it out. Lucky I had a 3" body lift also. I just took out the inner fender wall and it was an arm reach away.
2004 Chevy Duramax LLY -EfiLive w/DSP5,Egr removed,Flex-A-Lite, Banks Intake,11" Cst Lift powder coated blue, 3" body lift, 40" Toyo's on 22" Mazzi Hulks,Fox chrome shocks, Custom 4-link Air ride rear,Amp Research Step bars,TireGate,Custom Drop Hitch, Alien Patrol Custom bumper w/10,000 lbs winch, Roll-pan, Lightforce Lights, Alpine 7" flipout dvd/moitor, with alpine 7" monitor for rear camera, Rockford amp and 12" Power Sub, Custom Rear seats split for sub box, 10 Rockford Speakers 1 T212d2 Sub, Mag-hytec Diff/trans pan. Custom billet Grille,Fender Flares,4" exhaust aero turbine muffler, Kodiak inlet pipe, Water/Meth kit. Heim Tie rods, AFE Intercooler tube, BD Downpipe, Colbalt digital gauges.
thepunisher04chev is offline   Reply With Quote
Old 10-31-2009, 12:57 PM   eBay Motors   #6 (permalink)
ibzkewl
yea i had hella of a time installing mine too, although i didnt loosen and body mouts or anything like that and i did sand the paint of the top on the downpipe, also i found that if you take alittle piece of sandpaper, fine grit and sand the flange on the turbo to get all of the soot out of there that helped alot, i could not get mine on otherwise, but after cleaning and sanding the turbo inlet it slid right in, also i got the dipstick out just fine, but it was a pain in the butt and i did have to use a very small swivvle socket and small 1/4in drive wrench...
hope all goes well....
2006 LBZ 2X4,cc/sb, 5" MBRP turbo back, MBRP downpipe, EGR blocker plate, 30% tint, linex cobalt boost/pyro guages, BD manifold, AFE intercooler pipe......more to come
ibzkewl is online now   Reply With Quote
Old 10-31-2009, 01:32 PM   eBay Motors   #7 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
Not necessary, you wern't trying hard enough.
Ive done 5 trucks with the diamond eye and never had to touch the body...
Old 11-04-2009, 07:26 PM   eBay Motors   #8 (permalink)
DeereMan
DeereMan's Avatar
Loosening the body bolts is absolutley not necessary. It took about 2 hours to install my Diamond Eye down pipe. It is a tight fit but the biggest issue was the transmission dipstick tube.
2007 Silverado Classic 2500HD LBZ
EC,SB, Allison 1000 6 speed
265's on 16x8" Eagle Alloy wheels
Blocked EGR
PCV Rerouted
BD LH Exhaust Manifold
Diamond Eye Turbo Downpipe
MBRP 4" Front Cat Delete pipe
Banks 4" Monster Exhaust
Banks 3" Intercooler Tube
50Gal Inbed Auxilary Tank
DeereMan is offline   Reply With Quote
