Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > After Market Mods. > Performance Upgrades
Old 11-01-2009, 05:45 PM   eBay Motors   #1 (permalink)
BlackBetty06
BlackBetty06's Avatar
Fuel Rail Shim
i soon will be getting a built trans and will be able to turn the programmer the whole way up. i no i need a lift pump and want an air dog. which one is best for the 06. is it the AD II?? i think that has the least install work. also will i need a fuel rail shim? if i do how much are they and how hard are they to install?? thanks
Daily Driver: 2006 Duramax Diesel (LLY) Allison 1000 6sp Black CCSB. Magnaflow true 4 inch straight pipe split to duals. Banks Ram Air intake. Edge Evolution Race BD Manifold
My First Truck: 1990 Chevy 1500 sport reg cab 4x2 5.SP Man with 4.3v6. A High Perf. 350 is in the works someday
BlackBetty06 is offline   Reply With Quote
Old 11-01-2009, 05:50 PM   eBay Motors   #2 (permalink)
treyfox11
treyfox11's Avatar
i personally like the air dog II its works great
06 lbz cc/sb ,afe intake,mbrp 4in turbo back exhaust
ppe tie rod sleeves,egr blocked
di-pricol guauges(boost and pyro)
ported fuel rail fitting,fuel valve shimmed
Air Dog II 165 lift pump
stage 5 tranny built by me
Efi live tuned
Bruce Lee can kick Chuck Norris's A**
treyfox11 is offline   Reply With Quote
Old 11-02-2009, 09:21 AM   eBay Motors   #3 (permalink)
IdahoRob
IdahoRob's Avatar
Airdog II is a good pump. The fuel rail shim isn't mind numbing, just can be a bit of grunt work.
2007 LBZ Daily driver, single stock cp3, stock engine 11.70 @ 115mph on #2, 677 HP
2002 LB7 Fun truck 9.801 @ 139+MPH on #2 fuel only
EFI Live, Suncoast Dealer, Dmax Hotrod Parts
Adrenaline Truck Performance 208.484.3670
IdahoRob is offline   Reply With Quote
Old 11-02-2009, 05:49 PM   eBay Motors   #4 (permalink)
BlackBetty06
what is the shim exactly does it get inserted into the fuel rails??
Old 11-02-2009, 05:55 PM   eBay Motors   #5 (permalink)
treyfox11
treyfox11's Avatar
there is a valve in the end of the fuel rail on driver's side . you remove this take it apart and install shims then put put it all back together
Efi live tuned
Old 11-02-2009, 06:03 PM   eBay Motors   #6 (permalink)
BlackBetty06
okay thanks, doesnt sound too bad, is it needed for the edge evo race. it says something about it in the literature that came with the unit
Old 11-02-2009, 06:18 PM   eBay Motors   #7 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
get the LP, run your truck and see if you are popping a low fuel rail code. no sence in doing all that work to your fuel rail if you arent losing pressure.
