fuel pick up - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 01-05-2011, 05:30 PM Thread Starter
fuel pick up
i wanted to install a lift pump along with a fuel tank pick up. for a lift pump i was going with an air dog 2 but i was unsure of a fuel tank pick up to go with. any sugestions?
2002 chevy duramax. tuned by brayden fleece, 68 mm cheata turbo, modded lbz cp3 pump, injectors, lift pump, suncost stage 5 trans, cogneto front end, pro comp ladder bars, sitting on KMC XD 20s rapped in 36 inch terra grapplers.
ares21566 is offline
post #2 of 12 (permalink) Old 01-05-2011, 05:34 PM
like a Ninja
guytonLBZ's Avatar
with a ADII you really dont need one. but if you really want to do one id do a HELLMAN FUEL SUMP...thats what i did. not a bad install either. just the filler neck can be a bitch
Holton-22 USMC
SOLD "06 chevy 2500HD LBZ 6spd,black and blacked out, CCSB 4X4
Custom Twins, EFI by IdahoROB, built trans W/1058 by ME, 40% nozzles, PPE manifolds & Up-pipes, BD Intercooler, lowered on 20" Fuels, 6000K HIDs,
BIG Thanks to: IdahoRob, Mike L., Suncoast, BD Diesel, PPE, Fuel, S&B, Industrial Injection
Alligator Diesel Performance - 208-777-1977
guytonLBZ is offline
post #3 of 12 (permalink) Old 01-05-2011, 05:38 PM Thread Starter
i wanted to install a pick up because everytime my truck gets near a 1/4 tank it draws air, shuts off and has to be bleed. i have my bed off any way so while it was off i wanted to fix this once and for all
post #4 of 12 (permalink) Old 01-05-2011, 05:39 PM
like a Ninja
guytonLBZ's Avatar
hellman sump will do it for ya. and with the ADII itll pretty much run the tank completely dry
Holton-22 USMC
post #5 of 12 (permalink) Old 01-05-2011, 05:41 PM Thread Starter
thank you for the info i have never heard of the hellmann sump
post #6 of 12 (permalink) Old 01-05-2011, 05:43 PM
like a Ninja
guytonLBZ's Avatar
its easy to install for the most part. if you got the bed of its that much easier and you dont have to worry about droppin the tank. if youd like a quote let me know and ill see what i can do for you
Holton-22 USMC
post #7 of 12 (permalink) Old 01-05-2011, 05:46 PM
llypower's Avatar
Where the hell does that get mounted/work? I got the fass with ppe pick up kit and I still have the problem.
2006 gmc ccsb
Built frontend, s366, dsp5
2004 LLY GMC
650hp-SOLD
llypower is offline
post #8 of 12 (permalink) Old 01-05-2011, 05:49 PM Thread Starter
yeah i would love a quote. air dog 2, hellmann sump and yukon locker. also would the yukon be better than the true track
post #9 of 12 (permalink) Old 01-05-2011, 05:52 PM
like a Ninja
guytonLBZ's Avatar
gets mounted at the lowest point on the trucks fuel tank. in my case i put right behind my sending unit and it lets gravity do the work for the most part
Holton-22 USMC
post #10 of 12 (permalink) Old 01-05-2011, 06:09 PM
llypower's Avatar
in the tank?
2006 gmc ccsb
2004 LLY GMC
650hp-SOLD
llypower is offline
