Great lift pump for the $$$$$!!! - Page 16 - Chevy and GMC Duramax Diesel Forum
Old 11-21-2012, 12:53 PM   eBay Motors  #151 (permalink)
NAFLASH's Avatar
Exactly
2006 Chevy Silverado 2500HD CCSB LBZ 2wd:
EFI Live by IdahoRob|Edge CTS Insight|Holley HP150|Nicktane FF adapter|Diamond Eye 3" downpipe and 4" straight pipe|S&B Intake|Transgo Jr.|EGR Blocked|PPE Race Valve|4" CST spindle|35" Dynapro ATM's|
NAFLASH is offline   Reply With Quote
Old 11-21-2012, 12:55 PM   eBay Motors  #152 (permalink)
rebpdt's Avatar
Originally Posted by Derski69 View Post
I'm not worried about air in the fuel system. I think it's a way for people to make more money. I look at it this way the factory setup has no air filter the 6.5's don't have that problem; and if you don't run your fuel too low, I think you won't need to worry about it.
6.5's ran on a few thousand psi on the injectors. duramax's run between 23K and 26K depending on series of motor. the old 6.5's didn't need it as the pressure wasn't high enough to cause problems. the 6.6 injectors run at high enough pressure they may as well be taking a bath in a sand blaster. you want the cleanest, purest fuel you can give them
Originally Posted by TakeEm View Post
Air is one of the main causes for injector failure. Air will kill an injector just as well as dirty fuel will.
Sent from my Autoguide app.
^this
I get that. I'm just saying if you bleed it out after installing a new lift pump there isn't much way air can get back into the system without having some sort of leak.
that removes whats there while sitting still. once you move the truck, fuel sloshes around the tank and begins to bubble. ever shaken a soda bottle? that air is fed through the pickup tube straight to the injectors.
this should help explain it better
Originally Posted by NAFLASH View Post
Derski69, don't bother trying to reason with them. Yes air does hurt the injectors, but how much we'll never know because its near impossible to conduct an accurate test.
a cavitation test would not be hard to set up.
CCSB LB7 4x4
rebpdt is offline   Reply With Quote
Old 11-21-2012, 01:12 PM   eBay Motors  #153 (permalink)
TakeEm's Avatar
^ exactly. If you don't think air ever reaches these injector your crazy. I believe if trucks had air separator from the factory, the injectors would last. In a common rail truck with a HP pump & HP injectors air can be one of your worst enemies. It is definitely not a way to just make more money.
Caleb 22
2007 LBZ CCSB S475/stock Wehrli Twin Turbo Kit/Suncoast Built by Dmitri Millard
EFI Live DSP5 by Duramaxtuner.com
5" DE, rerouted, debadged, demolded, 18X9 BMF Novakanes Stealth wrapped with 285/65/18 Nitto Trail Grappler MTs, 45 gallon transfer flow replacement tank, Amp power steps, All Season bulletproof trans/power steering line kit, Airdog II 165, Nicktane with Cat filter, Edge Insight CTS with pyro
Big thanks, Duramaxtuner.com & Willie @ Synthetic Motorsports
TakeEm is offline   Reply With Quote
Old 11-21-2012, 01:30 PM   eBay Motors  #154 (permalink)
NAFLASH's Avatar
Here we go again...
Old 11-21-2012, 01:51 PM   eBay Motors  #155 (permalink)
NAFLASH's Avatar
A test that air rates the fuel is easy. Running is through an injector to see how much it wears is going to give you biased results because you have no idea how much air is in the fuel or at what psi to run it through the injector. We can all agree its bad but to say its going to substantially effect injector is yet to be proven nor can it accurately be tested. In other words I AGREE but to a different extent. Look at all the dodges running Holley blue/black/red label pumps still running with a lot of miles. Once again I do agree air is bad but when bone stock duramax's getting 200,300,400k miles on factory injectors its hard to peel off 3 more bills for an airdog,FASS,etc...This is a cheap alternative,no more no less.
Old 11-21-2012, 02:15 PM   eBay Motors  #156 (permalink)
TakeEm's Avatar
We all have our own opinions. The price of one injector is enough for me to go with the better pump. To me it's well worth the extra bills for a bit better setup. I am done on this subject. I hate pissing matches!
Caleb 22
Old 11-21-2012, 02:43 PM   eBay Motors  #157 (permalink)
NAFLASH's Avatar
Amen
