Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > After Market Mods. > Performance Upgrades
Old 09-23-2008, 04:58 AM   eBay Motors   #1 (permalink)
Joe Perkins
Arrow Air filters - More air more power Discuss Here
Do you agree with this statement - discuss here
Joe Perkins is offline   Reply With Quote
Old 09-23-2008, 05:03 AM   eBay Motors   #2 (permalink)
usafracer
usafracer's Avatar
Depends. Stock sir filter systems are good up to 400-450 HP and do a better job of filtering. Cotton oil filters (k&n) are no good for diesels to many problems to go into but there have been many studies done on this just google it and you willsee what I mean.
2008 GMC Sierra Crew Cab 4X4 334 hp and 599 ft/lbs on 24 Aug 2008 at Meridian Motor Sports Meridian Idaho.
2004 CC/SB 4X4 Duramax (sold)
Old 09-23-2008, 06:40 AM   eBay Motors   #3 (permalink)
bigdaddydiesel
BigDaddyDiesel
bigdaddydiesel's Avatar
I have seen upgrade mods that you can do to your factory air box that can increase airflow, and yes it helps, but IMO you also need cooler air directed from away from and protected from the engine heat. This way the air charge through the system will provide much cooler air into the intake for better atomization. One mod to add to an intake mod to help this is to coat your boost tubes with bedliner material, it is cheap, easy and makes a noticeable difference in the EGT's as well as engine performance and efficiency.
and like usafracer said, oil filters are all bad for a diesel, mainly because th oil will get on the MAF sensor and cause problems. K&N gauze can come apart under high boost pressures.
TRUCK ONE: '03 GMC Sierra 2500HD 4X4 Ext. Cab Short Bed LB7, K&N Intk AFE Fltr, 4in exhaust, Banks Six-gun w/ power PDA and Speed Loader, FASS Fuel System, 6-Spd Manual Tranny w/ Custom Ceramic Dual Disk Clutch By: South Bend, Pyro and Boost Gauges in the A-Pillar
Old 09-23-2008, 06:47 AM   eBay Motors   #4 (permalink)
usafracer
usafracer's Avatar
I disagree with part of your statment. Cooler air has nothing to do with better atomization of fuel in a diesel. The diesel is injected directly into the combustion chamber (or pre-combustion chamber on 6.2-6.5) there for it does not help with atomization.
Old 09-23-2008, 06:54 AM   eBay Motors   #5 (permalink)
Beaner242
Beaner242's Avatar
I found a Ram Air hood that Im really interested in. Looks cool and functional but its $1500. Works with factory airbox.
08 GMC Sierra
Summit White
Crew Cab
30% Tint
Stock
Beaner242 is offline   Reply With Quote
Old 09-23-2008, 07:02 AM   eBay Motors   #6 (permalink)
usafracer
usafracer's Avatar
That is a lot a cash I would spend else where unless you are just going for look. I cant see a ram air hood doing much for a turbo vehicle.
Old 09-23-2008, 07:12 AM   eBay Motors   #7 (permalink)
Duraski
Duraski's Avatar
I might be wrong with using the term better "atomization" with the diesel. The cooler air helps to get more "air" or denser cooler air into the cylinder so more air larger explosion or power stroke more engine HP and more efficiency better economy. The intercooler on your pickup perfect example and nitrous on other vehicles of how cooler air increases HP and the cooler the air going into intercooler, the cooler the air going into the engine, so atomization may not be the most accurate term, yet thats the word that came first to my mind also.
2002 2500HD Dur/Al CC SB LS 4x4 Sprayed in bedliner, Sun Visor Star Board running boards from previous owner. Edge w/attitude is installed again.
Next Mods when I have the Cash
4" Stainless Exhaust Single Or Duals?
1967 Camaro RS 327 .30 over Holley 650, Edelbrock hi-rise, Crane Fireball level three cam(torque range 2000 to 8000rpm double bumped heads Hooker Headers 2 inch Duals and thrush turbo muffs,4 Speed Saginaw.
Duraski is offline   Reply With Quote
Old 09-23-2008, 07:29 AM   eBay Motors   #8 (permalink)
bigdaddydiesel
BigDaddyDiesel
Duraski is right, maybe "Atomization" was the wrong word, but increased cylinder pressure is a direct result of cooler air charge temps, as a result of that you get more HP, torque, mpg, etc.
Old 09-23-2008, 07:30 AM   eBay Motors   #9 (permalink)
usafracer
usafracer's Avatar
Ok that works. I just get a kick out of people who try to think of a diesel engine like a gas one. You dont contorol the amount of air that goes into a diesel you contorl the ammount of fuel. A gas engine if you lean it out to much it will get hot a diesel on the other hand will cool off the leaner it gets.
Old 09-23-2008, 08:03 AM   eBay Motors   #10 (permalink)
bigdaddydiesel
BigDaddyDiesel
as far as Ram air hoods, there are ram air hoods out there for MUCH less money... Like $5-600 that is what ram air does too, it provides a much cooler / Denser air charge by providing access to outside air as your go down the road that is not exposed to under hood temps.
