| Banks Bullet LB7 Here is a simple product for the person who has no interest in blowing smoke into the next county and uses his truck to tow or haul and wants a little more power and would like some gauges....all in one simple and small package.
The Banks Bullet has three power levels: STOCK, TOW, SPORT. TOW adds about 30 hp; SPORT adds about 60 hp. Power adjustable on-the-fly.
The Bullet is also a Digital Boost Gauge. A separate setting lets you select a boost level that will trigger the visual alarm (a red LED). Adjustable from 20-50 PSI in 1 PSI increments.
It will also display FUELING percentage. Stock is always 100; higher numbers are stock + additional fueling from Banks Bullet. (140 indicates 40% more fuel delivery with Banks Bullet.)
It can also display EGT's. The optional (included)thermocouple equips the Bullet with adjustable temp limiting control. Set the temp limit and save your engine! Fueling limits are adjustable from 800-1500° in 50° increments. Exceeding the set EGT limit by more than 50° will trigger the visual alarm.
The Bullet is the size of a standard 2” gauge, Banks Bullet can mount anywhere a gauge can go. Includes a single-gauge instrument mounting panel. An optional pillar-mount console is available.
So what you get is a small programmer that will increase your horsepower with no harm to your drivetrain with the capability of digital gauges.
The Bullet with thermocouple is $355.84 shipped to your door. |
