Old 10-05-2008, 10:14 AM   eBay Motors   #1 (permalink)
bent
Points: 53, Level: 1
Points: 53, Level: 1 Points: 53, Level: 1 Points: 53, Level: 1
Activity: 0%
question on leveling 08
I have a 08 4x4 3500 srw duramax reg cab. I can't stand how the front end is so low, I have mudflaps on the front and they rub when wheels turned on level ground. I do not want to install a lift as I use the truck to tow and work. My question is can I safely crank torsion bars and install shock extensions with out harming the halfshafts? Right now I have 3 inches difference from front to rear. I also plan on installing air bags on the rear.
bent is online now   Reply With Quote
Old 10-05-2008, 10:38 AM   eBay Motors   #2 (permalink)
rj998
Points: 440, Level: 7
Points: 440, Level: 7 Points: 440, Level: 7 Points: 440, Level: 7
Activity: 0%
rj998's Avatar
You can crank up your torsion bars and you shocks will be fine, just remember higher you go stiffer the ride, drive for a while at desired level and prob should get front end realigned after you find your level.
07 classic 4dr c/c sb black. 4" s/s straight piped 6" tip. trans go jr. by me. cal-tracs. ppe air box mod. ppe hot+2 et level 4 (225) oru leveling keys. bilistin shocks. fuel rail shim. egr blocker. pvc reroute. edge insight gauge. M/T classic 17x9 with dick cepek mud country 33x12.5x17
Best e.t. 13.95 @ 94 mph w/1.88 60 foot w/33" tires and no sleeves
Fass 150, cognito and sleeves
Next mod tranny by me,sun coast products from idaho rob
New best e.t. on level 5 300hp
13.15 @ 101 mph w/1.80 60 foot w/33" tires
rj998 is offline   Reply With Quote
Old 10-05-2008, 04:44 PM   eBay Motors   #3 (permalink)
Maverick684
Points: 3,620, Level: 25
Points: 3,620, Level: 25 Points: 3,620, Level: 25 Points: 3,620, Level: 25
Activity: 1%
Maverick684's Avatar
Yes you can crank up the bars, I would just play around till you find a good compromise between ride and height. If you do crank them up all the way eventually it will wear out the halfshafts, wheelbearings, upper ball joints etc. The shock extenders will smooth the ride out some but not all of it.
05' Dmax LLY CC SB, 6in. Fabtech with Heavy duty tie rods,
6000K HID headlights & fogs,
Upcoming mods: Lift pumps, Fully built tranny
On the Way: PPE intake manifold w/EGR delete
Maverick684 is offline   Reply With Quote
Old 10-06-2008, 09:51 AM   eBay Motors   #4 (permalink)
Nor-Cal Nick
Points: 17,261, Level: 57
Points: 17,261, Level: 57 Points: 17,261, Level: 57 Points: 17,261, Level: 57
Activity: 3%
Activity: 3% Activity: 3% Activity: 3%
Nor-Cal Nick's Avatar
Cognito/ LMM Dually (pic's & spec's)
Clink on the link to see what I did. The Cognito leveling kit is GREAT since it will fix the bad ball joint angles and also allows for better alignment. There is more upgrades I did that is not needed for just the leveling but take a look and if you need more info just ask.
2008 Chevy 3500HD Dually LTZ <<< Clink on link to see truck.
Cognito 2-3 leveling kit, HD tie rods, Steering braces, Idler pivot, Front & Rear Sway Bar, Bistein's frt & rear, Sulastic shackles, Bags, Toyo MT 295/70r17 w/2" spacers, AFE stg2, MBRP 5" turbo back w/RBP back 6" tip, EFI Live by Duramaxtuner.com, Nexus gauges, Nicktane fuel filter, TTS Dual pumps & pick up, Transgo JR, MagHytec Trans & Diff pans, Titan 62gal fuel tank, Amp boards, 8000k HID Headlights and fogs, Drawtite Sig.24k 5er.
6-7-08 “400hp Fun Tune” >> 414hp./786tq.
6-7-08 “LMM08_08_HOT_6.07.08_Highboost” >> 440hp./805tq.
Nor-Cal Nick is offline   Reply With Quote
Old 10-06-2008, 10:00 AM   eBay Motors   #5 (permalink)
Darren
Points: 852, Level: 11
Points: 852, Level: 11 Points: 852, Level: 11 Points: 852, Level: 11
Activity: 6%
Activity: 6% Activity: 6% Activity: 6%
Darren's Avatar
level
5 turns on mine took 5 min. went up 7/8" then allined for $50
toung weight makes it perfectly level.
2008 chevy 2500HD LMM white four door long bed 4x4
5 turns on tortion bars 265/75/16 toyo mud terain
Darren is offline   Reply With Quote
