Old 10-05-2008, 11:59 PM   eBay Motors   #1 (permalink)
66diesel
Points: 694, Level: 9
Points: 694, Level: 9 Points: 694, Level: 9 Points: 694, Level: 9
Activity: 0%
66diesel's Avatar
which lift kit is the best
I am wanting to put a 6 inch lift on my truck and was wondering which are the best ones. I 've checked out alot of them and my picks so far would be pro comp, fabtech, cst, trailmaster, and possibly superlift. I also need one that i don't have to cut anything on my truck if there is such a one. Please give me your opinions.
2001 GMC 2500HD SIERRA 4x4 ext cab sb
4" flo pro exhaust that duals out of the muffler.
AEM cold air intake.
Van Aaken smartbox 70 and 110hp settings
KD boost valve (just installed)
66diesel is offline   Reply With Quote
Old 10-06-2008, 06:56 AM   eBay Motors   #2 (permalink)
blackdeath
Points: 4,554, Level: 28
Points: 4,554, Level: 28 Points: 4,554, Level: 28 Points: 4,554, Level: 28
Activity: 46%
Activity: 46% Activity: 46% Activity: 46%
blackdeath's Avatar
fabtech is awesome, alot of them involve cuting the rear front diff bracket , unless u go bigger i think .. dont quote me on that . all i know is it took me 5.5hrs to put my lift on by my self with a hoist
2008 silverado dmax LTZ, aFe stage 2 ppe level 5, dpf delete, EGR block off plate , autometer gauges (cobalt) boost and pyro,, transgo jr ,, 8"fabtech, fabtech tierods, 35"nitto a/t. 5" grandrock stack kit,straight piped
2008 traiblazer ss, straight pipe , 1.5" down
blackdeath is offline   Reply With Quote
Old 10-06-2008, 07:15 AM   eBay Motors   #3 (permalink)
Duradieser01
Points: 1,142, Level: 13
Points: 1,142, Level: 13 Points: 1,142, Level: 13 Points: 1,142, Level: 13
Activity: 3%
Activity: 3% Activity: 3% Activity: 3%
Duradieser01's Avatar
I had a 6in Trailmaster on my 94 GMC, never had a problem with it, great suspension, a company installed it for me, and i believe they had to cut on the front end.
2001 Duramax, ATS E-POWER, ppe boost valve, injectors, BD coverter, stage III tranny, Air Dog 150. Fueled by VEGE
Duradieser01 is offline   Reply With Quote
Old 10-06-2008, 07:20 AM   eBay Motors   #4 (permalink)
bmos37
Points: 578, Level: 8
Points: 578, Level: 8 Points: 578, Level: 8 Points: 578, Level: 8
Activity: 2%
Activity: 2% Activity: 2% Activity: 2%
Fabtech is the way to go!
You will have to do alot of cutting with a pro-comp. If you you ever need to return to stock the pro comp will not give you the option.
2004.5 LLY,2500,CC,SB 4X4 LS,BLACK
BANKS 6 GUN TUNER W/PDA,4"TURBO BACK DUAL'S ,NO-CAT,NO-MUFFLER,BLOCKED EGR,AFE INTAKE for now,SUNCOAST STAGE IV W/1057,LINE-X BED-LINER,B&WTURNOVER BALL GN HITCH,20.IN.PRO COMP RIMS W/BF-GOODRICH-AT-325/60/20,ALWAYS LOOKING TO ADD MORE.
bmos37 is offline   Reply With Quote
Old 10-06-2008, 08:39 AM   eBay Motors   #5 (permalink)
countryredneck
Points: 1,055, Level: 12
Points: 1,055, Level: 12 Points: 1,055, Level: 12 Points: 1,055, Level: 12
Activity: 22%
Activity: 22% Activity: 22% Activity: 22%
countryredneck's Avatar
i have a 8" fabtech lift with dirt logic shock and love it!
'06 duramax, 8" fabtech lift, dirt logic shocks, 24" akuza rims, 38" kuhmo tires, airaid intake, banks 6 gun, superchip, stage 4 trans by PATC, upgraded transfer case by merchant automotive, BD exhaust manifold, straight piped stacks ordered and in the mail ---> ARP head studs, EFI live, tts lift pumps, shim kit
countryredneck is offline   Reply With Quote
Old 10-06-2008, 10:04 AM   eBay Motors   #6 (permalink)
Nor-Cal Nick
Points: 17,261, Level: 57
Points: 17,261, Level: 57 Points: 17,261, Level: 57 Points: 17,261, Level: 57
Activity: 3%
Nor-Cal Nick's Avatar
All the IFS lifts must cut atleast one mount off your frame to clear the diff.
These 2 kits are whats called UCA drop style kits and will demand the most cutting and harder to return to stock.
-Pro Comp
-CST
These kits are "Spindle" kits. The retain the fatory UCA position and has less cutting. Spindle kits are also nice for the fact that they increase the spindle ball joint span over stock and since you are installing larger tires this helps reduce ball joint wear because of less levearage.
-Fabtech
-Trailmaster
-Superlift
Now out of spindle style kits on the market I really like the Cognito Motorsports HD lifts for the reason they are only CHevy/GM lift mfg. They have the most upgrades on the market that will fix all the common wear problems. Today it's not the lift foundation that have problems it is the other factory components that can't take the stress of the larger tires and Cognito either self projects less stress with the lift or has a upgrade to change a weak OEM point to a stronger product.
You can read more about the Cognito lift kits at this link:
Cognito Motorsports Lifts
2008 Chevy 3500HD Dually LTZ <<< Clink on link to see truck.
Cognito 2-3 leveling kit, HD tie rods, Steering braces, Idler pivot, Front & Rear Sway Bar, Bistein's frt & rear, Sulastic shackles, Bags, Toyo MT 295/70r17 w/2" spacers, AFE stg2, MBRP 5" turbo back w/RBP back 6" tip, EFI Live by Duramaxtuner.com, Nexus gauges, Nicktane fuel filter, TTS Dual pumps & pick up, Transgo JR, MagHytec Trans & Diff pans, Titan 62gal fuel tank, Amp boards, 8000k HID Headlights and fogs, Drawtite Sig.24k 5er.
6-7-08 “400hp Fun Tune” >> 414hp./786tq.
6-7-08 “LMM08_08_HOT_6.07.08_Highboost” >> 440hp./805tq.
Nor-Cal Nick is offline   Reply With Quote
Old 10-06-2008, 10:54 PM   eBay Motors   #7 (permalink)
66diesel
Activity: 0%
66diesel's Avatar
looks like fabtech then
Thats all good to hear now i just need find someone close by that sells them.also wondering how bad did it affect the fuel mileage? Hopefully no more than 2mpg under normal driving.and how much did your rims cost blackdeath?
Old 10-06-2008, 11:25 PM   eBay Motors   #8 (permalink)
08DMAXX
Points: 365, Level: 6
Points: 365, Level: 6 Points: 365, Level: 6 Points: 365, Level: 6
Activity: 5%
Activity: 5% Activity: 5% Activity: 5%
08DMAXX's Avatar
Love my Fabtech! I lost about 2-3 mpg.
08 2500 Crew Cab 4x4
6" Fabtech Lift Kit
18" Moto Metals
Mickey Thompson ATZ 35x13.50's
Stainless Running Boards
PCV Reroute & Resinator Block Off
Coming any day: Edge Juice W/ Attitude
Full Throttle or No Throttle!
08DMAXX is offline   Reply With Quote
Old 10-07-2008, 06:29 AM   eBay Motors   #9 (permalink)
blackdeath
Activity: 46%
blackdeath's Avatar
i think rims and tires were 2100$
Old 10-07-2008, 09:44 AM   eBay Motors   #10 (permalink)
Nor-Cal Nick
Activity: 3%
Not sure if you will find a local shop that sells Cognito. It is one of those brands that work great but alot of shops don't sell because it's easier to just sell the cheaper kits and compete with other shops in the area for the sale. Look on the Internet/google and you will need to have the kit shipped to you and have someone install it or do it yourself. In the end the extra effort will be more than worth it. There are alot of GM/Chevy guys on dieselplace.com that live in Canada and running these kits.
Best of luck and let us know if you need more info or help.
