Old 10-09-2008, 05:26 AM   eBay Motors   #1 (permalink)
WorkTruck
WorkTruck's Avatar
Tie Rods?
I noticed yesterday that the boots that hold the grease in the tie rod ends are broken. I've never had good luck just replacing the boots on past vehicles, so my question is when I buy new tie rods should I just get factory replacements or should I upgrade to heavy duty ones?
'07 Classic 2500HD ext. cab
nerf bars
delta diamond plate tool box
back rack
Edge Juice w/attitude
K&N CAI
MBRP 4" turbo back w/5" tip
Moto Metal 16 x 9 (hopefully 285's soon!)
04 GMC Yukon Denali
07 Honda Rancher 400 w/ITP Mudlites!
WorkTruck is offline   Reply With Quote
Old 10-09-2008, 10:45 PM   eBay Motors   #2 (permalink)
usafracer
Red trucks rule.
usafracer's Avatar
I would upgrade. The price difference is off set by piece of mind in my book
2008 GMC Sierra Crew Cab 4X4
2004 CC/SB 4X4 Duramax (sold)
Old 10-10-2008, 12:16 AM   eBay Motors   #3 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
What kind of upgrade are you looking at? A heavy duty end or the big ones like fabtech?
Anyways Id defiatly upgrade. If it doesnt replace the whole tie rod and you pull at all in 4wd Id buy a set of sleeves since you'll have the ends off and need a alignment anyways.
Jason
Old 10-10-2008, 05:14 AM   eBay Motors   #4 (permalink)
WorkTruck
WorkTruck's Avatar
I'll probably just get a heavy duty one, not the big ones like fabtech. Any suggestions on what kind to get and where to get them?
nerf bars
back rack
K&N CAI
04 GMC Yukon Denali
Old 10-10-2008, 05:33 AM   eBay Motors   #5 (permalink)
WorkTruck
WorkTruck's Avatar
Looking on the nor-cal truck site at the cognito's and it said that you need longer sway bar end links? Does anyone have any experience with this?
nerf bars
back rack
K&N CAI
04 GMC Yukon Denali
Old 10-10-2008, 10:42 AM   eBay Motors   #6 (permalink)
usafracer
Red trucks rule.
usafracer's Avatar
nor-cal nick is the man he will hook you up
Old 10-10-2008, 10:56 AM   eBay Motors   #7 (permalink)
BigGrnJeepTug
BigGrnJeepTug's Avatar
Upgrading is always the way to go but the LINKS arent the weaklink the sleeves are so, imo, i would get a factory set of rods ends and get an upgraded set of sleeves.
But it is also my opinion that any set of upgraded sleeves should NOT be made of 303 or 304 stainless steel but rather heat-treated 4340-300m chrome-moly, titanium, or a heat-treatable stainless like 17-4.
05' LLY CC/SB, PPE Standard, MBRP SS 4", BD Power Manifold, Autometer Phantom 2 Pyro and Boost, Kennedy fingered n plugged, cat grew legs, Belltech 1/3 drop, Michelin LTX M/S 265/75/16, Homemade 2-stage Water/Methanol w/ 220psi pump.
Rock it till it sounds expensive!
BigGrnJeepTug is offline   Reply With Quote
Old 10-19-2008, 05:52 PM   eBay Motors   #8 (permalink)
Nor-Cal Nick
Suspension Consultant
Nor-Cal Nick's Avatar
We have seen the Cognito HD tie rods make contact at full turn and drop out on some trucks. This is due to the large super size of the tie rod. You can add the tie rods and if it looks like they will touch then you can always order them after checking.
Shop On-Line 24/7 @ NorCalTruck.com Suspension & Diesel Performance (Visa-M/C-AMX-PayPal-We ship to Canada)
What's HOT for HD owners: Shocks / Steering upgrades / Leveling packages
Sales- Mon-Fri 8am-5pm(PST) #925-447-7800
**SEMA Crunch/I will be hit & miss next couple weeks, I will return PM's as time allows**
Nor-Cal Nick is offline   Reply With Quote
Old 10-19-2008, 10:26 PM   eBay Motors   #9 (permalink)
Durallymax
Too bad nobody makers a heat treated chromwe moly sleeve.
I cosse to go a cheapish rout with MOOG tie rods and Upstate Diesel sleeves.
Total cost was under $200
The "Last Minute Puller"
'03 GMC 2500HD LB7/Allison EC/SB 4x4
Suncoast, EFI Live, S400, Studs, Stock Motor
Badger Truck Pullers Association Member
Thanks to all of my sponsors
Durallymax is offline   Reply With Quote
Old 10-19-2008, 10:29 PM   eBay Motors   #10 (permalink)
Dmax15
Dmax15's Avatar
Where did you get that setup from? I need new tie rods, they have alot of play in them and id also like to do an upgrade with the sleeves.
2002 GMC LB7
homemade twin turbos, stock IHI over s475
EFI live tuning from IdahoRob
http://www.atptrucks.com
12.34 @ 108mph
Dmax15 is offline   Reply With Quote
