Larger Tires - Lifts - Anyone Run Larger Brakes? - Chevy and GMC Duramax Diesel Forum
post #1 of 18 (permalink) Old 12-08-2011, 04:52 AM Thread Starter
Black 2500's Avatar
Anyone running larger tires and/or lifts upgrading the front brakes to something to get more stopping power? I really noticed when I change to my 315/70/17's (34.65" tires) the braking is not nearly as good as with the 285's.
Just wondering is anyone found a good combo for rotors, pads or even calliper upgrades that works well.
2008 LMM CCSB Black on Black SLT Z71
4-6" Cognito NTBD Lift - HD Tie Rods -All Steering Upgrades - Traction Bars
Downpipe - SS Exhaust
All Season/Dirty Hooker Diesel Built Trans
EFI Live with DSP5 (tunes by IdahoRob) - AIRDOG II 165
Gauges - EDGE - INSiGHT CTS
Thanks to Tim @ TNE Diesel.
Black 2500 is offline
post #2 of 18 (permalink) Old 12-08-2011, 05:26 AM
Banned
I have never seen a set of aftermarket brakes on a duramax. Our braking system is designed to stop 17,000 pounds truck and trailer so your added 100 lbs is no big deal. I know people with 200,000 + on their original brake pads who have been running 295's the whole time, if they were over taxing the brakes the pads would prematurely wear. Spend your money elsewhere.........................
Also flush your brakes and they will work better..........................
smokinlmm is offline
post #3 of 18 (permalink) Old 12-08-2011, 05:39 AM
IGOU's Avatar
Hey smokin' My brakes have never worked worth a crap since I got my truck. Unless, I slam on 'em. Then, they will work the next several times. I noticed a small leak appears to be from booster/master cylinder area. Just a wet spot. And, doesn't appear to be from master cylinder. At least not the plastic part. It is my understanding that these brakes work off the power steering boost? I found that out when my belt broke and I lost my brakes. That really sucked. Anyway, do you think flushing would help mine? I thought I might need to get some new seals for the booster and rebuild it, but haven't tackled that yet.
Robert,
'03 Silverado, CCSB, 4WD 2500 HD,
20% injectors, ADII 165, K&N drop-in air filter,
buckstop bumper, w/ Warn powerplant winch, and PIAA fogs. Rear airbags.
'02 CCLB 2WD 2500HD
white, stock w/t w/ ZF-6 {TRADED-IN}
'15 GMC 3500 HD DRW
CCLB, 4X4 spray-in bedliner, B&W turnover, tinted tail-lights
IGOU is offline
post #4 of 18 (permalink) Old 12-08-2011, 06:25 AM
Banned
If you have never flushed the brake and power steering fluid then yes it will make a significant diffrence. The fluids absorb water and contaminates and loose the ability to proper apply the hydrolic forces needed. There are a couple threads in the DIY section on how the flush the brakes and power steering systems.
The leaky high pressure lines are just par for the course for GM, I had mine redone at a hydrolic shop with smooth crimps instead of the GM bubble style crimps which fail easily when mine were due.............
post #5 of 18 (permalink) Old 12-08-2011, 07:35 AM
IGOU's Avatar
Thank you, sir.
Robert,
'02 CCLB 2WD 2500HD
'15 GMC 3500 HD DRW
IGOU is offline
post #6 of 18 (permalink) Old 12-08-2011, 08:26 AM
mackyoudip's Avatar
The brakes on these trucks really aren't that good..
To the op,
Ssbc makes a few sets of calipers and there is a company sold on dmaxstore.com that sells a full kit with 16" rotors, upgraded calipers etc etc.
Only problem with the 16" rotors Is that you need 20" rims or taller to run them..
Mack: 2004 lb7
1960 f100 Cummapart conversion
Ex's:2006 LBZ ppe tuned
2007.5 LMM s366. 12.4@109
mackyoudip is offline
post #7 of 18 (permalink) Old 12-08-2011, 10:18 AM
oldschool
HumboldtDmax's Avatar
I will be going to the bigger brake setup in a few months
my original pads are still good but the rotors are warped badly. With my 35" tires if someone was to stop suddenly in front of me they will be my new hood ornament
2007.5 LMM CHEVY CC LT Z71
FabFour bumpers, Rancho 4in w/Bilstiens, full Kryptonite steering with Cognito braces and trac bars,35x12.5 Toyo R/T on 20x10x4.5BS KMC Monsters
[BANKS intake,dual exhaust,intercooler]Diamond Eye down pipe, AFE tube, res. plug, PCV mod, 4094avnt, 60% over nozzles, PPE race valve & fuel pickup, AirDog 150, Fitch fuel catalyst
Mike L. SCIV w/1056 C3 oiler, EFI live, Duramaxtuner DSP 5, Edge Insight, ProFab manifold/up pipes & 3" short bridge/boost pipe
HumboldtDmax is offline
post #8 of 18 (permalink) Old 12-08-2011, 10:33 AM
buildingup's Avatar
Still have factory brakes on my truck but once they wear out going to willwoods. Have the setup for the front sitting in the basement right now. Just need to buy the rear still which is another $2500...
07.5 3500 CC/LB | Cognito | Fuel off-road | Toyo | S475 SDP Twins | PPE Stage 5 | Apline | EFI Live | Extra Large Fender Mod
Sold 02 2500HD EC/SB Duramax
-EFI Live/AIRraid intake/4" dual exhaust
-6" Fabtech lift w/cognito arms/braces/tie-rods
-20x12 Fuel Hostage Black w/ 35x12.50x20 Toyo MTs
buildingup is offline
post #9 of 18 (permalink) Old 12-08-2011, 10:40 AM
oldschool
I was thinking I wouldnt need the backs because the front does most of the work. I hope I'm right, thats a lot of money for front and rear
post #10 of 18 (permalink) Old 12-08-2011, 11:33 AM Thread Starter
Black 2500's Avatar
I appreciate the fact that braking system was designed to handle the weight of the truck, trailers etc... but consider the unsprung weight we are adding by running larger rims and tires. It is not so much the 100 extra lbs of weight we need to consider, as this is insignifigant as a whole. It is the additional unsprung weight froam the larger tires adn rims which will have an adverse effect on the funtion of the brake/suspension components.
It'd be interestig to see if anyone who upgraded braking system noticed any signifigant gain of efficiency in their braking.
Like Humboldt said, with his 35's he certainly notices a difference, as do I with the 315's. Threashold braking to stop for the dork in front of you who slammed the brakes in his Corolla because he missed his turn becomes way less fun.
