Bad tie rods or wheel bearings? - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 01-31-2012, 09:44 PM Thread Starter
TXbobber's Avatar
My front end is making a humming noise mostly from the right side. I've read other threads saying to test for a bad wheel bearing to lift the truck and check for play at 6 and 12 then again at 3 and 9. I did this and I only have play at 3 and 9. Would this be the wheel bearing or could it be my tie rod?
2004 Silverado 2500HD LB7
Interior:Autometer boost gauge, Autometer EGT gauge, Batman bobbelhead
Engine: AFE CAI, 5" turbo straight pipe with 6" tip, EGR delete
Exterior: Cranked T-bars, 33" mud terrains, back rack, custom wrapped bow tie
TXbobber is offline
post #2 of 10 (permalink) Old 01-31-2012, 09:53 PM
Ask one to be one
usafracer's Avatar
To check for a tie rod you need to have the truck on the ground and have a buddy rock the steering wheel back and forth and look for play in the tie rods
Marty
2010 GMC Sierra CC SB 4X4 Cognito 6" lift and 315/70/17 ATP Tuned!!
2008 GMC Sierra Crew Cab 4X4 (wifes) Zone lift set close to 4" 305/70/17's Hankook Dyna Pro RF-10 ATM
usafracer is offline
post #3 of 10 (permalink) Old 01-31-2012, 11:14 PM Thread Starter
TXbobber's Avatar
Ok so any kind of play at the wheel assembly means bad wheel bearings?
TXbobber is offline
post #4 of 10 (permalink) Old 01-31-2012, 11:33 PM
DuramaxForum Guru
kman2468's Avatar
Send a message via AIM to kman2468
wheel bearing most likely
here is mine
it made a whine when i turned wheel to left and just driving down road it made a loud drone noise. and when turning wheel to right it got worse
Kyle
13 lml stock
sold 04.5 lly
kman2468 is offline
post #5 of 10 (permalink) Old 01-31-2012, 11:48 PM
WisconsinMAX's Avatar
I just jacked my front end up and moved my wheel side to side and watched my tie rod come out of the centerlink. That's my way to tell it was fckd :rockin
Andrew
2006 Chevy LLZ
ReadyLift|EFI Live tuned by DDP|Autometer|
AFE|MBRP|RBP|PPE|Transgo Jr|Cognito|AVS|WeatherTech
Waiting install:cab lights, building traction bars, Airdog, ATP Autocal!
Thanks ATP,ADP, & MA
WisconsinMAX is offline
post #6 of 10 (permalink) Old 02-01-2012, 12:02 AM
billkonceniii's Avatar
yeah just look at the tie rod. if its really bad you can move it with your hands
2003 256,000 miles and counting Crew Cab Dually. Efi Live by BOBO, 5 inch Exhaust, Intake, leveled, 1.5" spacers.
DRW Club #64
billkonceniii is offline
post #7 of 10 (permalink) Old 02-01-2012, 12:07 AM
But your description of the noise sounds like a wheel bearing. Easiest way to test it is to drive straight and pull hard to the left which puts the load on the passenger side and then try turning right putting the load on the drivers side. Which ever way makes the noise worse will be your bad side. One thing people say is when one goes the other is not far behind....
Andrew
2006 Chevy LLZ
post #8 of 10 (permalink) Old 02-02-2012, 08:29 AM Thread Starter
TXbobber's Avatar
Last night I lifted the truck to check it again. When I had my buddy wiggle the wheel the whole wheel assembly ( including the spindel) and the steering rack moved. From what I saw it looked like the bushings on the rack could be bad?
Any thoughts?
TXbobber is offline
post #9 of 10 (permalink) Old 02-02-2012, 08:39 AM
sillachris's Avatar
you do not have a rack all of that is suppost to move
2004.5 LLY 2500hd duramax, Autometer Pyro $ Boost Gauges, 4" mbrp straight no cat and no muff, K&N filter modded air box, Egr blocker and finger stick, AFE mouth peace, PPE fprv block, and toyo MT 33 1250 20, and leveled and finally Efi Live DSP2 by Idaho Rob.
www.NorCalTruck.com & Rigid Ind. FTW!
sillachris is offline
post #10 of 10 (permalink) Old 02-05-2012, 06:52 PM
Ask one to be one
usafracer's Avatar
If by rack you mean center link then you have a wore idler arm and/or pitman arm.
Marty
