Best Power Steering Fluid - Chevy and GMC Duramax Diesel Forum
post #1 of 20 (permalink) Old 05-14-2012, 03:30 PM Thread Starter
jaysmo13's Avatar
Question Best Power Steering Fluid
Just wondering what kind of power steering fluid everybody uses. About to change mine I'm sure the old owner never changed it. Just wanna get the best I can.
03 Silverado 2500HD CCSB "The Toy"
4 inch DP back exhaust 7 inch tip, PPE Gauges, Stinger Digital Voltage Meter, All Blue led dome lights, gauge lights, under dash, & under backseat, Smoked 8k 55w highs, lows and fogs, LED Taillights , 35x12.5x20 Nitto Trail Grapplers, 20x10 Custom XD Rockstars, AEM Bruteforce CAI, EFI Live by duramaxtuner.com, DMAXSTORE & PPE Stage 6 transmission, AirDog II 165gph
06 Dodge 2500 Cummins CCSB "The Tow Machine"
Exhaust, Cold Air Intake, Autometer Gauges.
jaysmo13 is offline
post #2 of 20 (permalink) Old 05-14-2012, 03:47 PM
eric-satx's Avatar
I just put royal purple in mine ... simply cause its the only synthetic that I can easily obtain (NAPA or Orielly's).
I've read good things about Redline and Amsoil too. Basically, most people like the synthetics. However, I think adding a cooler is probably the best way to extend the life of the fluid, pump, and hydroboost.
2007 LBZ, Tie Rod Sleeves, Pitman & Idler Arm supports, Pump Rub fix, Bilstein 5100s , Cognito UCAs, N-Fabs, Cabin Filter mod, Delayed Blower Module to dry evaporator, and a Power Steering cooler)
2006 Jetta TDI (daily driver)
eric-satx is offline
post #3 of 20 (permalink) Old 05-14-2012, 03:51 PM Thread Starter
jaysmo13's Avatar
What kind of cooler would you use if you do have one?
jaysmo13 is offline
post #4 of 20 (permalink) Old 05-14-2012, 03:53 PM Thread Starter
jaysmo13's Avatar
And how much power steering fluid do I need to fill it back up after I drain it?
jaysmo13 is offline
post #5 of 20 (permalink) Old 05-14-2012, 04:03 PM
eric-satx's Avatar
Here is the Flushing How To: <here>
As for the cooler, I just ordered a cheap one from Amazon (http://www.amazon.com/gp/product/B0006HNM66/ref=oh_details_o01_s00_i00) and will be putting it on in the next week or so . But there is actually a GM cooler for the Duramax (part # 10385584 IIRC).
post #6 of 20 (permalink) Old 05-14-2012, 04:03 PM
SoCalMike's Avatar
http://www.duramaxforum.com/forum/ho...ost-flush.html
do this.......
2007 LBZ Crew Cab 4x4
Transmission built by inglewoodtransmission.com
atptrucks.com
DMAXSTORE LML UCA GIVE AWAY
SoCalMike is online now
post #7 of 20 (permalink) Old 05-14-2012, 04:07 PM
jjr0419's Avatar
Send a message via Yahoo to jjr0419
Originally Posted by socalmike View Post
^^ x2
2008 Silverado 2500 CCSB 4x4
EFILive, MBRP 4" straight, Cognito braces, Rare Parts HD tie rods, 3" drop shackles, overload removed, 20" Helo 835, Cooper Zeon LTZ 305/50, Kenwood Excelon X996
jjr0419 is offline
post #8 of 20 (permalink) Old 05-14-2012, 04:43 PM Thread Starter
jaysmo13's Avatar
Yeah I've read that and plan on following it I just didn't know how much power steering fluid I'd need. I'm getting ready to flush and add new here in the next couple hours. Anything else that I should go ahead and do fluid wise? I already did oil. Was thinking transmission fluid and filter and brake fluid.
jaysmo13 is offline
post #9 of 20 (permalink) Old 05-14-2012, 06:03 PM
eric-satx's Avatar
If you run about 3-4 qts through there it should be well flushed.
As far as other fluids...
In addition to what you list you might consider:
Transfer Case
Front and rear differentials
Coolant flush
If you haven't already:
Fuel Filter
Air Filter
Cabin Filter (I think the '03s still had them)
Then she'll be good as new.
post #10 of 20 (permalink) Old 05-14-2012, 06:04 PM Thread Starter
jaysmo13's Avatar
Took 4 quarts for mine to run clear
jaysmo13 is offline
