Old 01-05-2009, 09:26 PM   eBay Motors   #21 (permalink)
JacktheBear3
Originally Posted by marbles72 View Post
You're moving the front of the truck up so you're losing suspension travel. isnt that what leveling will do??
Ya, man... The Cognito Upper A's take all of our desires into consideration.
They put our leveled front ends back into factory travel specs, with full camber adjustment at lift height.
It's sick how other lifts leave you at the limit, I love Cognito products.... too bad they don't love me
JacktheBear3 is offline   Reply With Quote
Old 01-06-2009, 12:11 PM   eBay Motors   #22 (permalink)
Nor-Cal Nick
Suspension Consultant
Nor-Cal Nick's Avatar
ok thanks nick ..so much info I do like that you give good feed back,now you dont mean that I cant run in 4 wheel drive your just saying dont pull a sled in 4 wheel correect??ok I will get that kit run it in thew green zone(whatever that is) and If i want to up grade the lift I already have th uca so that part is purchased,walla half way there,Im guessing in the destructions=)it states how much you can turn up your torsion bars??also if I use these shocks can they if I choose be used the for the 4-6'' liftBilstein BE5-E381.t0???
Yes all the install info will come in the kit so you are all good. Also we are a installer not just a parts shipper and offer real time install tech help to all our customers so that will help also.
If you upgrade to the Cognito 4" NON torsion bar drop kit then yes those shocks will work.
I want to exdend to you also that when you are ready to put your order together to feel free to call myself or Jeff here and we can help you.
Originally Posted by JacktheBear3 View Post
Excellent Write Up Nick !
Thank you..
Yes, add pre-load "Crank" up 2" you loose 2" of drop out. Add the Cognito UCA and gain back 2" so in the end no down travel lost.
Not sure what exactly you mean but we are there largest retailer and distributor for the Cognito product and if you need to purchase product for your business feel free to get with me and I can set you up
Shop On-Line 24/7 @ NorCalTruck.com Suspension & Diesel Performance (Visa-M/C-AMX-Disc-PayPal-We ship to Canada)
Sales- Mon-Fri 8am-5pm(PST) #925-447-7800
What's HOT for HD owners: Shocks / Steering upgrades / Leveling packages
Nor-Cal Nick is offline   Reply With Quote
Old 01-06-2009, 10:00 PM   eBay Motors   #23 (permalink)
Skinny
Skinny's Avatar
I've been looking at the Cognito 4" kit for my next project truck and have a few questions. There is no indication of track width change, do you have a spec for that? I don't want my tires sticking way out of the fender (you guys don"t have to worry about snow and slush spray down there!) I also don't want to run wider flares to compensate, I prefer a cleaner, more subtle look, just a little taller. The Cognito site doesn't have a picture of the kit, can you post one? I'm very interested in their torsion bar linkage that keeps them in the stock position, can't get my head wrapped around how that would work. And finally I would want to do the upper control arm kit with it, am I correct in assuming as long as I install the ball joint in from the top of the arm, it would stay at the 4" lift? Installing it from the bottom and tightening the keys make it a 6"? Lastly, are the Cognito tie rod ends the same as the Fabtech ones? I've seen them, just wondering how they compare. Thanks, Marc.
Soon to be looking for a 2003+ 2500HD.........
Skinny is offline   Reply With Quote
Old 01-06-2009, 10:01 PM   eBay Motors   #24 (permalink)
Skinny
Skinny's Avatar
One more question...just out of curiousity, how come you guys striped all the Weekend Warrior decals off of your trailers?
Old 01-07-2009, 08:16 AM   eBay Motors   #25 (permalink)
Nor-Cal Nick
I take it you have not looked at my site's Cognito write up?
..:: Nor Cal Truck ::.. ..:: Cognito Motorsports 4-6" Front Lift Kit ::..
Also this link is a easy way to add all the options up to see what a package will cost you:
..:: Nor Cal Truck ::.. ..:: Online Store ::..
This was the very first truck to get this NTB drop Cognito kit other than the prototype. There is a ton of info on the lift and to answer your question it has a 1/2" per side push. Very small , here is a picture onf the difference:
As for the Cognito HD tie rods they are not the same as Fab's. They come from different mfg's.
Here is a pic of them:
Old 01-07-2009, 08:19 AM   eBay Motors   #26 (permalink)
Nor-Cal Nick
When I bought my WW 5er I had another truck that had everything powder coated Red on the suspension and the trailer had Blue stickers so we took them off. Jeff (middle) just wanted a all white trailer.
Old 01-07-2009, 05:28 PM   eBay Motors   #27 (permalink)
JacktheBear3
Nick, I think you will....
Look at your calendar, we had a cold one on December 7th, it was a circus..... I told you about my love for CHAD. I will call you later this week, cause I intend to take advantage of NOR-CAL. Rock On !
Old 01-07-2009, 09:27 PM   eBay Motors   #28 (permalink)
Skinny
Skinny's Avatar
Thanks for the links, very informative and a very impressive system. Those torsion bar links blew my mind, genious. Once the Dodge goes byby and a Gm is back in my garage, I'll be giving you a call, Cheers, Marc.
Old 01-10-2009, 07:35 PM   eBay Motors   #29 (permalink)
JoshC
Hello,
Is there an additional body lift on this unit? If so, or not, please describe the lift/tire size:
Is this a leveling kit with 33" tires?
Do you have everything in stock for a stage 4 kit?
Thanks, Josh
JoshC is offline   Reply With Quote
Old 01-13-2009, 01:38 PM   eBay Motors   #30 (permalink)
Nor-Cal Nick
Originally Posted by JoshC View Post
Hello,
Thanks, Josh
Here is the spec's on that truck: Chevy Gallery Also has a couple more pic's.
Right now I am waiting for a stock order to come in but let me know and we can get you on the list and get you going ASAP.
