| Suspension&Steering Discuss what Mods for the suspension & steering are right for you. |
| Junior Member | NorCal Nick...help I would like some recommendations for setting up my suspension for sled pulling. I know about the tie rod sleeves and idler and pit-man braces, although I have wondered if HD tie rods are worth the money? I have read that 4wd boosted launches are bad for the cv's if the are not straight. I assume this is also true for sled pulling. Which leads me to believe a lift is a bad idea, but I like my 33"s. I saw a truck that appeared to be lowered at a pull a while back that did really well and wondered if that is the way to go. I have read about hard stops but I am not sure what they do. I assume it keeps your hitch height up, but I'm not sure of the advantage of this. I am in the process of installing some 2 link trac bars so I have that part figured out. Any knowledge on this subject would be appreciated. I would like to go compete in a couple of local pulls next year, and then gauge my interest in adding more mods to support better pulls. Thank you in advance for your help and any information.
__________________ MARSHALL 2007 LBZ Graystone Metallic CC/SB EFI w/DSP5 by Mark@Danville / K&N Intake w/Amsoil filter / LML DS Manifold / Allison Deep Pan / Merchant TCase / FASS 150 w/Sump / Edge Insight CTS / Rerouted, Blocked & Race Valve / Leveled & Trim Removed / 4in MBRP SS DP Back w/ 5” Black Tip / Smoked 3rd brake & Tails / 285/75/16 Cooper STT’s / MT Classics Powder Coated Black |
| Junior Member | Bump
| DuramaxForum Veteran Join Date: Feb 2010 Location: College Station, Tx
| I'm running a very close to 33" tire and I'm lowered. Leveled or lowered and you can fit good sized tires with minimal trimming of the fender wells Sent from my iPhone while cruising through wal-mart wearing my wolf shirt.
__________________ -Austin- Fightin' Texas Aggie 2001 LB7 2500HD CC/SB 2WD 5" Flo~Pro Straight w/ 7" Tip| ProFab Intake Horn |Spectre Stage-2 CAI | EFI Live w/ DSP-5 | PPE Stage IV Transmission | ProFab Downpipe | PPE Boost Valve | Holley Black Lift Pump | Intake Heater Delete | GlowShift Guages (Boost, Pyro, & Fuel Pressure) | 3" Drop Shackles | 18x9 Falken ORC 952's | Nitto Terra Grapplers 285/65/r18 | Kenwood Deck | 2 12" Kenwood Subs on 2200watts | 4 6-1/2" Pioneers (Doors) on 350watts | JML 6000k HID Lo-Hi/Fog | Herculiner Bedliner | Westin Side Steps | Ranch Hand Full Front and Rear Bumper Replacement. 546hp & 1025 ft/lbs at Lone Star Dyno, Spring Branch Tx. |
| Junior Member | Does this setup serve you well in your sled pulling endeavors?
| well i don't sled pull, i was just stating that you can still run your 33' tire if youre lowered
| DuramaxForum Veteran Join Date: Jan 2010 Location: Washington, Mi
| Many of the sled pullers run trucks with lifts without any issues. As long as your CV angles are flat or slightly negative you will be fine.
__________________ 07.5 3500 CC/LB | Cognito | Fuel off-road | Toyo | S475 SDP Twins | PPE Stage 5 | Apline | EFI Live | Extra Large Fender Mod Sold 02 2500HD EC/SB Duramax -EFI Live/AIRraid intake/4" dual exhaust -6" Fabtech lift w/cognito arms/braces/tie-rods -20x12 Fuel Hostage Black w/ 35x12.50x20 Toyo MTs |
| DuramaxForum n00b Join Date: Aug 2012 Location: Fall river, ma
| Cognito's lifts are designed to correct cv angles, are t they? So would this be better for pulling then a leveling kit if you still wanted to go up? I have a wide offset so I still get rub I.n reverse on my fenders. We've trimmed as much as we can, and my t bad are up more then half way ( I know not good, but I'll be ok for now). I want to do a set up capable of 4wd launches and sled pulling in workstock class, but also get rid of the rubbing and keep my tires ( 33x12.50R17) thoughts? I won't pull my truck untill I'm confident in my suspension and trans, so I'd like to get em knocked out this winter
__________________ 2006 GMC Sierra 2500HD LBZ -4" mbrp dual exhaust (turbo back) lml manifold, trans-go jr, efi live tuned by Idaho rob, hd hoss wheels, 17", dick cepek mud country 33's, all lights replaced by spyder projectors and led's, dsp5, k&n CAI, and some interior trim .. Oh and an airdog 165 93 Jeep Grand Cherokee - 6" lift, dc mud country 35's, s4.1 stroked with wild cam, built rubicon axles w/ front and rear lockers |
| Yes a lift would be better then a leveling kit. All a leveling kit does is turning up the torsion bars resulting in increase CV angles. Putting a true lift kit on drops the front diff X amount and lifts the front X amount. Just have to watch out though as some lifts drop the diff X amount and lift Y amount.
| Senior Member Join Date: Aug 2009 Location: Bismarck ND
| Like said before the lift will keep your cvs flat at the right setting. I would just do a 4" lift and keep it so the cv shafts are level. Do you use this truck for anything other than playing with? I ask this because i got a cousin that has a modified gas pulling truck and after a few years his frame is bending from the stresses of pulling.
__________________ 08 2500hd cc sb bw with companion, firestone ride rites, cognito traction bars, cognito uca, fox performance shocks, cognito steering braces, and cognito tierods, bfgkm2 255/80r17. Old truck 03 1500hd w4me tune, aem cai, 951 moto metal, 285/16 duratracs, bw and companion |
| I have t even pulled it yet. I want to do one maybe two pulls a year, just to show that the truck isn't all show. Otherwise, the truck is all show. Lol. Used to truck show and pull my jeep every now and then. Soon it won't even be my daily driver. More like my Harley. But I want everything done right. I have the money to do it, instead if living with it or finding quick fix. I will never get rid if this truck if I can help it.
