Lets talk low..... - Page 9 - Chevy and GMC Duramax Diesel Forum
Old 11-11-2012, 03:44 PM   eBay Motors  #81 (permalink)
macknos94's Avatar
i have about one turn more till the bolt can be removed completed maybe i'll try it tomarrow to see if it make a difference.
2004 ccsb 4x4-yup its got a lb7... for now
built tranny with all the shiny good stuff
mp8/ ppe hot+2, ppe lift pump, exaxt steering toys, plus a few other toys.
lly swap in the works.
macknos94 is offline   Reply With Quote
Old 11-13-2012, 08:00 PM   eBay Motors  #82 (permalink)
nvrplzd's Avatar
Originally Posted by lb7blksmk View Post
Thanks, it was just a quick 5 minute fix because i wanted to get out of there haha. I want to pull it off and make a cleaner bracket.
So the NBS trucks rears are way different, cause I have tons of space from the bracket still and I'm only about 1.5" off my bump stops in the rear.
Just thought that was interesting.
Tyler-
2007.5 3500HD SRW Long N' Looow
EFI by Kory Willis, Garrett, DJM, DPC, PPE, Airdog, Nitto, Profab, Airlift, Cognito.. just to name a few.
BIG thanks to Will with Troll Performance Tuning and Matt with Blackout Diesel Performance
2004.5 LLY Ext Cab 8' ~EFI, Fabtech 6" and much, much more.. SOLD
nvrplzd is offline   Reply With Quote
Old 11-14-2012, 05:30 PM   eBay Motors  #83 (permalink)
Banned
Frames are the same.
Old 11-14-2012, 05:41 PM   eBay Motors  #84 (permalink)
Alligator Performance
lb7blksmk's Avatar
Brians correct.
the reason i cut mine was due to the location of my bracket for the traction bar. I kept my bars at the same height as the frame so they were not hanging down below the frame too far.
www.alligatorperformance.com
03 LB7 EFI
David 208-777-1977
david@alligatorperformance.com
lb7blksmk is offline   Reply With Quote
Old 11-15-2012, 12:14 PM   eBay Motors  #85 (permalink)
Creepy
TheStepChild's Avatar
Bought set of 2 inch drop shackles for the van today. Blew out the back shocks so I ordered a set of those too. Probably put it all on and switch to the 265's for winter next weekend
'07 LBZ
'12 Express Van
TheStepChild is online now   Reply With Quote
Old 11-16-2012, 12:03 PM   eBay Motors  #86 (permalink)
Creepy
Shackles won't fit the van. So much for everything on the net being true
So I'll put them on the truck, but...
I saw a post from nor cal nick about dropping the back of a CC/LB and needing shims because of the 2 piece driveshaft. Asked him for clarification but nothing yet. Anyone know for sure?
'07 LBZ
'12 Express Van
Old 11-16-2012, 12:06 PM   eBay Motors  #87 (permalink)
Banned
Have a pic of the oem shackle on the van James? For just a 2-3" shackle I wouldnt see you needing axle shims.
Old 11-16-2012, 12:29 PM   eBay Motors  #88 (permalink)
Creepy
I didn't get a pic, and I just backed it in the garage won't see daylight till Tuesday. The thing looks the same as the truck, but on the van there's only 1/2" or less between the top of stock shackle and floor/body of the van. On the truck it looks like a few inches + of room between the top of stock shackle and bed of truck.
Maybe if I keep some weight in rear of van and lower rear psi I won't scrape. Or I could just move the overhead light that the van hits when backing in.
Edit. Or cut a hole in floor of van
'07 LBZ
'12 Express Van
Old 11-16-2012, 01:48 PM   eBay Motors  #89 (permalink)
Banned
Only other way I see leaving the stock shackles is to pull a leaf or overload if you havent already.
Old 11-16-2012, 02:10 PM   eBay Motors  #90 (permalink)
kawikid1425's Avatar
Dont notch the frame its not worth it! I wouldnt have bought my truck from Brian if it was C notched. DJM 3/5 kits are the best IMO. I want to 4 link mine with coil overs in the rear eventually or something cool...
kawikid1425 is offline   Reply With Quote
