Traction Bar Help - Chevy and GMC Duramax Diesel Forum
post #1 of 14 (permalink) Old 12-04-2012, 06:45 AM Thread Starter
o3gerber's Avatar
Traction Bar Help
Hey guys, i need a little help choosing the right traction bar. I have looked thru the forum but i am still a little hesitant on witch bar is gonna work for me, and i still have a couple questions. I am looking at the Cognito Economy Bars, but am not sure witch size will work best. I am deployed right now and i have a south bend clutch waiting at the house for me to put in when i get home in and with that i am gonna get a bigger tune so i am worried about some axel wrap because i have 5in blocks in the back for my lift with 35's. The truck is a daily driver and i will tow ocosainaly, and spank my girl friends mustang once and a while too (she is gonna hate that) but i am mostly concerned about witch bar will work the best because of my lift. After the tune, clutch and other things i got for the truck i should be in the high 400s and hopefully break 500hp. any help would be appricated. thanks o3gerber
2004 Silverado 2500HD RCLB LB7 With ZF-6
EFI Live by Duramaxtuner, DSP5 Switch
Banks Ram-Air Intake, 5'' Straight Pipe
South Bend DD
Air Dog 165
PPE Boost Valve
Pro Fab Intake Horn
Glow Shift Boost + EGT Guages
Zone 6in Lift
315/75R16 Baha Claw TTCs
o3gerber is offline
post #2 of 14 (permalink) Old 12-04-2012, 06:50 AM
The S.O.M.'s Avatar
I'd say get the 60" ones
2004.5 LLY ECSB 4X4
EFI Live
Danville Stg2r
Bosch Motorsport 65% overs
MA700 Trans
Lots of HSP Diesel parts!
ARP Studs
Built Front End
The S.O.M. is offline
post #3 of 14 (permalink) Old 12-04-2012, 07:22 AM Thread Starter
o3gerber's Avatar
what are the benifits of the 60 over the 50?
South Bend DD
Air Dog 165
PPE Boost Valve
Pro Fab Intake Horn
Zone 6in Lift
o3gerber is offline
post #4 of 14 (permalink) Old 12-05-2012, 05:52 AM Thread Starter
o3gerber's Avatar
bumped
South Bend DD
Air Dog 165
PPE Boost Valve
Pro Fab Intake Horn
Zone 6in Lift
o3gerber is offline
post #5 of 14 (permalink) Old 12-05-2012, 06:47 AM
corvetteandsilverado's Avatar
sub'd...also wondering about traction bars for my 6" bracket lift
10 GMC 2500 SLT LMM> 5" mbrp, EFIlive dsp5 tuned by Rob Edge, CTS insight, MBRP dp, built trans, MPI twins, FAST 150, 6" pro comp, 35" toyo MT, 22 american force SS fox shocks
05 GTO M6 SLP exhaust K&N intake for now
04 silverado DD> 4" RXC lift 33's plasti dip flat white
corvetteandsilverado is offline
post #6 of 14 (permalink) Old 12-05-2012, 09:04 AM
The S.O.M.'s Avatar
I believe the longer they are the more they will hold your axle stable
2004.5 LLY ECSB 4X4
EFI Live
Danville Stg2r
MA700 Trans
ARP Studs
Built Front End
post #7 of 14 (permalink) Old 12-06-2012, 09:46 AM
zr600's Avatar
I would get the 60" too. Thats what i have on my truck, it is just leveled though. That or give norcal truck a call and ask them.
08 2500hd cc sb bw with companion, firestone ride rites, cognito traction bars, cognito uca, fox performance shocks, cognito steering braces, and cognito tierods, bfgkm2 255/80r17.
Old truck 03 1500hd w4me tune, aem cai, 951 moto metal, 285/16 duratracs, bw and companion
zr600 is offline
post #8 of 14 (permalink) Old 12-06-2012, 02:16 PM
DaveB's Avatar
Any length will hold the axle stable. Shorter bars are used more for drag racing, such as Cal Tracs. You'll typically see sled pullers with much longer bars. Most seem to agree that around a 60" bar is good all around.
Some pictures of mine here:
PMT Fabrication. TRACTION BARS FOR DURAMAX, POWERSTROKE, DURAMAX
07 CCSB 4X4 LBZ: Danville Billet 4094 & 45% Nozzles, DSP5 by Mark at Danville, BT Lockup Box, Romeo Fab Up-Pipes, Downpipe, & 3" Y-Bridge, Banks Hotside/PPE Boot, BD Manifold, Rail Shimmed, PCV Reroute, MBRP 4", S&B Intake, Airdog 2 165, Autometer Factory Match Boost/Pyro, Suncoast GMax 6-3/Precision ML built by Riley Gullett, MA Pump Rub & TC Brace & Big Hog Customs Trans Cooler Lines.
Cognito UCA's, Rancho 9000XL's, Rare Parts HD Tie Rods, All Season Centerlink Bracket, HD Idler Support/Gusset, Russell Stainless Brake Lines, Brake Performance Dimpled/Slotted Rotors, Custom Traction Bars, Line X Xtra, 6K HID Lows and Fogs, Smoked Headlights & Taillights.
BMF 20x9 Death Metal Rehabs with 305-50 Nitto 420S
DaveB is offline
post #9 of 14 (permalink) Old 12-09-2012, 07:44 AM Thread Starter
o3gerber's Avatar
Awesome thank you DaveB, that is exactly what i am looking for, i want a good all around bar, i read a ton of stuff about them but most of it was about whats best for the strip or for pullin, couldent find what is good all around.
South Bend DD
Air Dog 165
PPE Boost Valve
Pro Fab Intake Horn
Zone 6in Lift
o3gerber is offline
post #10 of 14 (permalink) Old 12-09-2012, 08:29 AM
timwly's Avatar
I'm running caltrac bars on my lb7 with 8 inches of lift, I can really tell a difference with axle not wrapping. I would recommend getting rid of the blocks and running all spring also. But I'm not a fan of blocks either. Jmo. Stay safe my friend
Sent from uPhone
2003 LB7 / Allison CCSB Black on Black
5" straight / ported&polished turbo horn / PPE boost valve / EFI live DSP5 (duramaxtuner.com lb7 private label) / airdog 165 / bullydog GT moniter / AAM 9.25 straight front axle / 8" lift 4 link suspension in front coilovers / Custom self built setup / cal-trac traction bars / hydraulic assist steering / 20" Fuel throttle machined wheels / 37x12.50x20 Nitto teragrapplers / 10" pypes tip dumping behind axle
timwly is offline
