traction bar help please - Page 2 - Chevy and GMC Duramax Diesel Forum
Old 01-03-2013, 08:35 AM   eBay Motors  #11 (permalink)
BorderlineReckless's Avatar
Originally Posted by Cknight199 View Post
Why don't trucks come stock with traction bars? What's the purpose of axel wrap? Rather than having straight driveshaft?
they do make the ride a little stiffer, from what i understand. and there is not purpose for axle wrap lol its bad. its more of a problem on lifted trucks with blocks and under power the axle "wraps" and puts alot of bind on everything. the bars prevent wrap, but with the side effect of a little stiffer ride, rattling and a little more weight
-Trent-
2008 LMM 2500HD, MA-700, MBRP 4'', K&N cold air intake, EFI Live from Diesel Addiction, edge insight, PPE lift pump, egr blocked, 33'' Goodyear duratracs on 20" XD Misfits, de-debadged,smoked tail lights and cab lights, halo headlights, black grille, leveled with keys, B&M gooseneck hitch, air ride air bags with compressor, Alligator tie rod sleeves, PPE shim kit,Rough Country 6'' Lift Powdercoated Orange, 35w 5000k HIDs highs, lows and fogs
WAITING TO BE INSTALLED - PCV reroute, Ppe rear diff cover, inline filter kit
>>>build thread<<<
BorderlineReckless is offline   Reply With Quote
Old 01-03-2013, 08:44 AM   eBay Motors  #12 (permalink)
I hope you can got to these pics
2004.5 lly CC/SB LT white 147k : EFI Live DSP5 Tuned by Kory : Georend transmission : Stright piped 4in MBRP turbo back exhaust : Pro fab down pipe : EGR Block plate : AFE mouth piece : raptor lift pump : CAT Nicktane adapter : Rare parts tie rods : Traction bars
Dura is offline   Reply With Quote
Old 01-03-2013, 09:25 AM   eBay Motors  #13 (permalink)
mike diesel's Avatar
First off you need actual jam nuts on there, not some 1/8th" threaded piece of plate. Second off you need jam nuts on both ends. Thats your problem, get some actual jam nuts on there and it wont loosen up on you.
05 lly
EFI Live
4094 vvt
Built Trans
BT Lockup Box
Supporting Mods
mike diesel is offline   Reply With Quote
Old 01-03-2013, 09:32 AM   eBay Motors  #14 (permalink)
bturner's Avatar
What he said. That is your problem
2011 GMC 3500 SLT 4dr dually 4x4
weathgaurd tool box, bedliner, strobe kit, B&W hitch, more to come
FOR SALE. Loaded, stock 62,000 miles
2008 GMC 2500 reg cab 4x4
Need a zf6
bturner is offline   Reply With Quote
Old 01-03-2013, 09:36 AM   eBay Motors  #15 (permalink)
Ok so tighten them togather and put some good jam nuts on and i should be good to go. thanks alot guys
Old 01-03-2013, 09:37 AM   eBay Motors  #16 (permalink)
I have a set that I attached to the top of the axle. 05 crew cab Dmax. I have not noticed much in the way of a stiffer ride. But there is a world of difference in loose gravel, sand and wash board roads when running unloaded and with no trailer. My truck has no lift (stock suspension) and is used only to tow a 12,000 5th wheel.
lavarock is offline   Reply With Quote
Old 01-03-2013, 09:48 AM   eBay Motors  #17 (permalink)
rms
rms's Avatar
If you can, post a pic of them.
Does it help with ground clearance (off-road)?
2007 LBZ 4x4 regular cab
S & B Intake - Diablo Predator
285/75/16 Cooper ATP's - 8' Bedslide
Amp Steps - Bilsteins - Fumoto
rms is offline   Reply With Quote
Old 01-03-2013, 02:44 PM   eBay Motors  #18 (permalink)
Sorry I can not find a picture. I am in Arizona for the winter and did not bring my truck and trailer down this year.
But i have a post on Diesel Place Top mount trac bars?? - Diesel Place : Chevrolet and GMC Diesel Truck Forumsthat shows the bar I am using and another I would do if I was to do it again. As for ground clearance everything is above the axle. Look at post #1 that is the bar I have. I am still trying to remember where I got the bars. I did make a major modification. If you notice the pivot point is at the axle. I broke the bar a couple times. I turned the bar 180 so the pivot point is at the spring hanger where it should be. I cut a section of square tubing for the bracket at the spring hanger. Had to add a heavy angle at the axle. If I were to do it again with above axle I would do what is shown in post #10.
If you are into serious pulling I agree the below axle is the way to go. But for my everyday use and only pulling a 5th wheel trailer my system works good.
Old 01-03-2013, 03:11 PM   eBay Motors  #19 (permalink)
toxic diesel's Avatar
I had those bars on my 77 chevy least to say i cracked my leaf spring hanger and they didnt do shit
08 lmm efi live 530 rwhp s&b intake 5in turbo out exhaust. home made lift pump holley 150. 6 in atlas in rear custom 4 link 14 travel straight axle aam 03 dodge 4:56 gears rear locke. 37 toyo mt's 17 fuel hostage wheels rbp grille Replica recon smoked lights ppe hid lights soon to be mike l tranny
toxic diesel is offline   Reply With Quote
Old 01-03-2013, 03:13 PM   eBay Motors  #20 (permalink)
bturner's Avatar
Ya I'm not really seeing how the top mounted bars help at all
Need a zf6
