traction bar help please - Chevy and GMC Duramax Diesel Forum
Old 01-03-2013, 07:40 AM   eBay Motors  #1 (permalink)
Ok so i searched the foram for this and couldnt find it so sorry if this was answered already. i got a really dumb question i made my self some adjustable traction bars and i dont want them to rattle so i figured i would tighten them. do i tighten them so it pulls the ends togather or pushes them apart. hopefully you guys no what im talking about. Thanks Mark
2004.5 lly CC/SB LT white 147k : EFI Live DSP5 Tuned by Kory : Georend transmission : Stright piped 4in MBRP turbo back exhaust : Pro fab down pipe : EGR Block plate : AFE mouth piece : raptor lift pump : CAT Nicktane adapter : Rare parts tie rods : Traction bars
Dura is offline   Reply With Quote
Old 01-03-2013, 07:50 AM   eBay Motors  #2 (permalink)
mike diesel's Avatar
Personally i think if it were me, i would tighten them so it just slightly pulls the ends together. You wouldnt want to crank them together very tight tho, just a little snug is all.
05 lly
EFI Live
4094 vvt
Built Trans
BT Lockup Box
Supporting Mods
mike diesel is online now   Reply With Quote
Old 01-03-2013, 07:52 AM   eBay Motors  #3 (permalink)
BorderlineReckless's Avatar
how do they attach to the axle? i think it would make a difference. cuz if they are attached on the bottom and you shorten the bar it will roll your axle back if you lengthen the bar it will roll the axle forward. that's if its on the bottom. idk lol just rambling
-Trent-
2008 LMM 2500HD, MA-700, MBRP 4'', K&N cold air intake, EFI Live from Diesel Addiction, edge insight, PPE lift pump, egr blocked, 33'' Goodyear duratracs on 20" XD Misfits, de-debadged,smoked tail lights and cab lights, halo headlights, black grille, leveled with keys, B&M gooseneck hitch, air ride air bags with compressor, Alligator tie rod sleeves, PPE shim kit,Rough Country 6'' Lift Powdercoated Orange, 35w 5000k HIDs highs, lows and fogs
WAITING TO BE INSTALLED - PCV reroute, Ppe rear diff cover, inline filter kit
>>>build thread<<<
BorderlineReckless is offline   Reply With Quote
Old 01-03-2013, 07:54 AM   eBay Motors  #4 (permalink)
or do i have no clue what i'm talking about? haha
-Trent-
>>>build thread<<<
Old 01-03-2013, 07:55 AM   eBay Motors  #5 (permalink)
Its attached to the bottom of the U bolts
Old 01-03-2013, 07:58 AM   eBay Motors  #6 (permalink)
and my buddy tightened them and he pulled a goosneck a couple hundred miles and they were loose so was wondering what way was right?
Old 01-03-2013, 08:06 AM   eBay Motors  #7 (permalink)
Do you have jam nuts to keep the ends tight? I have jam nuts on all my stuff and they have never come loose, also is one end right hand thread and the other left hand thread or are they both right hand thread? If one of left and the other is right thread it will loosen itself very easily if there are no jam nuts. Post some picks of your setup please!
05 lly
EFI Live
4094 vvt
Built Trans
BT Lockup Box
Supporting Mods
Old 01-03-2013, 08:13 AM   eBay Motors  #8 (permalink)
I have left hand on one end and right hand on the other with a jam nut on just one end. i will try get some pics up ASAP
Old 01-03-2013, 08:17 AM   eBay Motors  #9 (permalink)
*The Solder King!* \m/ \m/
n0useforaname's Avatar
I could be wrong, because I honestly never really thought about it enough, but I would think it really wouldn't matter too much. The whole point of them is to stop rolling, and whether it's pulling or pushing, it will stop the roll (in my mind anyways).
RIDE: 2007 Chevy CCSB LBZ colormatched all around/bedlinered bottom
LIFT: ZONE, Kryptonite Front end, Cognito Brace kit, Traction Bars, Comp. Tubes
TRANS: Big Dipper Stage IV/PPE Deep Pan / Pump rub fix
SOUND:X4500BT, 6 1/2 JL Audio's, 10"s, 5 Channel JL AMP
INTERIOR: EGT/Boost Autometers & CTS, Black Cherry Denali Trim and wheel, Black Leather, Red L.E.D's, US Speedo Cluster, Rubber Floor, 20% tint
ADD ONS: 40 overs, AD II 165, Oasis Diff, Roll pan, Merchant brace, BigChevyHitch, Cowl Hood, 4500K HIDs, AMP Research Steps, LM Grille, BedRug w/ Recon lights, ExTang Solid Fold, LED tails
TIRES/WHEELS: 35X12.50-20 Toyo MT on 20x10 BMF S.O.T.A's and 4.56 Gears
AIRFLOW: EPR Triples, Turndown, AFE intercooler pipe, EFI LIVE by ATP
INSTALLER: BLACKOUT PERFORMANCE
Old 01-03-2013, 08:30 AM   eBay Motors  #10 (permalink)
Cknight199's Avatar
Why don't trucks come stock with traction bars? What's the purpose of axel wrap? Rather than having straight driveshaft?
2006 LBZ CCLB DRW
Suncoast Trans w/ 1056
Billet Garrett 4094
BTLockup Box
Built Front End
Some More Stuff
EFI Live by Starlite Diesel
Fastest 1/4 yet: 13.606 (fourth time down the track)
Cknight199 is offline   Reply With Quote
