LBZ - Duramax store "Stage 3 Front End" - Chevy and GMC Duramax Diesel Forum
Old 02-25-2013, 08:59 AM   eBay Motors  #1 (permalink)
jsucil89's Avatar
Looking at buying the Stage 3 Front End from the Duramax store for my 07' CCSB LBZ. The kit comes with the following which seems like the beefiest setup for IRS front ends out there:
- Kryptonite Center link
- Kryptonite Tie-Rods
- Kryptonite Idler support bracket
- Kryptonite Idler support frame gusset
- Cognito Pitman support
- Moog pitman/ilder arms
The kit is expensive ($1,378.99). Has anyone installed this kit? Are there vendors with more competative prices?
2007 Chevy CCSB LBZ
6" Fabtech, Fox shocks, 22x12 Weld Cheyennes, 325/50/22, EFI Live w/ DSP5 switch (Idaho Rob), CTS Insight monitor, EGT, SDP EGR Delete Kit, LB7 up-pipe, 3" DE downpipe, 4" MBRP CAT delete, 4" Magnaflow catback, Pace Edwards tonneau, AMP boards, leather, sun-roof, de-badged
2003 Cobra (10th ann.) - Aluminator, built glide w/ gear vendor OD unit, 10K orig miles
2003 Ford Lightning - Ridetech Air Ride
1989 Mustang LX - 32v mod motor conversion, 700rwhp
jsucil89 is offline   Reply With Quote
Old 02-25-2013, 09:17 AM   eBay Motors  #2 (permalink)
Definitely people out there who have installed it, hopefully they will chime in. The Kryptonite stuff if a proprietary design so its exclusively available from Dmaxstore. EXAXT used to be a great option and pricepoint but they haven't had production for a while now so until it becomes available again, the Kryptonite stuff (very similar to the EXAXT setup) is your best option for a bulletproof front end IMHO.
MTL_Dmax is offline   Reply With Quote
Old 02-25-2013, 01:56 PM   eBay Motors  #3 (permalink)
jsucil89's Avatar
Curious to hear feedback from the guys who have installed the stage 3 kit. I'm torn between the stage 2 and stage 3 kits.
2007 Chevy CCSB LBZ
Old 02-25-2013, 09:44 PM   eBay Motors  #4 (permalink)
DangerDog's Avatar
I have their tie rods and centerlink, it's good so far. Want to get their idler arm support and bracket. The centerlink might be a little close to the front differential with a lift kit though.
Sean
2006 Chevrolet 2500HD CCSB LBZ Duramax
SDP S480/Stock Twins
EFILive by IdahoRod
Pro Comp 6" on 35" Mud Terrains
ISSPro Triple Gauges Pillar
5" Straigh Pipe to Dual 7" Black Mitre Stacks
DMAXStore Kryptonite Front End
Mike L Stage IV Trans
FPRV Shim
FASS 150 Titanium
DangerDog is online now   Reply With Quote
Old 02-25-2013, 10:14 PM   eBay Motors  #5 (permalink)
ATPTRUCKS
sickdiesel's Avatar
We have their kits ready to go. Best kit on the market by far! We sell tons and never once had an issue. I have their kryptonite comp series on both of my rigs and is before the best.
Let me know if I can help out bud
Sent from AutoGuide.com App
Dustin im 22 and yes i bought my trucks myself
Blackout :06 GMC lbz 4x4 Built motor, SDP twins, exergy Injectors, Self built trans
White Thing :07 Chevy lbz 4x4 Caged and built to the hilt
Special thanks to: Mike L, Gtrippin, IdahoRob, SDP, ISSPRO, Yukon, and Cam at AP
LIKE US ON FACEBOOK!
Adrenaline Truck Performance IDAHO ROB 208.685.1000
sickdiesel is online now   Reply With Quote
Old 02-25-2013, 10:24 PM   eBay Motors  #6 (permalink)
KevinWielenga's Avatar
Just got my truck back today with the stage 3 installed it feels great and did a few launches and it launched straight as an arrow. Im also running BFG 285's and was worried about rub with the torsion bars down. How do my CV angles look??
Sent from my SCH-I535 using AutoGuide.Com Free App
2004.5 LLY
Stage 4 trans by MIKE L
Danville performance 72mm turbo
4 inch turbo back MBRP exhaust
Diamond eye downpipe
FASS 150
EGR Deleted
PCV re-routed
Shimmed fuel rail
Modded intake and mouthpiece
KevinWielenga is offline   Reply With Quote
Old 02-25-2013, 10:28 PM   eBay Motors  #7 (permalink)
ATPTRUCKS
sickdiesel's Avatar
Looks great Kevin! Glad it all went smooth!
I wasn't lying when I said I can launch at over 30 psi in blackout with 2 fingers on the wheel and it go straight
Old 02-25-2013, 10:31 PM   eBay Motors  #8 (permalink)
Ya dustin it is incredible!!! Now im just tuning my BOV and am gonna get some serious tests in at a track!!
2004.5 LLY
FASS 150
EGR Deleted
PCV re-routed
Shimmed fuel rail
Old 02-25-2013, 10:40 PM   eBay Motors  #9 (permalink)
ATPTRUCKS
sickdiesel's Avatar
Oh ya!
Old 02-25-2013, 10:51 PM   eBay Motors  #10 (permalink)
06LBZdmax40's Avatar
do you have stock keys in? im runnin leveling keys in mine and run 285's wondering if i can probably turn mine down a bit and reduce a little angle, not that i have bad angles now.
Matt
2006 LBZ CC/SB leveled w/ bilstien 5100s, egr blocked, pcv reroute, afe stage 2, 4" straight pipe, edge cts insight, EFI live-Idaho Rob, 285/75/16 toyo MT on stocker 16's, de-badged, de-molded, de-stickered
06LBZdmax40 is offline   Reply With Quote
