Old 08-10-2009, 05:43 PM   eBay Motors   #1 (permalink)
brown bear
brown bear's Avatar
suspencion and t-bars
like 6 months ago i installed a leveling kit but now that i rebuild my front end i try to turn my t-bars down and it seems like my front end it does not drops down all the way not sure why, may be because i left the hd torsion keys? also notice that my suspension it feels some times more likely when im driving on uneven road like if metal is hitting against metal or like if my shocks are bad i have brand new shocks, i jack up the truck and with i flat bar was checking if something was loose or moving between the ball joints and i cant see anything any suggestions please thank you
02 LB7
http://www.discounttiredirect.com/
brown bear is offline   Reply With Quote
Old 08-10-2009, 05:55 PM   eBay Motors   #2 (permalink)
Brooster
If you left the aftermarket keys it won't drop back to factory height as I believe those keys are taller. I have the same issues as you and have ordered the Cognito A-Arms to correct the problem. They are suppose to be in tomorrow so maybe I can get them installed Wednesday. It has taken almost two weeks to get them but should be worth the wait. I will post the results after the installation to let you know how it works out.
2008 2500 Ext. Cab Shortbed 4x4
285/70R17 Wrangler ATS on Stock Alloys
Cognito A-Arms & Leveling Keys
Everything else stock for now
Brooster is offline   Reply With Quote
