Old 10-21-2009, 08:41 PM   eBay Motors   #21 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
suspension guys....suspension..
no blocker plates, no fuel filters, no 400hp is the limit on stock 6 speed....
Old 10-22-2009, 09:15 AM   eBay Motors   #22 (permalink)
Buck
Buck's Avatar
1. in cognito worth the money?
2. which lift kit is the best?
3. do 1/2 ton keys lift your truck?
4. how far is to far to crank your stock t-bars
5. do scolatic shackles work?
6. whats the best shocks?
7. bilstien or fox shocks?
8. do 33's fit levled?
9. do 35's fit with a 4in lift?
10. do 38's fit with an 8in lift?
Vehicle 2008 Chevy Crew Cab Short Bed
Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims
Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck
Drivetrain LMM Duramax, Allsion 1000 Transmssion
Performance Mods RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Hot+2 Race LMM tuner (160hp setting), PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC
Other Mods B&W Turn Over Ball, Air Lift Bags, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
Buck is offline   Reply With Quote
Old 10-22-2009, 10:35 AM   eBay Motors   #23 (permalink)
la77chevy
la77chevy's Avatar
I believe this is a Q & A kinda thing, all i see is questions Were lookin for answers too.
04 LLY CCSB
LBZ mouthpiece,resonator plug
33x12.50 Toyo MT's on 18'' Eagles
Gooseneck Hitch
Spray in bed liner
Straight pipe with 4''tip
AFE stage 2, EGR blocker
PPE Xcelerator
N-Fab step bars
Tool box, bed rails
la77chevy is offline   Reply With Quote
Old 10-22-2009, 10:38 AM   eBay Motors   #24 (permalink)
Hondarider552
x2..........
Old 10-22-2009, 10:48 AM   eBay Motors   #25 (permalink)
zack
STRIPCLUB CONNOISSEUR
zack's Avatar
Q. I have a nbs chevy (07.5 - 2010) what size tires can I fit on with a leveling kit
A. You can Run 285/65/18's with minor trimming on a factory wheel or with in the same spec of factory (mine are 18x9 with 0mm offset), I do it with cognito leveling kit
Q. Are tierod upgrades nessisary?
A. YES!!!!!!! If you have anything done to your truck at all I strongly suggest Cognito HD tierods, Worth every penny they cost.
Zack, 21
2008 Silverado 2500HD LMM EXTCAB 4x4
EFI TUNED BY HUSKER DIESEL
7000lbs
461/834
14.2 @96mph
zack is offline   Reply With Quote
Old 10-22-2009, 11:40 AM   eBay Motors   #26 (permalink)
Six-Gun-Todd
Turkey day awaits...
Six-Gun-Todd's Avatar
Location: Second star to the right and straight on till morning
Ok.....here is a question you could answer for me.....
I have a NBS truck and want to lower it a bit.....what is the best process for doing this without major frame work ?
My life in times is complicated, more complicated than most will ever comprehend. Going fast was the only thing that ever made me feel better about being me.
-Six Gun Todd
MPF
www.meyerperformance.com
812.344.4421
Six-Gun-Todd is offline   Reply With Quote
Old 10-22-2009, 12:24 PM   eBay Motors   #27 (permalink)
Buck
Buck's Avatar
1. in cognito worth the money? yes
2. which lift kit is the best?depends on buget and other factors, what are you using the truck for ect.
3. do 1/2 ton keys lift your truck?unneeded with a proper levling kit
4. how far is to far to crank your stock t-barsyou need 5/8in between your UCA and the frame stop
5. do scolatic shackles work?i don't know never used em
6. whats the best shocks?depends on what you want to do with the truck.
7. bilstien or fox shocks?depends on what you want to do with the truck
8. do 33's fit levled?yes...kinda
9. do 35's fit with a 4in lift?yes
10. do 38's fit with an 8in lift?yes...kinda
Originally Posted by Hondarider552 View Post
x2..........
you guys are rough!
Old 10-22-2009, 12:33 PM   eBay Motors   #28 (permalink)
zack
zack's Avatar
im sure you already know, but drop shackles for the leafs in the rear and slack off the tbars. you can get a +/- 3 inch drop by doing that.. and drop shackles are usually under 100 bucks.
Zack, 21
7000lbs
461/834
14.2 @96mph
Old 10-22-2009, 03:24 PM   eBay Motors   #29 (permalink)
Nor-Cal Nick
Suspension Consultant
Nor-Cal Nick's Avatar
You looking for a job?
I will also add, ride quality will suffer if you let the front down too far. You have to watch on how much the truck rests on the compression stops so the truck doesn't bottom out on the front end..
Shop On-Line 24/7 @ NorCalTruck.com Suspension & Diesel Performance (Visa-M/C-AMX-Disc-PayPal-We ship to Canada)
Sales- Mon-Fri 8am-5pm(PST) #925-447-7800
What's HOT for HD owners: Shocks / Steering upgrades / Leveling packages
Nor-Cal Nick is offline   Reply With Quote
Old 10-22-2009, 03:26 PM   eBay Motors   #30 (permalink)
Nor-Cal Nick
A. You can Run 285/65/18's with minor trimming (on a factory wheel or with in the same spec of factory), I do it with cognito leveling kit
I added alittle to yours...
