New shocks for 04 Duramax - Chevy and GMC Duramax Diesel Forum
post #1 of 3 (permalink) Old 02-25-2014, 03:32 PM Thread Starter
zmillsz5m's Avatar
Hey guys im looking into replacing the shocks on my 2004 extended cab LLY. Id like to get some opinions on something for a smoother ride than stock, i have also somewhat leveled the front out by turnin the torsion keys but not maxed out, probably about 3 inches. Also is it crucial what length shocks i get? Thanks guys
2004 LLY extended cab, AFE mouthpiece,EGR blocked,33 NittoTerra grapplers,4" MBRP downpipe back 5" Tip, EFI live tuned by Idaho Rob,Edge CTS Tuner
zmillsz5m is offline
post #2 of 3 (permalink) Old 02-25-2014, 04:10 PM
agibson94's Avatar
I leveled my 04 lb7 by torsion bar and I replaced with regular shocks no problems. I put more expensive shocks but still OEM size and its still not caddy smooth like it was new, but I'm fine with how it is. If you raise it or get bigger tires it always seems to get rougher in my opinion.
2004 lb7 chevy duramax
Volant cold air, boost and pyro egt gauges
ppe boost increase valve
diablo sport predator
4 in exhaust turbo mouth piece gibson exhaust tip, nicktane adapter cat filter, pioneer double din,leveled,
Hids led dash lights
Carthage, indiana
LEAD FARMER
andy
agibson94 is offline
post #3 of 3 (permalink) Old 02-25-2014, 04:22 PM
MHDMAX66's Avatar
I just put rancho rs9000xls on my truck and like em. They have 9 settings so you can adjust the shock to what you want lower when empty and higher when towing. I was on 4-5 in the rears for a little bit and it's deffinetly noticeably softer ride then the stocks. I jacked them up for towing I think 7 or 8 and was to lazy to adjust them back it's more stiff but not that bad. If your leveled you probably need extenders or a longer shock but who ever you get them from should be able to get that straightened out for you I got mine from the Dmaxstore.
2008 GMC 2500HD LMM
-EFIlive with dsp5 swicth -Transgojr with transynd -Edge cts gauge monitor with dash mount -Edge eas egt probe -Airdog 165 lift pump -Blocker plate -Transmission cooler lines -Optilube fuel additive -Backup camera
MHDMAX66 is offline
