there last sema truck came down to the wire too, I think nick was applying decals the night before and taking pics on the way to sema lol. The cool thing, it looked bad ass at sema. well done last year, and most likely this year too
__________________ 09 white on black CC/SB LTZ loaded.
RPB grill, 6k HIDs hi/low and fogs, pyro/boost gauges, 7-9" cognito, air bags w/compressor, train horns, 20" rockstars, 35" toyo MTs, 5% tint, AMP steps, DPF DELETE, 5" magnaflow w/ RPB tip all gone but the muffler, AFE intake, two JL 10's, all new interior speakers, PPE HOT, titan tank, bed liner, 10inch adjustable drop hitch, and more to come!
CRAP !!! I need to get new stickers made for my dually and my wifes burb. Thanks for the reminder !!
__________________ 2006 Chevrolet CC/SB LBZ 4x4
MBRP 4" Down Pipe Back w/ 5" Tip...Bye Bye Kitty!!!!
285 BFG All Terrains on Factory 16"
Tinted Front Windows 20%
B&W Turnover Ball
Ryan starting to drop the factory u-bolts getting ready to install the new 4" fabricated lift blocks and new longer u-bolts.
The front end is pretty much finished up in this pic.
This truck is a crew cab long bed so it has a 2 piece rear drive line. On a truck with a 2 piece drive line you must drop the carrier bearing to reduce the u-joint working angles, reducing the chance of a vibration when lifting the rear of the truck.
RBP wheels wrapped with Toyo 37x13.50x20 Mud's.
Justin needs to get out of my shot.
Here is a pic of the new Cognito HD long travel helper air bags and Firestone auto leveling system. This package is the "weld on" version. For 3500's the axle bump stop pads are larger and you must cut them off and use the weld on version. This version kit is also great for custom rear axle set ups. The "Bolt On" version will be the more common used kit for guys running large size lifts and needing a helper bag kit that will not bind or over stretch when the suspension is traveling between it's full stroke.
Here is Ryan cutting off the factory 3500 axle bump stop pad.
And with the new Cognito weld on mount. In this pic you can't notice too easy but there are 3 holes on the side of the bracket (1 bolt holding it together right now in the pic). This will allow someone to pivot the bag mount to allow fine tuning. This is key to maintain bag alignment when a truck has the axle degreed for proper drive line angle.
Justin making final adjustments before starting to weld.
A pic of Justin welding the lower bag mounts to the axle.
More pic coming..... including in the next batch what I do to the fenders to clear the 37's with the truck sitting in the 7.5"-8" range. Easy steps you can do with simple tool in your garage.
Any questions or comments please feel free to post them.
