Old 11-04-2009, 01:24 PM   eBay Motors   #21 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
Originally Posted by IGUESS View Post
OB, i kinda want to put a little lift in the rear too. did you go with longer shocks in the rear or stay with stock height? and for the front i need a 2" longer shock?
I went with longer shocks in the rear too. I talked with nick at norcal truck and he set me up with the right stuff. I highly recommend to get the bilstein 5100s. The ride is so much better once i put them on. Before i had the yellow and blue bilsteins...ride was much better than stock, but not near as nice as the 5100s.
Old 11-04-2009, 01:46 PM   eBay Motors   #22 (permalink)
Buck
Buck's Avatar
Originally Posted by bnkrupt View Post
the only reason you want the Cognitos is to fit your 33's??
the ONLY thing the Cognito UCA's do is give you more down travel when your bars are cranked or key'd.
you can run a 33 with your bars tuned up and not need the UCA's unless you are looking for max down travel, in case you are making lots of sweet jumps or something.
just give your bars a few cranks and drive it. you would be much better off spending your money on a better (longer) shock than a UCA kit.
the CV angle is what you need to be concerned about, not if you hit a bump stop on full down travel.
Call me if you need some help. I really hate to see so many people confused about this.
Cognito or NOT you are still going to fatigue your front end parts if you do not level properly.
I don't know about all that... true the CV angle is what’s most important however arms or not they can still be taxed beyond its design parameter.
all largers tires wear the front end out faster then stock t-bars cranks or not.
The ball joint angle is fixed with the aftermarket arms as well.
What’s your beef with the arms? Don’t get as deep a discount as Nick or what? A good part is a good part.
to the OP get the shocks if your spending the money cus the stockers are junk when it rolls off the line in MI!
Vehicle 2008 Chevy Crew Cab Short Bed
Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims
Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck
Drivetrain LMM Duramax, Allsion 1000 Transmssion
Performance Mods RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Hot+2 Race LMM tuner (160hp setting), PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC
Other Mods B&W Turn Over Ball, Air Lift Bags, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
Buck is offline   Reply With Quote
Old 11-17-2009, 12:05 PM   eBay Motors   #23 (permalink)
Nor-Cal Nick
Suspension Consultant
Nor-Cal Nick's Avatar
I was wanting to get the UCAs bc of the angle the ball joints would be at and the wear they would get being at that angle. Would the ball joints not wear like im thinking they would if i would just crank the bars?
Yes there are alot of positive reasons to look at the Cognito packages for leveling. In the end your suspension will be better and stronger for this type of height you are looking for. Every part has it's direct reason of being part of our packages.
Originally Posted by zack View Post
If tools from around the house include a fairly well set up ool box then yes. You'll also need a torque wrench, pickle fork, sledge hammer (yes a sledge), and a grease gun (for greasing the bushings after its all installed) I wouldnt get shock extensions if your going all out just buy longer billstein 5100's and you'll be set.
Yes x2 on the kit being DITer friendly with common tools and a couple other tools that are not as common can be obtained easy most of the time.
Here is a video to check out by another member from a Dmax forum that did his in the garage, might help:
You can add a rear block to gain alittle lift to get that end stance of rack back. This is common if what you are looking for.
Shop On-Line 24/7 @ NorCalTruck.com Suspension & Diesel Performance (Visa-M/C-AMX-Disc-PayPal-We ship to Canada)
Sales- Mon-Fri 8am-5pm(PST) #925-447-7800
What's HOT for HD owners: Shocks / Steering upgrades / Leveling packages
Nor-Cal Nick is offline   Reply With Quote
