Old 11-06-2009, 07:42 PM   eBay Motors   #1 (permalink)
Dura2thaMax
Dura2thaMax's Avatar
Steering stabilizer
Does anyone know if a steering stabilizer would help with a truck that follows grooves in the road?
Or what does a steering stabilizer help with?
Thanks
07 Sierra 2500HD CC SB Classic. Loaded
LBZ
4" Rancho Susp. Lift
K&N Intake
Edge Juice w/Attitude
Dura2thaMax is offline   Reply With Quote
Old 11-06-2009, 07:45 PM   eBay Motors   #2 (permalink)
jaglmm
Diesel Addict
jaglmm's Avatar
i'd like to have one also..
i heard there a P.I.T.A to install
07.5 LTZ
473h.p/1038lbs of torque 11-14-2009
Suspension: 6inch Rough Country w/ Shocks
Wheels: 37x13.50 Super Swamper M16's on 22x11 Black Monsters
Programmer: EFI Live
Exhaust: MBRP DPF back stack kit, 6inch Black Stack, DPF delete, Lost Kitty
Lift Pump: Airdogg 150
Intake: S and B
Gauges: Triple Pillar w/ EGT, Boost, Fuel Pressure
Other Mods: Aem water/meth, Trans Go Jr, Fabtech Tierods, EGR blockoffplate, PPE shim kit
jaglmm is offline   Reply With Quote
Old 11-06-2009, 09:21 PM   eBay Motors   #3 (permalink)
maxxflip
maxxflip's Avatar
Thanks
It might a little.... I bet replacing the pitman and idler arms would solve the problem they will cause wandering if worn
08 LMM
Tuned by ʍʍlʍʍ
maxxflip is offline   Reply With Quote
Old 11-06-2009, 09:34 PM   eBay Motors   #4 (permalink)
Dura2thaMax
Ok. I just wondered if it wasnt from the 305's that are on it. Funny the guys at the alignment shop didnt say anything about them. All they said was wheel bearing was shot
LBZ
K&N Intake
Old 11-06-2009, 09:36 PM   eBay Motors   #5 (permalink)
maxxflip
maxxflip's Avatar
OK... a bigger and better stabilizer might help a bit......Didnt know you just had it at an alinment shop
08 LMM
Tuned by ʍʍlʍʍ
Old 11-07-2009, 01:37 AM   eBay Motors   #6 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
did you check your wheel bearing? easy to check...jack the front tires off the ground and try to rock the tire at 12 and 6....if there is movement, that bearing is bad.
Also, with the alignment...they were able to get it within specs and not just close right? I know if caster is off a little it will cause wandering.
Old 11-08-2009, 07:13 PM   eBay Motors   #7 (permalink)
Dura2thaMax
The bad wheel bearing was replaced. I am not sure about the alignment. As far as I know it was good. How does a person check the Idler and Pitman Arm? Its really bad when brakes are applied
LBZ
K&N Intake
Old 11-17-2009, 12:18 PM   eBay Motors   #8 (permalink)
Nor-Cal Nick
Suspension Consultant
Nor-Cal Nick's Avatar
A stab. will help but you want to make sure that is something added after every other part is looked at because you may hide the true problem. If everything is solid then it will not heart to add a stab. or replace the OE on your truck.
Shop On-Line 24/7 @ NorCalTruck.com Suspension & Diesel Performance (Visa-M/C-AMX-Disc-PayPal-We ship to Canada)
Sales- Mon-Fri 8am-5pm(PST) #925-447-7800
What's HOT for HD owners: Shocks / Steering upgrades / Leveling packages
Nor-Cal Nick is offline   Reply With Quote
