Tighten parking brake (e-brake)? - Chevy and GMC Duramax Diesel Forum
post #1 of 14 (permalink) Old 07-04-2010, 12:17 AM Thread Starter
tigermack's Avatar
Send a message via AIM to tigermack
Hi guys,
I was wondering how do I get my parking brake engage tighter? When I shift it into Park (P), I still get a little budge when I let go of the brakes unless I put the parking brake all the way deep to the floor, I don't think that's normal but it works fine. Is it possible that I can adjust it and engage a little earlier so I don't have to step on it that far? Just for a peace of mind, I guess.
Thanks.
03' EC LB7 2WD
T6 Rotella - Napa oil filter
Amsoil Torque-drive - Napa filter
PPE standard & boost valve | Bilstein 5100's | Prosport EGT & boost gauge w/ Autometer dual overhead pod | Pioneer Avic D3
tigermack is offline
post #2 of 14 (permalink) Old 07-05-2010, 03:56 PM
saw what you did there
theunderlord's Avatar
sounds mildly normal, free bump for ya.
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #3 of 14 (permalink) Old 08-12-2010, 07:53 AM
My Parking brake does this too and I would like to fix it. Any luck recalibrating it?
02 chevy 2500HD 4X4 Crew cab Short box
Virginia Beach
sirhc3 is offline
post #4 of 14 (permalink) Old 08-21-2010, 08:26 AM
eagleers's Avatar
bump bump bump
2004 Chevy Silverado 3500 Duramax LLY Allison 4x4 Dually
Mouth piece mod,turbo Resonator blocked,pvc reroute mod EFILive DSP5 Amsoil oil and fluids all around custom front bumper with receiver hitch and Piaa driving lights
Autometer 2 gauge pillar with Z series boost and pyro Pioneer Avic d3 and Ipod connection Bose
Cobra cb Radio Shack scaner Kobalt full size tool box
rest stock
eagleers is offline
post #5 of 14 (permalink) Old 08-21-2010, 08:52 AM
LHN...We ARE the Joneses
Itís a Drum-in-Hat, open it up and adjust the shoes.
Usually, by the time the PB gives way from holding, itís also time (or nearing) for a brake job too (check the rears, wears there faster).
Hook'em_Horns! is online now
post #6 of 14 (permalink) Old 08-21-2010, 04:21 PM Thread Starter
tigermack's Avatar
It's not a drum brake, though...?
03' EC LB7 2WD
post #7 of 14 (permalink) Old 08-21-2010, 04:28 PM
biketopia's Avatar
it's a mini drum brake set up inside the rotor just for the parking brake. It's easier to simulate the action of a drum by the use of cables.
2003 2500HD LT CCLB, EFILive by Idaho Rob, 4" MBRP, Diamond Eye Down Pipe, Ported Intake Horn, S&B Intake, PPE Boost Valve, ADII, Nicktane CAT Adapter, CTS Insight, Cognito UCA, Rare Parts Tie Rods, Cognito Brace kit, Bilsteins, Gear Alloy wheels, Hankook RF10 285's, All on Mod, DDM 5k Low's & 4300 Fogs, air horn, on board air, limo tint, blue led interior
biketopia is offline
post #8 of 14 (permalink) Old 08-21-2010, 04:32 PM
1slowracer's Avatar
Technically not a drum brake. But the park brake shoes are inside the rotors. It a "rotor drum". The soft filling is normal. You can adjust them without taking anything apart. If they still semi hold. Pull and hold the e-brake release handle then pump the e-brake pedal about 10-15 times semi fast that will rachet the adjuster. Hope i was some help.
2001 chevy 2500hd 4x4 ext. Cab long bed lb7
5" turbo back exhaust into 6" tip
afe cold air intake, bills 3.5" turbo horn
homemade boost valve
EFI live dsp5 by Idaho Rob
Airdog II 165
and hopefully much more to come:rockin
1slowracer is offline
post #9 of 14 (permalink) Old 08-21-2010, 07:05 PM Thread Starter
tigermack's Avatar
Let me give that a try now. Thanks.
03' EC LB7 2WD
post #10 of 14 (permalink) Old 08-21-2010, 07:08 PM Thread Starter
tigermack's Avatar
I think that worked, I will see when I take it out driving and parked. Thanks!
03' EC LB7 2WD
