06 2500hd 4x4 w/wheelchair lift and Iím having suppression issues - Chevy and GMC Duramax Diesel Forum
post #1 of 13 (permalink) Old 10-31-2010, 06:14 PM Thread Starter
don27usa's Avatar
I have a 06 2500hd 4x4 w/wheelchair lift and Iím having suppression issues, with me and my wheelchair it leans about 2Ē on driver side. It already has 3Ē body lift to accommodate the wheelchair lift. The GMC dealer cranked the keys up 2Ē on the driver side and now it rides really rough. Anyone know how I can fixs this issue, I would not mind coming up to almost level, but donít know, to do this and get a good ride, since Iím always pushing down 2Ē already?
Here is the wheelchair truck conversion link: GoSHICHI 4x4
Thanks, Don
don27usa is offline
post #2 of 13 (permalink) Old 10-31-2010, 06:17 PM
blaineGMC's Avatar
They make adjustable air shocks for the front i beleive.
Blaine
04 LLY Suncoast/Precision ML by me. Tuned by Rob.
AFE, MBRP, Mag-Hytec, Merchant Automotive, SSBC, Bilstein
For EFI Live go to:
blaineGMC is offline
post #3 of 13 (permalink) Old 10-31-2010, 06:24 PM
07-Dmax's Avatar
I would contact the wheelchair lift company and ask them why it leans. they should have compensated for this somehow in there design. Otherwise maybe an airbag set up on your suspension front and rear with seperate air valves so you can adjust them. You wouldnt need much air at all for this and it may not ride all that bad. minimum air on the right side and 4 or 5 pounds more on the left. good luck. first time I have seen this set up and with my step brother in a chair I can see where this would be very cool for ya.
2007 chev 3/4 ton ccsb ltz
6" rcd lift, amp research elec steps, mag hitec diff cover, amsoil dual bypass oil filter, bushwacker flares, 295/70/17 toyo m/t, a bunch of go-fast parts I cant name for the time being.
You didnt see me
you cant prove it
I didnt do it
07-Dmax is offline
post #4 of 13 (permalink) Old 10-31-2010, 06:50 PM
usafduramax's Avatar
not to downplay the fact that you're in a wheelchair, but that is a very neat set up and cool idea
usafduramax is offline
post #5 of 13 (permalink) Old 10-31-2010, 07:03 PM
Mabye contact Nor-Cal Nick on here. He is the suspension guy around here. If anyone would have a suggestion he will. BTW that is a great looking conversion, I have a friend in a wheelchair and he wasnt able to find anything like that, he got a dodge magnum.
'06 Chevrolet CC/SB LT3 LBZ 4x4
MBRP 4" Straight, BFG KO's, Autometer Ultralites, HID's, B&W Turnover Ball,
Rhino Liner, Predator on 40hp with more to come.
'08 Chevrolet CC/LB LMM Work Truck 4x4
Deleted, DPF-R, Reading Utility Bed, Leveled on 285's, Rhino Lined
LBZ_Duramax is offline
post #6 of 13 (permalink) Old 11-01-2010, 05:16 PM Thread Starter
don27usa's Avatar
Thanks guys....I have talked to Nick, I was seeing if someone had other ideas, i did install air ride bags in the rear. I guess I really dont understand the concept of how the congito supension would help leveling it out. They dont have front airbags that, I know of! Has anyone installed the installed a congito from Nor-Cal? Thanks
Oh which 4" exhaust ya like?
don27usa is offline
post #7 of 13 (permalink) Old 11-01-2010, 05:28 PM
blaineGMC's Avatar
I Beleive Bilstein makes adjustable air shocks...
MBRP, Diamond Eye, There all good. Buy from a vendor on this website!
Blaine
For EFI Live go to:
post #8 of 13 (permalink) Old 11-01-2010, 05:31 PM
Stupid Has The Balls
Odyssey25013's Avatar
Bilstein front air shocks. MBRP or Magnaflow
Ben
2006 LLZ LT3 EC/LB
"Going for Broke"
Some Expensive Parts, Good Times, Busted Knuckles, Long Nights and Fancy Gauges So I Can Watch While I Blow Things Up
Special Thanks To Ben Tyler at BT DieselWorks, LLC. For All The Help and Hard Work
Odyssey25013 is offline
post #9 of 13 (permalink) Old 11-03-2010, 03:35 PM Thread Starter
don27usa's Avatar
To make the exhaust a true 4" do you need to replace down pipe?
don27usa is offline
post #10 of 13 (permalink) Old 11-03-2010, 04:04 PM
saw what you did there
theunderlord's Avatar
Yup. otherwise you'll just have a 4" 'downpipe back exhaust"
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
