Aftermarket camber bolts? - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 02-09-2011, 07:10 AM Thread Starter
brut3forc3's Avatar
Ok, im having a hard time with my truck pulling to the right and unevenly wearing my passenger tire. Is there a camber bolt that allows more adjustment than stock?
Thanks
EFI Live Tuned! by IdahoRob :rockin
2005 GMC LLY
Smoked cab lights
LBZ MP,LBZ intake
PPE stage 5 tranny
LMM Manifolds
6 inch rough country lift.
4 Inch MBRP straight pipe
to single 8" Mitre stack
35 Toyo M/T on 18" goliaths
brut3forc3 is offline
post #2 of 9 (permalink) Old 03-04-2011, 11:02 PM
BoostJunky's Avatar
Bump
I'm curious too. Found Car Part Wholesale - Auto Parts and Accessories Catalog - Moog Camber and Alignment Kit
and Moog MOK80277 thats a +/- 2* plate and the MOK100026 is the whole kit with up to +/- 1.5*
I've got a 4" Rancho lift and both tires are kicken in and are wearing the inside of both my front tires. I gotta get this fixed ASAP.
07.5 6.7 Cummins MC/SB
EFI, ARP, SC Comp 68, FASS, HTT Stainless, Borg Warner, Diamond Eye, and a lot more...
-2002 cc/sb SOLD
|4.5" on 34's|18" Moto Metal 961's|PPE 160 Tune|S&B CAI|5" Straight Pipe w/ 7" Tip|Ported/Polished Intake Horn|PPE BIV|PPE CP3 Fitting|Autometer Cobalt Boost/Pyro|Sleeves|Bushwackers|Kenwood 2xDin|Headrest DVDs|Boston Components|10's, JL 500/1 & 300/4|Black Halo Projectors w/ 6k/8k HIDs|Billet Grille|5% Tint|'03+ LED Tail Lights|Clifford Security System|Valentine One
BoostJunky is offline
post #3 of 9 (permalink) Old 03-05-2011, 12:24 AM
NewEST Spinny Thinggg
seth999's Avatar
I would check out my idler and pitman and other components first chances are it could be a worn out joint especially with a lift
06' CHEVY 2500HD CCSB PULLER/DD
Danville Billet S475
SoCal Stg.2 Heads
SoCal Cam
Mahle Forged Pistons .040 ovr
Hamilton Rods
Floor it pump
Dipper sticks
ATS Trans/CoPilot/TC
Other Stuff...
seth999 is offline
post #4 of 9 (permalink) Old 03-05-2011, 12:34 AM
KYdmax's Avatar
x2 on what Seth said... these tend to wear out over time... is there any play left to right if you jack up one of your tires???
Landis: '08 LMM, Black, LTZ, CC, SB, 4x4, Edge Evo Race CTS, Black MBRP 4" Turbo back straight pipe, Debadged, No door moldings,RBP Grill(slightly modified) Black Bowties front and rear, all headlight on mod, Leveled, 18"Black Rockstars with 285/65s Nitto Terra Grapplers
'00 Cherokee, Ready for the trails
Lol, I get confused easily Josh. You can't just run up and take my fkn glue and scissors and tell me arts n crafts time is over without a reason.
KYdmax is offline
post #5 of 9 (permalink) Old 03-05-2011, 07:49 AM
BoostJunky's Avatar
L-R or Up/Dn? The pass side hub bearing is starting to have a slight bit of play in it but nothing too too serious. I'm not sure ab L/R though. The adjustment brackets are maxed out though. That's where the others with the extra 1.5 +/- degrees of adjustment comes in to play.
-2002 cc/sb SOLD
post #6 of 9 (permalink) Old 03-05-2011, 09:33 AM
BoostJunky's Avatar
There are also these. 2001-2008 Chevrolet Silverado 2500 HD Control Arm Bushing Kit - Suspension - Moog, Upper 01-08 Silverado 2500 HD Control Arm Bushing Kit - 3704-07031519 - PartsGeek
Anyone used these to fix the alignment problem or the bolt kits?
-2002 cc/sb SOLD
post #7 of 9 (permalink) Old 03-05-2011, 10:28 AM
scottdomine's Avatar
Bolt kits are fine as long as you be sure that you don't have any other problems first. The bolt kit should be a last resort only. Check that no suspension or steering parts are bent or worn before resorting to the bolt kit for alignment. In theory, if everything is straight and good, the factory length bolt should align fine, but that doesn't always hold true. Most of the time when an alignment shop uses an a/m bolt they are just hiding (or ignoring) some other problem.
2016 Denali 2500HD CCSB 4X4: Ride Rite air bags, Totron 30" behind grille, Black emblems, Door moldings removed, Moshimoto LED Fogs, 5% rear 25% front doors Solar Guard windshield tint, Husky floor liners. 20X9 Fuel Assault (+1 offset) Cooper STT Pro LT295/60R20. Leveled - Kryptonite uppers, keys, shock extenders
scottdomine is offline
post #8 of 9 (permalink) Old 03-05-2011, 10:42 AM
BoostJunky's Avatar
So check the I&P arms first and then what? Driver side hub is good, pass side is ok but could stand to be replaced. I need a swap bar connector for the driver side, but other than that everything else looks pretty good just by eye balling it.
-2002 cc/sb SOLD
post #9 of 9 (permalink) Old 09-11-2011, 12:44 PM
Diesel Dan's Avatar
Send a message via AIM to Diesel Dan
Replace both hubs first or aligning it is a waste of time.
2003 Chevy 2500HD ECSB D/A
110 HP tune Kryptonite tie-rods / Cognito braces
BFG KM2 305/65R17 (33x12.50") on H2's
Timbrens front, Hellwig overload springs rear, Bilstein 5100's, Rhino lined bed, '06 tow mirrors, camo seat covers, High Idle switch, Gadsden sticker on rear glass
MEMBER #1 Dirty Work Truck Club
'98 Jeep XJ 4.slow / Auto
4.5" Lift, 32x11.50-16 Nitto Trail Grapplers, M/T Wheels, homebrew bumper, Powertrax No Slip/C8.25
Whats a sway bar?
Drop the tailgate down on a turn row
Watch the corn grow, baby that's a good night
Diesel Dan is offline
