Old 08-12-2008, 10:16 PM   eBay Motors   #11 (permalink)
cloudgmc
Points: 441, Level: 7
Points: 441, Level: 7 Points: 441, Level: 7 Points: 441, Level: 7
Activity: 1%
Originally Posted by Tow Master View Post
Unfortunalty there can be a million things the hurt the ride of a truck. Tires, tire air pressure, shocks. Id take the air out of the bags to see if it helps. Everyone says bilestein? shocks are the way to go. Im not 100% sure if there better than ranchos or not. How do you knopw the truck has a leveling kit or not? How much of the silver shock is showing? If the owner put to small chocks on they could be bottoming out causing a bad ride.
wow, thanks for the reply guys got me lots to think about. i talked to the owner. he put on aftermarket torshion keys to level the ride. iv noticed that they are not all loaded they have lots of threads left on the bolts that push up on the keys. the shocks have a 1/2 inch spacer on each one of the front ones, just below where they thread to the frame, (i hope u know what i mean or ill take a pic.) he said it is to make it longer. iv heard that u can do that to the stock shocks to get a better ride. i dont know how mush of the silver is showing ill check but there is a dust boot there. tires are 285/75r16 psi 55 all the way around. with bf goodrich. i get most of hard rde in the front. feels like i hit a bumb or a dip and the front end just keeps bouncing, its even hard to keep the gas pedal steady during that. i mostly have the psi on the bags at 3. hopes this helps, later
2005 gmc 2500 LLY crew cab, airaid intake, 5" magnaflow exhaust cat back, no programer yet. pleasure vehicle 12.7mpg
cloudgmc is offline   Reply With Quote
Old 08-13-2008, 12:23 AM   eBay Motors   #12 (permalink)
Tow Master
Idiot lookin at the computer
Points: 12,414, Level: 48
Points: 12,414, Level: 48 Points: 12,414, Level: 48 Points: 12,414, Level: 48
Activity: 90%
Activity: 90% Activity: 90% Activity: 90%
Tow Master's Avatar
Wow I thought you ment it rides like a brick. Thats strange for it to keep bouncing and usually means a leaking shock. Your shocks could of went bad and or all the fluod came out. Even if you adjust the ranchos it might not make a difference. Have you tried putting the shocks on the highest and lowest number to see whatthe difference was?
Jason
Old 08-15-2008, 08:06 AM   eBay Motors   #13 (permalink)
rotcartdj
Points: 679, Level: 9
Points: 679, Level: 9 Points: 679, Level: 9 Points: 679, Level: 9
Activity: 0%
When I first put my aftermarket keys in I did not install the shock extension brackets to see what the ride would be like and what you are describing is almost exactly what my truck was doing. I installed the extensions and most of the bounce went away. There is still some but that comes from the extra preload on the torsion bars. Hope this helps.
2004 Chevy 2500HD EC Short Box w/LB7 ZF-6 speed
255/85-R16 Remington Mud Brutes on factory rims with 2" Lift Front and Rear
Straight piped. Kennedy Air Box Mod. AFE Drop-In Filter. CrankitupDiesel Tie Rod Sleeves
AmsOil Severe Gear Front and Rear Diffs
Autometer Phantom II Boost and Pyro w/ overhead console mount
FUTURE UPGRADES
Exhaust 4in Turbo Back
EFI Live w/DSP5
Cognito Braces/Upper A-arms
And the list goes on and on
rotcartdj is offline   Reply With Quote
Old 08-15-2008, 12:05 PM   eBay Motors   #14 (permalink)
Duramax_JP
Points: 791, Level: 10
Points: 791, Level: 10 Points: 791, Level: 10 Points: 791, Level: 10
Activity: 19%
Activity: 19% Activity: 19% Activity: 19%
Ive heard the rancho shocks arent too great. But i may be wrong.
Duramax_JP is offline   Reply With Quote
Old 08-15-2008, 12:31 PM   eBay Motors   #15 (permalink)
Buck
Points: 1,423, Level: 15
Points: 1,423, Level: 15 Points: 1,423, Level: 15 Points: 1,423, Level: 15
Activity: 14%
Activity: 14% Activity: 14% Activity: 14%
Buck's Avatar
Rancho shocks are for lifted trucks from 80's there is a reason most all high performance cars and trucks for that matter come from the factory with Bilstein shocks THEY ARE THE BEST. It is the signal biggest improvement you can make to any car or truck. Just go to there website and get the right shock for you. Some truck apps have a HD and soft options just pick which one you want. Also if you have a leveling kit you should check out cogneto motorsports they have a extended length shock made just for them by Bilstein for your app. Nor Cal Nick can give you more info on them.
(My Truck) Black 2008 Chevy Crew Cab Short Bed
4x4 Z71 LTZ LMM
Speedliner, WeatherTech FloorLiners, B&W Turnover Ball
(Work Truck/Tow Rig) Black 2005 Chevy Crew Cab Long Bed Dually
2WD LT LLY
Transfer Flow 100gal in bed tank, B&W Turnover Ball, Edge/Attitude Level 2 all the time, 4inch Turbo Back Exhaust with Cat Delete
Buck is offline   Reply With Quote
Old 08-16-2008, 02:44 PM   eBay Motors   #16 (permalink)
Alupu
Points: 420, Level: 7
Points: 420, Level: 7 Points: 420, Level: 7 Points: 420, Level: 7
Activity: 0%
Alupu's Avatar
Originally Posted by cloudgmc View Post
i got my truck about 2 months ago, im starting to hate the ride. its really bumby. every little bumb or speed bumb truck bounces like 3 or 4 times (i almost fall out of my seat). i have rancho shocks on there (came with the truck). i have them set to 3. .
TRUST ME, SET all of them to 5 or the softest position
front and back.
2nd, what LOAD range tires do you have?
Load range C has a smoother ride than D and E
Alupu is offline   Reply With Quote
Old 08-18-2008, 11:12 AM   eBay Motors   #17 (permalink)
Nor-Cal Nick
Points: 17,261, Level: 57
Points: 17,261, Level: 57 Points: 17,261, Level: 57 Points: 17,261, Level: 57
Activity: 3%
Activity: 3% Activity: 3% Activity: 3%
Nor-Cal Nick's Avatar
You guys do know that Rancho shocks are generic valved. They don't do any testing to make sure you as a end user is getting the best valving for your application. I have been around trucks for years and they don't have any valving spec's to offer so something to think about when spending the money.
2008 Chevy 3500HD Dually LTZ <<< Clink on link to see truck.
Cognito 2-3 leveling kit, HD tie rods, Steering braces, Idler pivot, Front & Rear Sway Bar, Bistein's frt & rear, Sulastic shackles, Bags, Toyo MT 295/70r17 w/2" spacers, AFE stg2, MBRP 5" turbo back w/RBP back 6" tip, EFI Live by Duramaxtuner.com, Nexus gauges, Nicktane fuel filter, TTS Dual pumps & pick up, Transgo JR, MagHytec Trans & Diff pans, Titan 62gal fuel tank, Amp boards, 8000k HID Headlights and fogs, Drawtite Sig.24k 5er.
6-7-08 “400hp Fun Tune” >> 414hp./786tq.
6-7-08 “LMM08_08_HOT_6.07.08_Highboost” >> 440hp./805tq.
Nor-Cal Nick is offline   Reply With Quote
Old 08-28-2008, 01:38 PM   eBay Motors   #18 (permalink)
DMax07LBZ
Points: 292, Level: 5
Points: 292, Level: 5 Points: 292, Level: 5 Points: 292, Level: 5
Activity: 0%
DMax07LBZ's Avatar
Those spacers on the top of the shocks are causing the bad ride because since the shock isnt made for a level kit usualy 2 inches the cheap way to cure this is to add those extension but when ever you hit a but the arms will just sort of dangle and bottom out thus causing problems with the ball joints later on recommendations are check the level kit then go for some bilstein 5100 shocks for trucks with 0-2 inches of lift it MAKES A HUUUGE difference and i know this because my truck had the same thing bought all 4 bisteins on ebay for 270 and took me bout an hour and a half to install em my local shop wanted 400 for everything! saved myself close to 200 bux
2007 Silverado Duramax LBZ Crew Cab
Escalade handles, Bedrug, Painted bumpers and mirrors, 5% Tint All around, 20% Tint on Windshield, Smoked Tail lights and 3rd Brakelight
2 Fosgate Shallow Mount Sub's, Alpine IVA-505, Diamond Audio Components, 2 TUNN 1,300 watt Amps, 6 Tv's Total
RBP Turbo Back Exhaust. Edge Juice with Attitude, Trueflow XDI Air Intake, Resignator Plug
Clifford SST 2-Way Alarm with GPS Tracking & Remote Start, H.I.D Headlights
Pro Comp Level Kit, Bilsetin 5100 Shocks All Around
Helo Max Wheels Black, 33inch Mickey Thompson Baja Claw Radial
DMax07LBZ is offline   Reply With Quote
Old 08-28-2008, 02:00 PM   eBay Motors   #19 (permalink)
Nor-Cal Nick
Activity: 3%
DMax07LBZ,
What 5100's are you running? The Yellows or Zinc plated?
Old 08-28-2008, 02:41 PM   eBay Motors   #20 (permalink)
DMax07LBZ
Activity: 0%
DMax07LBZ's Avatar
the zinc plated ones the yellow look too funky for my tastes lol
