| Cognito Kit is the way to go I think the cognito kit with the bilsteins is the way to go. I have had the truxx kit with the shock extenders and it left alot to be desired in the ride quality department. The ride you get with doing the cognito control arms with the longer shocks is as good as it gets. I did the control arms keys and it gave me so much lift I had to put 3 inch inch blocks in the rear to bring the back up to match the front, and the bolts that adjust the torsion keys are not even close to being bottomed out, I would say there closer to coming out than bottoming out.
__________________ 2004.5 Black GMC 2500 LLY CC 4wd
Cognito Control Arms and torsion bar keys
Cognito Pitman and Idler System 2 inch rear blocks
Bilstein Shocks 315/75R16 BFG KM2's
Bullydog RFI-MBRP 4" Turbo Back Exhaust
Weatherguard Tool Box-Westin Step Bars PPE Standard
Warn Transformer,Black, Warn 12000 lb. winch
Warn 210 dual beam lights. KC Hilites backup lights
2-Rockford Fosgate P3 10s. Punch 360 Amp.Line X Bed Liner |
