Towing capacity? - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 25 (permalink) Old 10-01-2008, 03:51 PM Thread Starter
Towing capacity?
I know my 2005 duramax is rated at 12000 GVWR but when I was in the heavy equipment business, building roads,etc. The pickups were usually 3/4 ton Fords and they were hauling backhoes and small rollers and assorted other pieces of heavy machinery using big bubba trailers all over the mountainous western US. I bought the duramax to out do those Fords and when I was in the biz I only towed a small 17' 3,000 lb travel trailer. Now I want to upgrade to a 28' 5th wheel that weighs around 11000 lbs. That only leaves 1000 lbs before I reach the GVWR according to the sticker on the Driver's door and in the owners manual. Somewhere, I can't remember, I heard that I could actually tow up to 15,000 lbs. One of the mechanics in the biz who had a 36' 5th wheel, towing it with a '88 3/4 ton Ford gas model was going to a 40' 5th wheel. He told me it was the hitch weight that mattered not the GVWR. My question is how much weight can I tow with my 2005 chevy silverado duramax diesel
moedecker is offline
post #2 of 25 (permalink) Old 10-01-2008, 04:50 PM
LHN...We ARE the Joneses
Gross Vehicle Weight Rating on a DRW 3500 is 11,400k lbs. The empty 'Wet' weight (Crew Cab) is approximately 7.3k lbs, leaving you with a rated capacity of 4.1k lbs for passengers, cargo and trailer pin weight.
With a fiver weighing 11k lbs, figure 15% or 1,650 lbs of pin weight. That leaves you with 2,450 lbs for passengers and additional cargo.
The rated towing capacity for a GN/Fiver on a DRW 3500 is around 15k lbs.
You should address the LLY turbo mouthpiece problem to ensure a problem free towing experience and you'll be fine.
Hook'em_Horns! is online now
post #3 of 25 (permalink) Old 10-01-2008, 05:21 PM
timespentsearching's Avatar
i pull 20,000 pounds all the time. as long as you dont have over 2000 tonque weight you can pretty muhc tow aobut anything
03 EC/LB LB7: EFI LIVE, S&B intake, 5" DE, ATS manifolds and up pipes, Stock turbo (for 1 more weeks), airdog 150, pieced together trans, sleeve (trac bars and centerlink soon), 8" rear air bags-overload springs+2" blocks, bilstein 5100 shocks, leveled, nitto 285/75/17's and BFG KM2 255/85/16's for winter.
timespentsearching is offline
post #4 of 25 (permalink) Old 10-01-2008, 05:44 PM Thread Starter
Thanks guys, this really helps
post #5 of 25 (permalink) Old 10-31-2008, 11:05 PM
My 2007 LBZ is commercially licensed for 36k GVW but the most I've pulled is just over 34k GVW. I pull a 45' lowboy flatbed all over the country with my rig and the only problem I have is an occasional DTC P0087 which can be fixed with a shim kit according to IdahoRob.
Oregon Hotshot is offline
post #6 of 25 (permalink) Old 10-31-2008, 11:19 PM
big block 88's Avatar
I kinda don't even look at the trucks GVWR or the GCWR I just pull if the truck feels it can't or doesn't want to pull the load I will switch trucks.
Jordan Blake
Tow Pig-03 LB7/Alli EX Cab Long Bed, Dually, alot of miles dents scratches and dents, EFI
Alli-07 LBZ/Alli, Cognito, PPE, Airgdog, Bilstien, EFI McRat/Neens tuned, trippin auto meters, other things and stuff
big block 88 is offline
post #7 of 25 (permalink) Old 08-26-2009, 05:46 PM
Anybody pull a gooseneck horse trailer with a newer duramax? How does it do? Looking at buying one soon. Thanks
cmatt01 is offline
post #8 of 25 (permalink) Old 08-26-2009, 05:57 PM
Oregon,
How do you license a truck to tow over the manufactures ratings? While I agree that it is most like capable I would like to know the process of such licensing. Does it simply require the proper DOT numbers and CDL drivers license or is there more to this process?
diesail is offline
post #9 of 25 (permalink) Old 08-26-2009, 06:15 PM
Some states base registration fees on the declared maximum weight going over their roads, and not the mfrs stated gvwr. Get caught over what you declared and it's $$$$$.
It's a fee/tax/fine for a money grab, and not based on much of a safety factor, IMO.
Not much difference from other states that would charge for the truck based on 11,400lbs and then license and charge a GN with twin 12k axles...36k GCWR.
post #10 of 25 (permalink) Old 08-26-2009, 06:19 PM
06AFDmax's Avatar
Send a message via Yahoo to 06AFDmax
I know the other day I hauled my dads backhoe... It weighs a smidge over 14k (Case 580k) on a 24 foot gooseneck... only thing that worried me was my trans temp on the higher side... and i have a 3/4 ton... I think you would be just fin.. just make sure the tounge weight is good...
"No good decision was ever made in a swivel chair"
06 Silverado 2500 cc/sb Silver 6.6 Duramax LBZ BABY! H2 Wheels // Tow Mirrors // EGR Blocked // Edge Evolution // Diablo sport predator // Cobra 29 CB Radio//PPE Air Box Mod // Straight Piped Missing Kitty... !
1998 Dodge 3500 12 valve... ECLB Lariat w/ Fully skirted flatbed.. completely stock work truck... wait I think its missing the cat... wonder where it went to
Jackrabbit Services
"We Jump When you Call!"
06AFDmax is offline
