| Help trailer brake lights and turn signals not working I have an 06 silverado 2500 and all the lights on the vehicle are working. When I hook up my boat trailer the running lights work but not the turn signals or brake lights. I checked the fuses and they appear fine. The trailer wiring is all new and works fine when hooked to another truck. Any suggestions? |
| | eBay Motors #2 (permalink) | |
| Junior Member Join Date: Oct 2010 Location: Tennessee
| Quote:
If you are using an adaptor to change from the 7 pin plug to a 4 pin plug, check that out | |
| Duramax Forum Supporter ![]() Join Date: Nov 2009 Location: Indy OR 7S5
| The trailer fuses are located in the panel on the driver side end of the dash, they are different from the truck tai/brakel light fuses.
__________________ 2004.5 GMC SLT 4X4 CCLB LLY Ally, EFI Live V2 & DSP5 by Rob, Ride Rites, LBZ turbo inlet mod, po' man CAI, HIDs, stock height, Cognito tie rods, Bilstein 5100s, Isspros, H2 wheels with Toyo OC 285-70-17s, B&W turnover & Companion, Prodigy P3, dog snot on windows......Sent from my antique HP DV7-4183cl with Radeon HD5470 graphics, Beats Audio and Blu-ray drive..... |
| Senior Member Join Date: Jul 2011 Location: Edwardsville, IL
| IMO I always start with the ground with anything electrical. A bad ground can cause so many weird problems. Sent from my Autoguide iPhone app
__________________ 2010 Crew Cab Long Bed 4X4. Air lift 5000 air bags and compressor kit. PCV reroute. 5" DP back AFE with muffler. EFI live W/ DSP5 switch and Tunes by Idaho Rob. Transgo Jr. & Deep pan. 6K 35w low's and 55w High's http://www.atptrucks.com/ http://creaturesofthenightperformance.com/ |
| Of course I forgot to say after checking the fuses like those above me said. Sent from my Autoguide iPhone app
| Senior Member Join Date: May 2011 Location: Denver, Colorado
| Is the trailer light connection on the back of the truck live from the factory or do you have to do something to activate it?
__________________ 2008 GMC 2500 D-Max Crew Cab Long Bed Z71 100% Stock Real trucks don't need stacks |
| Yes all lights are alive from the factory. The 12 volt power at the plug may not be hot on some vehicles, but that is usually caused by GM using a dummy fuse and not a real fuse.
| I am having the same problem. My right brake/turnsignal on the trailer isn't working. The left is working just fine. I checked and replaced the fuse under the panel inside the driver side door and it still is not working. Any help would be a great appreciated. Sorry about hijacking the thread but it seems we are having a similar issue.
__________________ 2006 2500HD LBZ 4X4, 4 in. exhaust minus cat, afe stage 2 cai |
| Junior Member Join Date: Jul 2011 Location: Southern Maine
| I'm not sure if I'm going to give you a correct answer here but I owned a 2004 Chevy 2500hd and there is another fuse block under the hood left side near the brake fluid there I used to blow those fuses alot but all it takes is a little moisture try using a little connector grease from an auto store. Hope this helps |
