5th wheel towing capacity??? - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 09-03-2011, 06:52 PM Thread Starter
I have a 2003 2500HD 4x4 Extended cab i was wondering if anyone knows the 5th wheel trailer towing capacity. Looking to get a big toyhauler prob 16,000 or 18,000. Cant find the info anywhere!
2003, 2500 HD, Fabtech 8" Lift, 36" BFG KM2
KenHill is offline
post #2 of 6 (permalink) Old 09-03-2011, 08:53 PM
10200 lbs according to edmunds:
2003 Chevrolet Silverado 2500 Base Extended Cab Pickup 6.0L V8 4x4 4-speed Automatic 6.6 ft. Bed Features and Specs
2007 K2500HD CCSB- EFI Live by Idaho Rob DSP 2, CTS2 EAS EGT Probe, Transgo Jr, K&N FIPK, 265/75/16 on PYO
next mod-Pump Rub Fix-preventative
07TowPig is offline
post #3 of 6 (permalink) Old 09-03-2011, 09:09 PM
vanguardbh1's Avatar
I believe the total is 22,000 (truck, trailer, gear, dog) . My 03 with me in it is 7400 lbs. So that gives you 14,600lbs for a trailer (to stay legal)... Will your truck pull more??? Heck yes!! That's all the info I could find! Good luck!
2003 LB7 6" Tuff Country Lift, 35x12.5x20 Procomp MT, 20" American Racing Wheels, Edge Juice with Attitude, Sleeves, Ported Intake Horn, Custom Intake, Git R Dun:rockin
vanguardbh1 is offline
post #4 of 6 (permalink) Old 09-04-2011, 07:52 AM
NorskeNY's Avatar
Pin weight will be one your limiting ratings - with a 2500HD you will be limited to about 2000 lbs. A 16,000 to 18,000 tow hauler will have a pin weight of around 3000lbs or more. Your GVWR is 9200 lbs. The lift and big tires may impact how the 5th wheel tows (high in front). I had the same problem when looking at 5th wheels - pin weight. The dealer will sell you a trailer too heavy for your truck. I went to a 2005 3500 SRW (GVWR of 9900 lbs) and finally a 2011 SRW with a GVWR of 11,600 lbs. I added air bags to the truck to level it and improve the ride. Mine settles about 1 3/4 inches when loaded. I put about 50 lbs in the air bags.
My trailer is at about 12,000 lbs (with Harley in it) with a pin weight of about 2300 lbs. Manuf. numbers - 10,660 lbs and a pin weight of 2145 lbs.
2011 Chevy Silverado 3500HD LTZ CCLB LML SRW 4X4 Blue Granite Metallic.
Towing a 2012 Cruiser Patriot CF335SS fifth wheel.
Previous DAs:
2005 Chevy Silverado 3500 LT CCLB LLY SRW 4X4 Silver Birch Metallic
2004 GMC Sierra 2500HD SE ECLB LB7 4X4 Sand Beige Metallic
NorskeNY is offline
post #5 of 6 (permalink) Old 09-04-2011, 08:31 AM
bpe1's Avatar
By my signature you can note that I pull a rather heavy 5th wheel. We are 24,400 on the scales. This is truck, full fuel, me, full fresh tank, empty rest. Wife follows in separate vehicle. This is enough of a load that any canned tuner is out. Limped my tranny in Colorado. Flat roads was fine. What I am getting at is your truck will be very loaded and don't abuse it. Increased loads over GM ratings means fluids break down quicker, oil, tranny, diffs, etc. Brakes also wear quickly. Need to stay on top of rv brakes will help truck brakes but I go thru a set a year. I went over a year this time and had to replace rear rotors and calipers. OUCH. My truck is stock height and just slightly taller tires. My 5ther sits perfectly level. With your lift, the front will be up, reducing tailgate clearance and more wind drag. I am not a fan of flipping axles. This raises the center of gravity on the 5ther increasing roll over possibility. Never know when some fool will pull out in front of you and you are forced to go with your "home on wheels" where you don't want to go. Times with this (I've had 2) you will regret flipped axles. I am around 3500 pin weight. That's a lot for a 2500. I am very stable. Even in emergency situations. I have a lb cc 3500. You have the same drive as a 3500. It will tow it, air bags are mandatory. Don't want to hear this but I'd lower truck, and install stock or close to stock height tires. The larger tires increase load on engine. Higher final gear ratio. I full time in my 5thr. I travel a lot. Your 2500 towing that much weight will not be as stable as my 3500 especially in an emergency situation. Will be be all right? You have to decide that. I'm not trying to criticize, just help. God bless
2006 Freightliner Century 120 with Detroit Diesel. Sold my 2012 Chevy 3500 dually work truck with CM ER hauler bed and EZ Floater air hitch. Towing 2003 Teton Grand Freedom 5ther weighing 20,890 lbs. Traveling the USA welding pipe, repairing plants, building new ones & really enjoying God's beautiful country.
bpe1 is offline
post #6 of 6 (permalink) Old 09-05-2011, 10:44 AM
The truck is not anywhere rated for it but your biggest probelm would be the lift and tires you have. Especially the tires. They would be torn up fairly quick by that much weight on the hitch.
Re'
2005 K2500 LLY Allison 5spd Crew Cab 6.5' Bed
AFE Mouth piece
MBRP 4" w/Tip
Lots more to come
Re and Cheryl is offline
