5th wheel towing with a body lift - Chevy and GMC Duramax Diesel Forum
post #1 of 28 (permalink) Old 10-25-2011, 10:07 AM Thread Starter
Truck already had 3" body lift when I purchased it.
Currently we have a bumper pull TT about 6,000lbs
Looking to upgrade to a large tow hauler in the range of 15,000lbs.
Will there be any issues due to the body lift?
If so, then I guess I should upgrade to a proper "frame" lift...not really sure of the technical term for that.
Are there any add'l issues related to towing with a 4 inch "frame" lift?
Thanks in advance for your help.
2012 CC 4WD LT.White/lt.drk titanium 3/22/12
2005 CC 4WD LT White/tan....SOLD 11/29/11
2011 Passport 3050BH Trv Tlr
2012 KTM 350 XCF
2007 Cobalt 226 Classic Red
Brother Deal is offline
post #2 of 28 (permalink) Old 10-25-2011, 10:42 PM
Tow Master's Avatar
Id it were me I wouldnt do it. You wouldnt want that sticking that far above the frame.
Jason
Tow Master is offline
post #3 of 28 (permalink) Old 10-26-2011, 07:47 AM Thread Starter
If I switched to a more "proper" lift would I be OK?
2012 KTM 350 XCF
post #4 of 28 (permalink) Old 10-26-2011, 01:02 PM
Case-IH95's Avatar
I would think so, there are several people here towing 5th wheels with suspension lifts, but don't hold me to it.
2002 Chevy Silverado 2500HD Crew Cab Long Box
)-(Fabtech lift)-(
)-(Pro-Comp ladder bars)-(
)-(20" Eagle Alloy wheels)-(
)-(37x14 Toyo A/T's)-(
Originally Posted by AJ 72 View Post
Definitely build the transmission. Going into limp mode while trying to outrun a tornado would be counter productive!!!!
Case-IH95 is offline
post #5 of 28 (permalink) Old 10-26-2011, 01:16 PM
mainec's Avatar
The question is what was cut or removed when the kit was installed. If you are set on a 5th wheel then I would remove the body lift. If you are just doing a travel trailer and have a receiver hitch (not on the bumper) then you will be fine.
Been there done it with my 1500 that I put a body lift on.
2015 2500HD Duramax CC LTZ 4x4 Z71 Jet Black
Mods:
Bushwacker Fender Flares - Color matched
MB Wheels TKO 20X9 8-180 +18BS / Nitto Terra Grappler G2 LT 305-55-20 121S E2
The old truck:
2011 2500HD DMAX LML CC LT 4x4 Victory Red
Cognito 7-9" Lift Kit set at 7" / AMP Electric Running Boards / MBRP Cat Back Exhaust w/ Delete / H&S XRT Pro Tuner / K&N Cold Air Intake / BMF Novakane 8 22x10.5 Chrome
mainec is offline
post #6 of 28 (permalink) Old 10-26-2011, 01:18 PM
it stinks and whistles :)
Brennan's Avatar
as long as the truck fits underneath the trailer your good, i wouldnt tow a fifth wheel with a body lift. im not sure it would work anyway
06 lly,
Efi From ATP trucks,
5" straight pipe, egr blocked, cognito ucas,
rare parts gen2, bilstein 5100s, all season brace,
merchant pump rub fix, drp trans cooler lines,
air dogII 165
Brennan is offline
post #7 of 28 (permalink) Old 10-26-2011, 01:24 PM Thread Starter
Thanks..
As I am not sure exactly what type of lift is on the truck
I'm going to run her up to 4 Wheel Parts and see what is on it and what they
suggest. I already have 35" tires and am dead set on a big 5er tow hauler so I better do my homework.
2012 KTM 350 XCF
post #8 of 28 (permalink) Old 10-26-2011, 08:23 PM
joebedford's Avatar
Thanks..
Yeah, homework is a good idea. I'm sure you've already verified that GVWR and GCWR have not been compromised too much by the lift kit.
Well, probably you haven't.
Anyway, all that legal stuff aside, will your 5er clear the bed rails with such an extreme lift? You might have to flip the axles on the toy hauler to raise it to match the truck. Handling will be compromised of course but just drive slower.
Good luck,
Joe
PS: my toy hauler is a Voltage 3950 42'6" 19000 lbs. Only 2011 Chev can haul it (legally)
2011 Silverado 3500HD Duramax dually 4x4 CCLB LTZ STOCK
Reese 20K 5th wheel hitch
BakFlip hard folding tonneau
2011 Voltage 3950 Toy Hauler holding
her Harley Ultra / DFT trike
my Harley Ultra
joebedford is offline
post #9 of 28 (permalink) Old 10-26-2011, 08:29 PM
mainec's Avatar
Thanks..
Its probably a Performance Accessories. I think they are like the most common around.
Mods:
The old truck:
mainec is offline
post #10 of 28 (permalink) Old 10-26-2011, 08:47 PM
I have a 4" suspension lift on my truck and 44ft fifth wheel that weighs 17k it hauls it just fine. Just have to watch inclines so the bumper on the camper doesn't rub. So as long as you anchor the hitch to the frame good you should have no problems
2007.5 LMM Chevy 2500 LTZ crew cab short bed
Mods: AEM brute force intake, turbo back exhaust with banks dual tips, EFI live tuned (Idaho Rob), snow performance mpg max stage 3, G-max trans (ultimate transmissions), Yukon grizzly locker (rear), eaton e-locker (front), merchant automotive transfer case brace, and a 4" tuff country lift.
And a
2011 LML Chevy 2500 LTZ crew cab long box (stock)
Mavric is offline
