Pac Brake vs turbo brake tune - Chevy and GMC Duramax Diesel Forum
post #1 of 15 (permalink) Old 11-14-2011, 12:56 AM Thread Starter
i have a pac brake on each of my trucks that i tow with every day and love it! does anyone have the tune that closes the turbo wondering if it works as well or better than what i have?does it shorten the life of the turbo more than the pac brake since the valve is further down the exhaust? has anyone ever heard of an actual comparison test being done?
06 lbz 4" exhaust,fitch fuel catalist,juice,fs2500 bypass,amsoil in everything,pac brake,243k,ppe stage 4 trans,running 19.5 direct bolt ons
05 lly 4" exhaust,fitch,fs2500,amsoil,pac brake,246k,mike l stage 3 trans, running 19.5 direct bolt ons,amsoil in everything
vegas jake is offline
post #2 of 15 (permalink) Old 11-19-2011, 08:52 PM Thread Starter
anyone?
post #3 of 15 (permalink) Old 12-02-2011, 01:00 PM
I'm coming up blank
d-redd is offline
post #4 of 15 (permalink) Old 12-02-2011, 01:04 PM
Stone Colds Brother
08LMMWYO's Avatar
Well I don't have a pac brake, but I do have the Turbo brake and I love it.
Sent from my ADR6300 using AutoGuide App
RIDE: 2007 Chevy CCSB LBZ colormatched Black Pearl
LIFT: ZONE, Kryptonite Front end, Cognito Brace kit, Traction Bars, Comp. Tubes
TRANS: Big Dipper Stage IV/PPE Deep Pan / Pump rub fix
SOUND:X4500BT, 6 1/2 JL Audio's, 10"s, 5 Channel JL AMP
INTERIOR: EGT/Boost Autometers & CTS, Black Cherry Denali Trim and wheel, Black Leather, Red L.E.D's, US Speedo Cluster, Rubber Floor, 20% tint
ADD ONS: 40 overs, AD II 165, Oasis Diff, Roll pan, Merchant brace, BigChevyHitch, Cowl Hood, 4500K HIDs, AMP Research Steps, LM Grille, BedRug w/ Recon lights, ExTang Solid Fold, LED tails
TIRES/WHEELS: 35X12.50-20 Toyo MT on 20x10 BMF S.O.T.A's and 4.56 Gears
AIRFLOW: EPR Triples, Turndown, AFE intercooler pipe, EFI LIVE by www.ATPtrucks.com
08LMMWYO is offline
post #5 of 15 (permalink) Old 12-06-2011, 02:23 PM
chassie67's Avatar
Send a message via AIM to chassie67
what is the turbo brake everyone's talking about? anyone have a link or anything?
2004.5 CCSB mods:
banks bighoss intake, cat-back exhaust
GT-4094VA turbo. (love the whistle!)
AEM intercooler tubing, Diamond eye downpipe
AEM front pipe (cat delete)
AFE turbo inlet pipe
PPE hot ET+2 (running level 5)
Alligator performance Stainless Steel transfer case brace, 125 hp injectors, Stage 2 injection pump
not to mention strobes, CB, and sliding rear window!
chassie67 is offline
post #6 of 15 (permalink) Old 12-06-2011, 02:28 PM
gr8shot's Avatar
If you have an lly or newer you can get it tuned so that the turbo vanes close up under certain conditions which creates back pressure and slows the truck down. It works pretty darn well although I can't compare how it works against a pac brake style exhaust brake.
Sent from my phone, probably while driving and eating a sammich
Jesse
2004 LB7
Tastefully modded
Lots of miles
Built by Husker Diesel
gr8shot is offline
post #7 of 15 (permalink) Old 12-06-2011, 02:46 PM
oldschool
HumboldtDmax's Avatar
turbo brakes dont work very well on the 4094vvt because of the vane position
2007.5 LMM CHEVY CC LT Z71
FabFour bumpers, Rancho 4in w/Bilstiens, full Kryptonite steering with Cognito braces and trac bars,35x12.5 Toyo R/T on 20x10x4.5BS KMC Monsters
[BANKS intake,dual exhaust,intercooler]Diamond Eye down pipe, AFE tube, res. plug, PCV mod, 4094avnt, 60% over nozzles, PPE race valve & fuel pickup, AirDog 150, Fitch fuel catalyst
Mike L. SCIV w/1056 C3 oiler, EFI live, Duramaxtuner DSP 5, Edge Insight, ProFab manifold/up pipes & 3" short bridge/boost pipe
HumboldtDmax is offline
post #8 of 15 (permalink) Old 12-06-2011, 08:25 PM
Wouldnt that be hard on the turbo?
d-redd is offline
post #9 of 15 (permalink) Old 12-06-2011, 08:43 PM
01Dmax's Avatar
Considering that the boost built while using Turbo braking, is so much less than what it make to make power (10-12lbs or so) and this is with low egts. I can't see it being nearly as hard on the Turbo, as simply pulling a load.
I don't know how it compares with a pac brake, but I do know it works very well.
2006 CC/SB LT3 2500HD 4x4 D/A 285-65 18 TOYO A/T's on Black Monster's, Cognito UCA, EFI Live DSP5 thanks to Rob, Alligator Stage V trans w/ML converter, ADII 165, Autometer Cobalt pyro and boost guages, Rare Parts HD tie rods, blocked and shimmed, 5" Magnaflow straight pipe
2001 CC/SB 2500HD 4x4 D/A - SOLD
1993 Z28 M6
Lloyd Elliot ported heads and intake, LE 1.6 cam, 1.6 RR, 52MM BBK TB, 30lb/hr injectors, PCMforless tune, K&N FIPK, Pacesetter longtubes, Pacesetter ORY, Magnaflow catback -the cat Dynaspark billet optispark, RAM kevlar clutch, 275-45-17 pirellis on 17x9.5 ZR1's up front, 315-35-17 on 17x11 ZR1 rears
01Dmax is offline
post #10 of 15 (permalink) Old 12-06-2011, 08:49 PM
Turbo brake is nice but the pac brake gives you a lot more braking power.
DieselX-Darryl is offline
