Old 04-02-2007, 11:19 AM   eBay Motors   #11 (permalink)
rids15
Points: 1,053, Level: 12
Points: 1,053, Level: 12 Points: 1,053, Level: 12 Points: 1,053, Level: 12
Activity: 0%
Thanks for the info.
2007 Classic 3500 HD 4x4 Crew Cab Dually, LBZ
Metalic dark blue
Egde Evolution
MBRP 4" Turbo Back
B&W Turnover Ball Hitch
w/ fifth wheel companion
rids15 is offline   Reply With Quote
Old 04-03-2007, 08:55 AM   eBay Motors   #12 (permalink)
StevenE
Points: 1,223, Level: 13
Points: 1,223, Level: 13 Points: 1,223, Level: 13 Points: 1,223, Level: 13
Activity: 0%
Once an e-brake is installed, how does the driver activate it? I assume there is some sort of button/switch close at hand that activates the system. Also, I will be towing our new Rockwood 33' TT, about 7500# loaded. Would you recommned an E-brake for this?
2005 2500HD Duramax Siverado CC Ally 2WD
bone stock (for now)
Drawtite Class IV Ultra Frame Receiver
Rockwood 33' TT
StevenE is offline   Reply With Quote
Old 04-03-2007, 11:10 AM   eBay Motors   #13 (permalink)
Diesel Nut
Diesel Performance
Points: 4,490, Level: 28
Points: 4,490, Level: 28 Points: 4,490, Level: 28 Points: 4,490, Level: 28
Activity: 0%
Diesel Nut's Avatar
There are 2 different ways of activating the brake, either a shifter mounted or dash mounted switch. This switch will arm the system. When you lift off the throttle the brake will engage in about 3-4 seconds, to keep from being jerky. If you step back on the throttle the brake will disengage.
Anyone towing in the hills will benefit from an Exhaust Brake.
We are very busy in the shop, please call for fastest service!
Diesel Nut Motorsports
Everything you need for perfomance
Suncoast, PPE, EFI live, you name it, we have it
1-800-450-7036
Amsoil Online Store
Save some money - Become an Amsoil Preferred Customer
Make some money - Become an Amsoil Dealer
Diesel Nut is offline   Reply With Quote
Old 04-03-2007, 01:13 PM   eBay Motors   #14 (permalink)
StevenE
Activity: 0%
Is there any chance of engine damange?
Rockwood 33' TT
Old 04-03-2007, 05:02 PM   eBay Motors   #15 (permalink)
Diesel Nut
Diesel Performance
Activity: 0%
Diesel Nut's Avatar
No. The Brake is set to produce back pressure against the motor, but not near enough to float the exhaust valves. You aren't applying any more pressure to the motor than you do with normal driving. With turbocharged motors, you have whats called drive pressure, which is the pressure built up between the piston and the turbo wheel. This is what turns the turbo over. Every turbo has an A/R ratio, which tells you the ration of drive pressure to boost pressure. In the interest of turbo spool up and lack of smoke, most of your stock chargers are around a 2:1 due to smaller exhaust housings and wheels. So, at 30psi of boost, you make 60psi of drive pressure against the pistons. All you are doing is applying the same amount of pressure against the motor without building all that power.
1-800-450-7036
Amsoil Online Store
Old 04-04-2007, 08:42 AM   eBay Motors   #16 (permalink)
TravelswithCharly
Points: 1,414, Level: 15
Points: 1,414, Level: 15 Points: 1,414, Level: 15 Points: 1,414, Level: 15
Activity: 0%
All 2nd gen and higher dmax's have an exhaust brake from the factory: the Variable Vane Turbo. Mine is configured with EFILive such that I always have an exhaust brake at the higher non-fueled RPM's. Given that this custom tune also provides 90 towing HP, mpg benefit, lower noise, better altitude performance, nicer progressive power when empty than handhelds provide, accurate DIC, EGR defeat, wheel size speedo calibration, just to scratch the surface. a great tool.
04 LLY SRW SB
06 SRW SB
EFILive all conditions no smoke 100 HP tune, exhaust, TD-EOC, alternative stock Cold Air Intake.
TravelswithCharly is offline   Reply With Quote
Old 04-04-2007, 09:35 AM   eBay Motors   #17 (permalink)
StevenE
Activity: 0%
Diesel Nut ... pm sent.
Steven
Rockwood 33' TT
Old 04-07-2007, 11:28 AM   eBay Motors   #18 (permalink)
Ray,IN
Points: 2,292, Level: 19
Points: 2,292, Level: 19 Points: 2,292, Level: 19 Points: 2,292, Level: 19
Activity: 0%
The Allison FAQ page answers the question of using an exhaust brake on the D/A combo: http://www.allisontransmission.com/s...?CategoryID=11 In short, the Ebrake must be connected to the TCM.
Frozenhosehead- a true Jake brake willl not work to warm up an engine, because it works by altering valve timing, which effectively turns a diesel engine into an air compressor working in reverse. What this discussion is about is an exhaust brake- a restriction in the exhaust system.
2002 K3500 D/A LB, CC, black W/ blacked out lighting, stock. Tows a 40' fifth wheel RV (15.5K#) effortlessly.
Ray,IN is offline   Reply With Quote
Old 04-07-2007, 02:01 PM   eBay Motors   #19 (permalink)
2TheMaxx
Points: 889, Level: 11
Points: 889, Level: 11 Points: 889, Level: 11 Points: 889, Level: 11
Activity: 0%
2TheMaxx's Avatar
Originally Posted by 4wdcwby View Post
i thought the chevy has grade braking.or maybe engine/tranny braking. example. when i am pulling my toyhauler at a good rate of speed or going down a grade, when i step the brake my rpm's move up alittle and i think my engine and tranny start helping me slow down. ( poss down shifting ) ??
this is not the same as exhaust braking ?????????
This is not quite the same. Your transmission is using higher rpms and shifting down to slow the vehicle an exhaust (jake) brake uses back pressure in the exhaust. Ever hear a semi let off the gas and the exhaust roars, thats the jake brake.
I have used the allisons engine grade braking towing in the mountains and it works great. If there isn't enough speed reduction from the grade braking just tap the minus button on the shifter to drop another gear. This seemed to be sufficient enough and there was no need for a jake brake. I also drive a semi and every big rig driver knows you don't use the jake brake when it is snowy or icy unless you want the trailer to pass you up. In this case you shift down to create more rpms and there is also a johnny brake on semis. It is essentially a trailer brake. This will help slow you down and keep everything in a straight line. In snowy, icy conditions and if your towing a jake brake is trouble. Any other time ,unless your hauling more than these pickups are rated to tow, the engine grade braking is suffient. If you have to tow that much weight you can buy a good used semi for half of what a new diesel pickup costs.
07 Chevy Classic 2500HD DMax Crew Cab, SB
Superchips:Performance, Helo Maxx 8 Wheels, Bridgestone Revo Dueler 285/75 16, 2" lift rear, 2.25" torsion key lift front, Bilstein Shocks, Billet Grill, Lund Running Boards, B&W Turnover Ball/w 5th Wheel Adaptor, Tonneau Cover, Box Rails, Bed Rug
Girl's Drive Trucks Too
2TheMaxx is offline   Reply With Quote
Old 04-07-2007, 04:43 PM   eBay Motors   #20 (permalink)
TravelswithCharly
Activity: 0%
Originally Posted by 2TheMaxx View Post
In snowy, icy conditions a jake brake is trouble.
That is very important. Must be a manual engagement.
04 LLY SRW SB
06 SRW SB
