rear brake pad wear towing - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 10-15-2012, 06:08 PM Thread Starter
jevanb's Avatar
noticed my rears smell really bad after pulling out 13k 5er. is the trailer putting more stress on them then the fronts?? I hate my brake controller (Reese) it does not seem to slow it down much, and when the controller is set high the trailer jerks and grabs at a stop. should I expect accelerated rear pad wear while towing???
2006 LBZ ,gmax 6, AD2, DP and 4 inch,, nicktane,reroute,hid,gauges, ATP tuning, airbags,onboard compressor, superglide, PPE box
jevanb is offline
post #2 of 7 (permalink) Old 10-15-2012, 06:53 PM
redneck6821's Avatar
I had a couple brake controllers like the one you have and then I got a new work truck with the prodigy controller and I love it so I went and got one for my personal truck. I like it cause it gives you an actual digital read out of the braking pressure. Also iirc the rear brakes on these trucks do more stopping than the front
02 GMC ccsb
Fabtech 8" lift
38" Kumho Road Venture MTs
18" American Racing ATX rims
mbrp 4"
K&N CAI
Pioneer 7" indash DVD
nicktane adapter
redneck6821 is offline
post #3 of 7 (permalink) Old 10-15-2012, 07:15 PM
LHN...We ARE the Joneses
Yep, your trailer braking is not up to par and the truck's doin' all the work. It's built for towing and to help control any jackknifing effect when towing, your rear brakes get more umph than the fronts do.
This is why you never want to rely on the typical visual inspection of the fronts (when rotating) to determine pad life left. Judge by the fronts only and you could very well be gouging rear rotors with no pads left.
It doesn’t matter what brand of controller you go with (Reese, Draw-tite, Tekonsha), they all use the same guts. Just make sure you’ve got a proportional type controller that varies the braking output in relation to how hard you’re braking your truck.
No more slams at low speeds and no more panics at highway speed. Just smooth variable braking from the controller. Note: A new proportional controller is about 1/10th the price of a complete HD brake job.
Also, make sure your trailer brakes are adjusted properly. That with the new controller and you should be set.
Hook'em_Horns! is online now
post #4 of 7 (permalink) Old 10-15-2012, 08:00 PM
warsw's Avatar
X2.....even the best controller can't compensate for brakes that are not properly adjusted. Your controller may be OK.
2012 4x4 CC/SB Duramax.
Fold-A-Cover Hard Tonneua.
Ultra Goliath chrome Wheels.
Husky Mud Guards.
GM rear "wheel-well" inner liners.
Monroe 2969 steering stabilizer.
Luverne - Stainless Steel Side Entry Steps.
Wedged spacers in overload springs
warsw is offline
post #5 of 7 (permalink) Old 10-15-2012, 08:09 PM
Banned
Good working trailer brakes should be able to stop the truck and trailer safely... even without the truck using its brakes.
Hondarider552 is offline
post #6 of 7 (permalink) Old 10-15-2012, 08:36 PM
rd05lly's Avatar
You don't have gear oil on your brake pads do you. Makes me think you have a wheel seal bad because you are smelling them.
05 CCSB EFI Live by PPEI
2011 Chevy Tahoe
04 Olds Alero DD
76 Dodge Charger SE
https://www.syntheticmotorsports.com
rd05lly is offline
post #7 of 7 (permalink) Old 10-16-2012, 02:41 AM Thread Starter
jevanb's Avatar
smells like pad burning and no
leaks
jevanb is offline
