Gooseneck Vs 5th Wheel - Chevy and GMC Duramax Diesel Forum
Old 11-13-2012, 07:14 PM   eBay Motors  #1 (permalink)
Dmaxftw's Avatar
Any body give me a reason why you would utilize a 5th wheel now days in a pickup instead of a gooseneck setup? Gooseneck keeps your box useful when your not towing where the 5th wheel is huge and in the way.
2007.5 Sierra 1500 CCSB
Iron Bull Bumpers
PIAA Fog lights and reverse lights
BFG M/Ts
Waiting for the New body style to release before i purchase my new Duramax.
Dmaxftw is offline   Reply With Quote
Old 11-13-2012, 07:28 PM   eBay Motors  #2 (permalink)
Pat H's Avatar
For most campers, the 5th wheel plate supports more of the weight (or more specifically how the load shifts and is absorbed by the hitch). I have a gooseneck myself that came with the truck and haven't had a chance to use it yet, but it's definitely a little less intrusive than most 5th wheels I've seen.
2010 Chevy 2500HD CCSB LMM
A few things here and there installed
Originally Posted by danhr View Post
well you have reduced power..... you fix it by adding more power
Pat H is offline   Reply With Quote
Old 11-13-2012, 07:36 PM   eBay Motors  #3 (permalink)
b14
i have 5th wheel rails, my curt goosneck spyder plate takes a verticle load of 6600lbs and a 26500 trailer weight,, and you can get upto 20000lb 5 th wheel plates.. but holy expensive and my gooseneck plate still takes more weight..
2010 2500 ccsb
dpf delete - egr blocked - cheap pcv re-route
efi live tuned dsp5 - by rob!
4" Diamond eye duals
afe intake with pro dry 2
ride rights
edge insight cts w/ egt probe and two backup cameras
Dirty Loud and Proud
b14 is offline   Reply With Quote
Old 11-13-2012, 07:45 PM   eBay Motors  #4 (permalink)
Dmaxftw's Avatar
Weight differences noted. Thanks for the info.
Iron Bull Bumpers
BFG M/Ts
Old 11-13-2012, 08:27 PM   eBay Motors  #5 (permalink)
FireRescue's Avatar
5th wheel is eaiser hook up and rides better, hence more of the RV's use it, but GN are used on heavy trailers, simpler and supports more weight but is also rougher. B&W turnover ball gives you both worlds if you want to have both and still have a usable bed.
2011 Chevrolet Silverado 2500HD WT, Victory Red, 4x4, ECLB, Duramax(LML)/Allison, Heavy Duty Towing Package
Insalled: Amsoil, Rhino Lined, B&W, Mayhem, Goodyear, Bushwacker, Code Alarm, Rigid Industries, AMP Research, Hypertech,Tint, Precision, Rough Country, Plastic Dip, WeatherGuard, Back Rack, H&S Performance, MBRP, DRP, S&B, Cognito, Ranch Hand, Warn
Need the Guts to Install: Frost Fighter, Snow Performance, Autometer, ATS, FASS, Titan.
http://www.dmaxstore.com, Your Duramax Diesel-Only Shopping Resource
FireRescue is offline   Reply With Quote
Old 11-13-2012, 08:42 PM   eBay Motors  #6 (permalink)
justavillain's Avatar
I have both and the companion is still expensive but being able to Have my entire bed at will is nice plus i use goosenecks on the farm.
B&W is the best of both worlds
Sent from my Galaxy Nexus using AutoGuide.Com Free App
2011 Duramax LML, CCSB
H&S Mini Maxx
MBRP 4" Turbo back exhaust(DPF Delete)
aFe Intake system dry filter
Ranch Hand Legend Grille Guard
parking assist sensor delete
275/70r18 Nitto Terra Grappler
Cognito leveling keys
justavillain is offline   Reply With Quote
Old 11-13-2012, 09:06 PM   eBay Motors  #7 (permalink)
Confidence Antler
RitzBlitz's Avatar
Gooseneck allows side to side articulation which is great for loads that go offroad often ie loads of hay fifth wheel provides rigid lateral connection for top heavy/wind susceptible loads ie travel trailers and parasitically uses some if the lateral stability of the truck itself.
06 ECSB GMC
30 gal. Transferflow Toolbox/Transfer tank combo
...and a few other things
505/992
-Erik
RitzBlitz is offline   Reply With Quote
Old 11-13-2012, 09:23 PM   eBay Motors  #8 (permalink)
KB3MMX's Avatar
^^^^^X2, the B&W setup is top notch !!!!
Ham Radio= Global communications without airtime fees
My Antenna-SteppIR
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo
--SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
KB3MMX is offline   Reply With Quote
Old 11-14-2012, 01:34 AM   eBay Motors  #9 (permalink)
JimmyD's Avatar
Can not go wrong with the B&W setup, no comparisons. Pricey but worth it.
09 GMC SLT Dually
Steel Gray Metallic
All options except sunroof
Ext CAB/2wd/Max/All
Mods so far:
Tow Mirrors, Chrome Grill Overlay
Rear underseat storage, Mudflaps all corners, 20% Window tint, 6" Oval Steps, B&W Turnover Hitch
Sulastics
JimmyD is offline   Reply With Quote
Old 11-14-2012, 03:18 AM   eBay Motors  #10 (permalink)
DenaliDuallyHD's Avatar
I have used Reese in the past for 5th wheel hitches. Have the B&W now and I love it. The B&W is built better, simple to hook up your trailer and offers a better truck/trailer ride.
The B&W was less expensive then the new Reese Elite Series hitch. After you add the up everything you need to equal what you get with the B&W; you are paying a lot more for the Reese.
Reese Elite Series Pre-Assembled 18K 5th Wheel Hitch 30142
Reese Elite Series Gooseneck Hitch 30845
JohnnyO
2012 Denali Dually HD 4x4
Banks Exhaust, Ram-Air & Custom Super-Scoop
Line-X, BedStep, BedStep2, Bed Rug
B&W Turnover Ball Hitch with Companion 5th Wheel Hitch
American Work Cover-rolling cover/toolbox w/ B-light tonneau lighting system
1993 GMC 1500 SLE Extended Cab Short Box, 4x4, 5.7 gas, traded it for:
1996 GMC 3500 SLE Crew Cab Dually, 4x4, 7.4L gas, sold it and got a:
2003 GMC 2500HD SLT Crew Cab Short Box, 4x4, 8.1L gas, traded it in for the 2012.
DenaliDuallyHD is offline   Reply With Quote
