| | eBay Motors #21 (permalink) |
| DuramaxForum Veteran Join Date: Jul 2007 Location: ObamaNation-Under the Dictator's rule
| ^^^^^^nice !! .
__________________ Ham Radio= Global communications without airtime fees My Antenna-SteppIR Si Vis Pacem, Para bellum !!!! ======================== 07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod) --EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo --SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe --AMSOIL Synthetics and filtration bumper to bumper, including Bypass --DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs --PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes --Danville 3" Y Bridge and big air intake kit / EGR delete |
| Junior Member Join Date: Aug 2012 Location: Minnesota
__________________ 2008 GMC 2500HD SLE Crew Cab 4X4 LMM...EFI live by ATP Trucks (Idaho Rob)...Glow Shift Pillar Pod w/ EGT, Boost & Fuel Pressure....Heartthrob 4" Double Turbo Diesel 409 Stainless Steel Exhaust System Nitto Terra Grapplers 285/65/18...18" Ballistic Havoc Rims...GM Tow Mirrors...60" LED Light Bar W/ Reverse...HID Lights...Kenwood DDX719 |
| | eBay Motors #23 (permalink) |
| Junior Member Join Date: Jan 2012 Location: minnesota
| Hey bassnspear I'm in the same area, I just have my grille cover on. Helps alot on short trip so it can actually warm up.. And should I take it off when towing? I pulled a 18ft fishhouse on a 3hr drive one Way.. Temp reached a little over 180 or so, is that okay? Sent from my iPhone using AutoGuide.com Free App
__________________ 2001 Chevy ecsb 5"mbrp, tow mirrors profab mouthpiece 20" hoss 305-55/20 terra grapplers firestone bags Idaho Rob dsp5 ppe boost valve CAT filter addapt. autometer gauges s&b intake |
| Senior Member Join Date: Sep 2011 Location: mount horeb wisconsin
| i always wear my bra in the winter, my boobs get cold easily... ![]() but on a serious note, i wear mine when it's 30 or under and it seems to really help it warm up fast.. i let her run for 10 and then 1 mile down the road im at 185 degrees
__________________ Trey 01 gmc sierra slt crew cab 4x4 6.6 dmax, efi live by Idaho Rob, 315/75/16 Goodyear Duratracs on 16" Moto Metals, 3" body lift, 5" Diamond Eye straight pipe with 7" tip, Z Series Autometer Boost and Pyro, 6k Highs 8k Lows and 3K fogs, tinted windows cat adapter and donaldson filter, adII horn intake mod, tinted tails, lots of plasti dip led interior and dash lights, retros led reverse lights Big thanks to ATP TRUCKS and ALLIGATOR PERFORMANCE |
| Husker Diesel Pimp ![]() | Basically when the temp is below freezing its a good idea to put the winter cover on. Its up to you if you want the bumper and grill PR just the grill cover. Its not 100% necessary, the truck will run fine and still get reasonably warm without it. But it will help to warm the truck up faster and it'll run warmer. And it'll also stay warm a little longer after you shut it off too. On my lmm it made a huge difference, on the lb7 now it barely makes any difference at all, but I still use it anyway. Sent from my old skool Droid
__________________ Jesse Meyers | Husker Diesel | 402-502-6961 www.huskerdiesel.com | Email us! We will gladly match any competitor's deal! ![]() 04 LB7: It's coming along, slowly |
| Senior Member Join Date: Jul 2011 Location: Indiana, USA
| Where are you guys buying these winter covers?
__________________ 2003 LB7 2500HD ECSB -Edge Evolution CTS -MBRP 4" w/ 5"tip -Banks Ram Air -35w AGT 6000k HID's -5% tint allaround -285/75R16 Michelin LTX A/T 2s -300k miles and counting -Daily Driver |
| | eBay Motors #27 (permalink) |
| Senior Member Join Date: Feb 2010 Location: Dodge Co. WI
| I got my cover from ebay
__________________ 2004.5 lly ec/sb 4x4, EFI live by rob, afe mp, mbrp 4", idler and pitman braces 46 chevy truck 355, TH400, 9 inch 51 dodge M37 383, NP435, NP200, D70 power-lok front D70 detroit rear 5.13 sitting on 44s 66 chevy 3/4 ton 4X4 350, SM420, T221, D44, HO72 4.56 sitting on 36s 72 chevelle 468 w/ cross ram, 5 speed, 12 bolt posi 4.10 87 chevy 1 ton 4X4, 350tbi, TH400, NP205 twinstick, D60 power-lok, 14 bolt detroit 4.10 sitting on 33s or 37s http://www.atptrucks.com/ http://www.madjacksynthetics.com/ |
| | eBay Motors #28 (permalink) | |
| DuramaxForum Enthusiast Join Date: Sep 2010 Location: Maritimes, Canada
| Quote:
X2 The grill cover goes on as soon as the daily temp max is below freezing for a week solid and it comes off as soon as the days go above freezing again. I find it makes a big difference on how fast the truck heats up and keeping it at temp on the highway when the weather is frigid cold out. Never bothered with the bumper cover even if it hits -40C (same as -40F, that's where the scales cross over )
__________________ 2005 Silverado EC/SB, LLY, 4WD, EFI DSP5 V2 (Idaho Rob at ATP), Edge CTS w/ EGT probe, LML Exhaust Manifold, PPE shimmed FPRV, Banks LBZ air cleaner, Profab intake, LBZ Turbo Mouthpiece, Kennedy twin lift pumps w/ megafilter, Corsa 304 SS Exhaust, Mike L tranny cooler, EXAXT Steering System, Redhead Power Steering Box w/ Amsoil PS fluid, Green Torsion Keys, Allison Deep Pan w/ Suncoast Filterlock and Transynd ATF, Bilstein 5100's (Norcal), Cognito UCA's, 17" NBS alloy rims, 265/70R17 Michelin LTX M/S2's, Pioneer AVH-P3200BT, CubbyCam Backup Camera, Pop & Lock Power Tailgate Lock, Extang Solid Fold Tonneau Cover, Tekonsha P3 Brake controller, Alphatherm AT-38OD Washer Fluid Heater | |
| | eBay Motors #29 (permalink) |
| i bought mine from oreileys.
| | eBay Motors #30 (permalink) |
| DuramaxForum Veteran Join Date: May 2011 Location: Regina, Sask!
| That reminds me i need to put mine on!
__________________ 2006 LBZ Mike L Stage Awesome! Airdog2 165, 5" MBRP Turbo back EFI Live tuned by Idaho Rob, DSP5, ATP Cognito set at 8" Nor-cal Truck SS idler support/ Rare parts tie rods 37x13.50x20" toyo MT's/ XD Hoss wheels, Fuel Octanes HID's All on mod/ AMP reaserch steps |
