my 08 3500 cc didn't even come with a brake controller, do you have to order them extra? it was supposed to be a towing package but it's not there. so far i tow without it just fine, what do they look like in a 08?
__________________ Tom's new truck: red 08 duramax lmm , LTZ, crewcab 3500 4x4, stock for now for towing racecar trailer #10000lb's , spray in liner, has black aftermarket ranchhand cowboy bumper with cowcatcher for that sinister look , matching back bumper, added a toolbox in bed , new lights on push bar , cb chip to come later remember old age isn't for sissies !! never hollar whooaa!! http://i335.photobucket.com/albums/m...1/P9150004.jpg
Integrated Brake Controller is built in. Just add you a Prodigy with the wire bundle included by the Parking brake. $100 for a controller is much cheaper than $1200 for a complete brake job on our trucks.
a prodigy controller, can i get one at a parts house instead of the dealer?
... I myself am trying to figure out how to get my 12v accessory wire activated!!!
Corey
On my '09, there are two Red/Black Aux Power wires located under/near the under-hood fuse box. One is taped to the harness between the fender and fuse box. The other is taped to a different harness between the engine and fuse box. This one was actually pushed under the fuse box and hard to find. Also, there is a third Red/Black wire which is for the trailer brakes, which was/should be already hooked up to the stud on the fuse box closest to the engine.
To get Aux Power to the rear bumper you have to hook up the Red/Black wire that is located between the Engine and the Fuse box to the stud on the front of the fuse box that is furthest from the engine If you have a 5er or a truck camper, you need to hook up the Red/Black wire that is located between the fender and the fuse box and add a harness under the front of the cargo box. You do not want either Aux Power wires on the same stud as the Trailer Brakes.
Both of my studs, in the under-hood fuse box, already had 40 Amp fuses in their circiuts, which are located just inside the fuse box by the studs, under the cover. Both studs are on the outside front of the fusebox, but under the cover. Apparently, GM stopped inserting dummy fuses.
__________________ '09 2500 Z-71 HD with Allison
'06 Desert Fox TH
'53 Cranky Spouse
N8AGS
