04 Duramax dually nicely tow a 16,100lb 5er? - Chevy and GMC Duramax Diesel Forum
post #1 of 24 (permalink) Old 12-04-2012, 12:39 PM Thread Starter
Howdy duramax folks,
I bought from my sister an 04 Silverado 3500 extended cab dually 4x4 w/ 6.6 Duramax, 8ft bed, 3.73 rear axle, automatic trans, and now I’m looking for a Toyhauler for some full timing, with some cross country trips, but not moving constantly. I need help determining if the one I'm looking at is really too big. It has the following specs:
Dry Weight 13,940 lbs.
Gross Vehicle Wt Rating (GVWR) 18,420 lbs.
Unloaded Vehicle Wt (UVW) 14,040 lbs.
Cargo Carrying Capacity (CCC) 3,520 lbs.
Hitch Weight 2,720 lbs.
I Believe the GCVWR of this dually is 23,500 lbs. I Know the GAWR FRT is 4800 lbs, GAWR RR is 8550, and GVWR is 11,400 lbs.
Let's assume the actual weight of the dually w/ passengers and everything is 7400 lbs. That leaves 16,100 lbs for the total weight of the trailer (23,500 - 7400). I can see maxing out at 16,100 lbs on the trailer with dirt bikes, gear, and full fresh water.
I know it depends on driving style a lot, but how’s it gonna tow at this max? Mountains? What about transmission life if I drive wisely and conservatively? What about going a bit over 16,100 lbs?
I like the layout of the Forest River better than some others. Other 3 slide toyhaulers: Cyclone 4012 is just as heavy, and Raptor 3712, is about 1500 lbs lighter. How much difference would 1500 lbs really make w/ the Raptor? All three have about the same hitch weight I think.
Thank you for any input. Especially from those with this kind of experience.
Gil
stummer is offline
post #2 of 24 (permalink) Old 12-04-2012, 12:43 PM
Stevenmc89's Avatar
If a tundra can pull the space shuttle then you should be able to pull the trailer you want!
2004 FORD F-250, 6.0, CC/SB, FX4, LARIAT. 33 BFG A/T, B&W, RANCHHAND BUMPER
SOLD2002 LB7 CC/SB 4X4, 6" RCX LIFT, 37" TERRA GRAPPLERS, 18" KMC HOSS, K&N CAI, EDGE EVOLUTION CS, STRAIGHT PIPE, NICKTANE, RANCHHAND BUMPER WITH 30" RIGID LIGHT BAR, AND OTHER DOO DADS
Stevenmc89 is offline
post #3 of 24 (permalink) Old 12-04-2012, 12:47 PM
js05sierrahd's Avatar
Congrats on the new truck! Is it an 04 LB7 or 04.5 LLY?
If its an LLY may need to implement a few preventative cooling measures before you hook to that beast! Lot of info on LLY overheating on here.
Other than that bit of info I know very little about hauling anything that large, but I'm sure others will chime in shortly!
2005 GMC 2500HD • 4x4 • Duramax • Allison • Denali Headlights • 285/55R20 Nitto Terra Grapplers on Black/Machined XD Hoss -12 Offset • MBRP 4" Stainless Turbo Back • Diamond Eye Turbo Direct Pipe • LBZ Mouthpiece • EGR Blocked & Cooler Bypassed • PPE Standard Level 4 • Autometer Cobalt Boost Gauge • EDGE Insight CTS w/ EGT Probe • Head Gaskets & Studs @ 145,000 MILES
Check out some pics HERE
HERE
js05sierrahd is offline
post #4 of 24 (permalink) Old 12-04-2012, 12:54 PM
rkhodges21's Avatar
I agree with js. If it is an LLY, there are a few things you will want to do to it, but it should be bullet proof after that especially if you leave everything else stock.
If it is an LB7, you need to know if it has had injectors replaced. If not, save up and be ready to do that in the near future.
Other than that, do not hesitate to put some weight behind it, and don't worry, it will be able to tow more than you are skilled enough to tow, and that is not a knock on your towing skills in the least.
05 GMC LLY crew cab 4x4. aFe intake + mp, catback 4" exhaust, Nicktane Adapter w/CAT filter
Exterior:Billet Grille, LED Cab lights, LED Tails
Interior:Eclipse Nav/DVD head unit complete with backup camera
Originally Posted by Benjamin Franklin
Those who beat their swords into plowshares usually end up plowing for those who didn’t.
Originally Posted by Ronald Reagan
It isn’t so much that liberals are ignorant. It’s just that they know so many things that aren’t so.
rkhodges21 is offline
post #5 of 24 (permalink) Old 12-04-2012, 01:00 PM
YAMAHA1's Avatar
You'll pull it without any problems. I pull almost the same weight TH with still a little trailer behind that with ease. I'm sure now it'll only get easier since I got EFI Live from Rob.
sold: 01 lb7 drw cclb 1 ton 4x4
GM DRW club member #95
15' srw ccsb 3500 Denali debadged, 35% tint on the front half glass and 5% over stock tint on the back half glass, line-x bed, leveled with cognito stage 3 with stock keys, 20x12 fuel throttle wheels, 285/55/20 Mickey Thompson atz p3 tires, 5000k 55w hid headlights, led fogs, amp auto steps, 90 gal transfer fuel tank, b&w ball hitch, B&W companion 5th wheel hitch, firestone bags, kicker 400w upgrade
YAMAHA1 is offline
post #6 of 24 (permalink) Old 12-04-2012, 01:05 PM
I second this all of these trucks are strong pullers! BUT Stoping thats another story! Keep your max GVW in check, just cause you can pull it doesn't mean you can do it safely...
HERE
post #7 of 24 (permalink) Old 12-04-2012, 03:40 PM Thread Starter
sj05sierrahd and rkhodges the transmission is an Allison. I’m not fluent in all the abbreviations, but that must be what LLY is. Thank you very much, and I’ll look into that. I’ve towed an 8500 lb travel trailer w/ an 1999 V10 Ram 2500frt/3500r leaf springs a lot ski/treking in the US/Canada Rockies full timing for 3 years a while back. I went through a transmission due to powering up steep hills in overdrive towing only waterlogged 16 foot Boston whaler in BC. Lesson learned. I am now a smiling totally relaxed slowpoke all the time honest to goodness. YAMAHA1 thanks. Yes it’s all about stopping. Going down big mountain passes, I used to sparingly use the brake controller independently of the foot pedal brake. Sometimes trailer brakes without truck brakes can seamlessly and instantly draw truck and travel trailer in line and in sync. Sparingly though or you'll destroy the trailer brakes.
Ah if the world were still flat!
Thanks everyone. More perspectives?
stummer is offline
post #8 of 24 (permalink) Old 12-04-2012, 03:57 PM
LLY is the engine code, if the 8th digit of the VIN is 1 its an LB7 if its 2 then its an LLY.
05 LLY
EFI Live
Built Trans
Built Front End
Supporting Mods
andy-stevenson is offline
post #9 of 24 (permalink) Old 12-04-2012, 04:12 PM
JUST TROLLING AROUND
vinnie gillotti's Avatar
Send a message via Yahoo to vinnie gillotti
if it.'s a lly there are some things you should do to it beforehand towing injectors under vauvle cover lb7 good to go injectors visable to the eye lly
vinnie gillotti is offline
post #10 of 24 (permalink) Old 12-05-2012, 10:37 AM Thread Starter
Thank you for the info everybody. The 8th digit is a 2 so it's a lly. I did a search on the site for lly injectors and read very briefly about rebuild or replace and something involving an ice pick. Don't know if that's what you're talking about. What's the issue and what needs to be done? I'll get a shop to do it. Approx cost?
Is this something I should look into? Also wondering about Ride Rite airbags/airsprings. And of course there's the question of the choice of which fifth wheel hitch.
stummer is offline
