Trailer brakes/controller acting funny - Chevy and GMC Duramax Diesel Forum
Old 12-07-2012, 04:59 AM   eBay Motors  #1 (permalink)
Hoping someone can shed some light on a recent problem I have encountered. I had bought a trailer real cheap and then re-wired the entire thing and also put new brakes on. The problem I am having is I believe with my brake controller. If I pull the pin for the breakaway, all 4 lock up (dual axle). If I use the manual over-ride, all 4 lock up. The problem I am having is when I try to use the brake controller and the standard brakes. If I leave the wiring as is, I get nothing no matter how it is adjusted with the dial(on two different brake controllers). When i first took a look underneath, I saw a wire that someone had jumped from the white wire on the switch on the brake pedal to the red wire coming off of the brake controller. If I hook that back up and try it then all I get is full brake as soon as I tough the pedal.
My questions to start are....
1. Should I have to jump any wires on my truck for this?
2. If so which ones?
3. Should the white wire be reading 12 volts right away after engaging brake pedal or should it be proportional based on the amount of push on the pedal?
Thanks guys. It's a 10,000 pound trailer so I really need the brakes.
04.5 LLY CCLB Silverado White 193,xxx miles
-Tuned by Rob
-Big Dipper
-AFE Intake
-AD2 165
-5" MBRP Straight Piped
-Pypes downpipe soon
G-Auto is offline   Reply With Quote
Old 12-07-2012, 06:07 AM   eBay Motors  #2 (permalink)
KensAuto's Avatar
the white wire is ALWAYS ground on a brake controller, black is power, red hooks to brake lights, and blue goes to trailer (this is at the controller itself)
2012 GMC 2500 SLT 4x4
H&S minimaxx, MBRP downpipe back SS duals, Insight CTS w/backup cam, Fass HD150, PPE rear diff cover, Amsoil front to rear w/by-pass
Cognito 4-6 NTBD w/idler/pitman braces, a-arms, Monster energy 18x9 w/BFG KM2s 35x12.5, Recon smoked cab lights
Titan 57 gal saddle tank, linex color matched bedliner w/kevlar, Trekstep bed steps x2, RBP rail steps
KensAuto is offline   Reply With Quote
Old 12-07-2012, 06:14 AM   eBay Motors  #3 (permalink)
nick1camper's Avatar
Did you replace the dummy fuse under the hood with a real fuse? That could be why it's not working.
2005 ext cab sb LLY
4" exhaust w/muffler, EGR delete/Sinister diesel, Kodiak LBZ mouthpiece, PCV rerouted, Nicktane/CAT adapter, Autometer pyro & boost gauges, EFI Live by Kory, Transgo, pump rub kit, LBZ intake conv, H2's, Debadged
nick1camper is offline   Reply With Quote
Old 12-07-2012, 06:14 AM   eBay Motors  #4 (permalink)
Right. It was the white wire coming off the brake pedal switch (not the brake controller) that had been jumped to the red on the brake controller. Is there any reason that I should have to jump anything with the factory wiring in the truck ready from a brake controller?
-Tuned by Rob
-Big Dipper
-AFE Intake
-AD2 165
Old 12-07-2012, 06:15 AM   eBay Motors  #5 (permalink)
I have not. The box was installed by one of the PO's but it couldn't hurt to check. What should I be looking for? Thanks.
-Tuned by Rob
-Big Dipper
-AFE Intake
-AD2 165
Old 12-07-2012, 06:16 AM   eBay Motors  #6 (permalink)
U know there is a harness that just plugs in
That would eliminate the chance of it wired to the wrong side off the brake switch
What brake controller do u have does it have level and gain or is it self leveling
06 Chevy cc sb lbz
Efi live egr delete 4 in silverline exhaust edge insight with egt probe b&w turn over with companion 5 wheel hitch air bags cat adapter from alligator performance magnaflow dp ad2 165 all on mod sulastic shackles updated body mounts
pud383 is offline   Reply With Quote
Old 12-07-2012, 06:18 AM   eBay Motors  #7 (permalink)
Look in the under the hood fuse box. find the one for the trailer brakes. if the PO didn't know to replace it, there should still be a "dummy" fuse in that spot, and would explain why they had to "jump" wires to get power.
2005 ext cab sb LLY
Old 12-07-2012, 06:36 AM   eBay Motors  #8 (permalink)
I have the wiring harness for the controller. It's a draw-tite activator III. I'll check the fuse.
Thanks guys.
-Tuned by Rob
-Big Dipper
-AFE Intake
-AD2 165
Old 12-07-2012, 06:37 AM   eBay Motors  #9 (permalink)
Would the manual over-ride still work without the fuse though?
-Tuned by Rob
-Big Dipper
-AFE Intake
-AD2 165
Old 12-07-2012, 06:38 AM   eBay Motors  #10 (permalink)
I'm not sure, but it never hurts to check the easiest things first, says I. LOL.
2005 ext cab sb LLY
